11200801
11200801
    SPELSBERG
    SPELSBERG - 11200801 - Plastic Enclosure, Multipurpose, Polycarbonate, Polystyrene, 165 mm, 254 mm, ...
11200801 数据手册
EMPTY ENCLOSURE TK PS 2518-16-to TK PS 2518-16-to Empty enclosure CUSTOMIZABLE 254 x 180 x 165 mm Article number: 11200801 Empty enclosure, Base: polystyrene, Grey, similar to RAL 7035, Cover: polycarbonate, transparent without pre-embossings Technical data Accessory ASS-gro - External hinge set Measures HBA - Mounting material Width: 254 mm MPS-KRI - Mounting plate Length: 180 mm NS 35-216 - Standard rail Height: 165 mm TK ABL - External fixing lugs kit Inner height: 150 mm TK MPI-2518 - Mounting plate Material Base: Cover: Sealing: Cover screw: Environmental attributes Polystyrene, grey, similar to RAL 7035 Polycarbonate, transparent Polyurethane Polyamide 6, fiberglass reinforced Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Ambient temperature (24 h): 35 °C Max. rel. humidity at 25° C (short term): 95% Max. rel. humidity at 40° C: 50% Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) EMPTY ENCLOSURE TK PS 2518-16-to Other attributes Ingress protection: IP66 - acc. EN 60529 / DIN VDE 0470-1 Impact resistance: IK07 acc. DIN EN 5012 / VDE 0470 Part 100 Protection class: II - isolate protection acc. VDE 0106 Rated insulation voltage AC: 690 V Rated insulation voltage DC: 1000 V Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Fitted for outdoor application: No Combustion behaviour acc. to UL 94: Combustion behaviour acc. to VDE: HB/V-2 acc. UL 94 650°C acc. VDE 0471/ EN 60695 sealable: Yes Weatherproof: No Cable entries: No Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
11200801 价格&库存
很抱歉,暂时无法提供与“11200801”相匹配的价格&库存,您可以联系我们找货
  • 1+517.29695
库存:63
