310 408 01
310 408 01
    SPELSBERG
    SPELSBERG - 310 408 01 - Plastic Enclosure, Junction Box, Polyethylene (PE), 37 mm, 43 mm, 89 mm, IP...
310 408 01 数据手册
JUNCTION BOX Mini 25-2,5² Mini 25-2,5² Junction box 89 x 43 x 37 mm Article number: 31040801 Junction box acc. DIN EN 60670 (VDE 0606), 10 entries, 2 floor entries, suitable for confined installation environments such as suspended ceilings and cable ducts, complete with perforation tool and blanking plug, with external fixing positions grey, with 3 interlockable screw terminals 2.5 mm² Technical data Certificates Measures Width: 89 mm Length: 43 mm Height: 37 mm Cover: VST RR - Blanking plugs HandyGrip VG 20 - Terminal strip Material Base: Accessory HandyGrip VG 21 - Terminal strip Polyethylene Polypropylene HandyGrip VG 21 w - Terminal strip HandyQuick SQ 32 - screwless terminal HandyQuick SQ 52 - screwless terminal Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) JUNCTION BOX Mini 25-2,5² Other attributes Color: Rated cross section: Tackable: Environmental attributes grey Ambient temperature (min.): -25 °C 2,5 mm² Ambient temperature (max.): 40 °C No Ambient temperature (24 h): 35 °C Rated insulation voltage AC: 400 V Explosion safety: none Fire protection: none sealable: No Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Ingress protection: Weatherproof: Equiqment: Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% IP55 - acc. EN 60529 / DIN VDE 0470-1 No Terminal Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
310 408 01 价格&库存
很抱歉,暂时无法提供与“310 408 01”相匹配的价格&库存,您可以联系我们找货
