EMPTY ENCLOSURE
TK PS 1811-9-m
TK PS 1811-9-m
Empty enclosure
CUSTOMIZABLE
180 x 110 x 90 mm
Article number: 10540601
Empty enclosure, Base and cover: polystyrene, Grey, similar
to RAL 7035
with metric knockouts
Technical data
Accessory
ASS-gro - External hinge set
Measures
HBA - Mounting material
Width:
180 mm
MPS-KRI - Mounting plate
Length:
110 mm
NS 35-144 - Standard rail
Height:
90 mm
NS 35-81 - Standard rail
Inner height:
75 mm
TK ABL - External fixing lugs kit
TK MPI-1811 - Mounting plate
Material
Base:
Polystyrene, grey,
similar to RAL 7035
Cover:
Polystyrene, grey,
similar to RAL 7035
Ambient temperature (min.):
-25 °C
Ambient temperature (max.):
40 °C
Polyurethane
Ambient temperature (24 h):
35 °C
Sealing:
Cover screw:
Polyamide 6, fiberglass reinforced
Environmental attributes
Max. rel. humidity at 25° C (short
term):
95%
Max. rel. humidity at 40° C:
50%
Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved.
Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299
Page 1 of 2
Powered by TCPDF (www.tcpdf.org)
EMPTY ENCLOSURE
TK PS 1811-9-m
Other attributes
Ingress protection:
IP66 - acc. EN
60529 / DIN VDE
0470-1
Impact resistance:
IK07 acc. DIN EN
5012 / VDE 0470
Part 100
Protection class:
II - isolate
protection acc. VDE
0106
Rated insulation voltage AC:
690 V
Rated insulation voltage DC:
1000 V
Heavy metals-free:
Yes
PVC-free:
Yes
Silicone-free:
Yes
Fitted for outdoor application:
No
Combustion behaviour acc. to UL 94:
Combustion behaviour acc. to VDE:
HB acc. UL94
650°C acc. VDE
0471/ EN 60695
sealable:
Yes
Weatherproof:
No
Cable entries:
Yes
Page 2 of 2
很抱歉,暂时无法提供与“10540601”相匹配的价格&库存,您可以联系我们找货
