110-409
110-409
    SPELSBERG
110-409 数据手册
EMPTY ENCLOSURE TK PS 1309-6-o TK PS 1309-6-o Empty enclosure CUSTOMIZABLE 130 x 94 x 57 mm Article number: 11040901 Empty enclosure, base and cover: polystyrene, grey, similar to RAL 7035 without knockouts Technical data Accessory ASS-kl - External hinge set Measures HBA - Mounting material Width: 130 mm MPS-KRI - Mounting plate Length: 94 mm NS 35-106 - Mounting rail Height: 57 mm NS 35-81 - Mounting rail Inner height: 45 mm TK ABL - External fixing lugs kit TK DST - Spacing kit Material TK MPI-1309 - Mounting plate Base: Polystyrene, grey, similar to RAL 7035 Cover: Polystyrene, grey, similar to RAL 7035 Sealing: Cover screw: TK TW-h - Partition wall TK TW-n - Partition wall TS 15-111 - Mounting rail Polyurethane Polyamide 6, fiberglass reinforced Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) EMPTY ENCLOSURE TK PS 1309-6-o Other attributes Ingress protection: Impact resistance: Protection class: Environmental attributes IP66 - acc. EN 60529 / DIN VDE 0470-1 Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C IK07 acc. DIN EN 5012 / VDE 0470 Part 100 Ambient temperature (24 h): 35 °C II - isolate protection acc. VDE 0106 Rated insulation voltage AC: 690V V Rated insulation voltage DC: 1000 V Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Fitted for outdoor application: No Combustion behaviour to UL: Combustion behaviour to VDE: Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% HB acc. UL94 650°C acc. VDE 0471/ EN 60695 sealable: Yes Weatherproof: No Knockouts: No Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
110-409 价格&库存
很抱歉,暂时无法提供与“110-409”相匹配的价格&库存,您可以联系我们找货
