802-907
802-907
    SPELSBERG
802-907 数据手册
JUNCTION BOX Abox 025-L Abox 025-L Junction box CUSTOMIZABLE 80 x 80 x 52 mm Article number: 80290701 Junction box acc. DIN EN 60670 (VDE 0606), Ui=690V, with selfsealing, soft inlet membranes, M20, seal range 2 - 16 mm grey, without terminal Technical data Certificates Measures Width: 80 mm Length: 80 mm Height: 52 mm Cover: Abox 025/040 KLS-2,5²/4² - Terminal block Abox PST - Sealing kit Material Base: Accessory AST M20 - Attachment bushes polystrole, membrane out of TPE Polystyrene Entries BST M20 - Ventilation seal DMS M20 - Double-membrane seals KS M20 - Combi set KVR M20-GDB/MGM - Cable gland {Vorprägungen oben}: 2 x M20 KVR M20-MGM - Cable gland {Vorprägungen links/rechts}: 2 x M20 MPS-KRI - Mounting plate {Vorprägungen unten}: 1 x M20 RST M20 - Conduit connector {Vorprägungen Rückseite}: 1 x M20 SNI M20 - Stepped nipple VST M20 - Blanking plugs WNI M20 - twist nipple Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) JUNCTION BOX Abox 025-L Other attributes Entries: Rated cross section: Tackable: WST M20 - Twist plug 8 2,5 mm² Environmental attributes No Ambient temperature (min.): -25 °C Rated insulation voltage AC: 690 V Ambient temperature (max.): 40 °C Fire protection: none Ambient temperature (24 h): 35 °C sealable: Yes Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Ingress protection: Weatherproof: Equiqment: Color: Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% IP65 - acc. EN 60529 / DIN VDE 0470-1 No None grey Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
802-907 价格&库存
很抱歉,暂时无法提供与“802-907”相匹配的价格&库存,您可以联系我们找货
