320-970.
320-970.
    SPELSBERG
    SPELSBERG - 320-970. - Plastic Enclosure, Junction Box, Polypropylene (PP), 42 mm, 75 mm, 75 mm, IP5...
320-970. 数据手册
JUNCTION BOX HP 70-L HP 70-L Junction box 75 x 75 x 42 mm Article number: 32097001 Junction box acc. DIN EN 60670 (VDE 0606), 3 recessed stepped nipples, and two loose ones enclosed, seal range 5 16 mm, for terminals up to 2.5 mm² grey, without terminals Technical data Accessory Abox 025/040 KLS-2,5²/4² - Terminal block Measures ADR M20 - Sealing ring Width: 75 mm DMS M20 - Double-membrane seals Length: 75 mm DMS M20/sw - Double-membrane seals Height: 42 mm KVR M20-GDB/MGM - Cable gland Inner height: 38 mm KVR M20-MGM - Cable gland Inner width: 68 mm SNI M20 - Stepped nipple Material Environmental attributes Base: polypropylene, flame-retardent Cover: polypropylene, flame-retardent Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Ambient temperature (24 h): 35 °C Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) JUNCTION BOX HP 70-L Other attributes Equiqment: Entries: Rated cross section: Tackable: None 8 240 mm² No Rated insulation voltage AC: 400 V Explosion safety: none Fire protection: none sealable: No Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Ingress protection: Weatherproof: IP55 - acc. EN 60529 / DIN VDE 0470-1 No Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
320-970. 价格&库存
很抱歉,暂时无法提供与“320-970.”相匹配的价格&库存,您可以联系我们找货
