735-405
735-405
    SPELSBERG
735-405 数据手册
DISTRIBUTION BOARD AK 05 AK 05 Distribution board CUSTOMIZABLE 125 x 200 x 122 mm Article number: 73540501 Distribution board, 5 modules, PE/N terminal, with each 2 clamping points 16 mm², 3 clamping points 6 mm², 4 elastic entries on top, masking and labelling strips, insulating seals, additional double-membrane seals Technical data Accessory AK SGA-1 - Lock fittings Measures AK AS - Masking-off strips Width: 125 mm Length: 200 mm Height: 122 mm Material Base: Polystyrene, grey, similar to RAL 7035 Cover: Polystyrene, grey, similar to RAL 7035 Sealing: Cover screw: Environmental attributes Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Ambient temperature (24 h): 35 °C Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% Polyurethane Polyamide 6, fiberglass reinforced Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) DISTRIBUTION BOARD AK 05 Other attributes Color: Ingress protection: Number of distribution units: grey IP65 - acc. EN 60529 / DIN VDE 0470-1 5 Tackable: Yes Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes sealable: Yes Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
735-405 价格&库存
很抱歉,暂时无法提供与“735-405”相匹配的价格&库存,您可以联系我们找货
