130-008
130-008
    SPELSBERG
130-008 数据手册
EMPTY ENCLOSURE TK PC 2518-9-to TK PC 2518-9-to Empty enclosure CUSTOMIZABLE 254 x 180 x 90 mm Article number: 13000801 Empty enclosure - Industrial Quality -, base: glass fibre reinforced polycarbonate, grey, similar to RAL 7035, cover: polycarbonate, transparent without knockouts Accessory Technical data ASS-gro - External hinge set Measures HBA - Mounting material Width: 254 mm MPS-KRI - Mounting plate Length: 180 mm NS 35-216 - Mounting rail Height: 90 mm Inner height: 76 mm Material Base: Cover: Sealing: Cover screw: TK ABL - External fixing lugs kit TK MPI-2518 - Mounting plate Environmental attributes Polycarbonate, glass-fibre reinforced, grey similar to RAL 7035 Polycarbonate, transparent Polyurethane Polyamide 6, fiberglass reinforced Ambient temperature (min.): -35 °C Ambient temperature (max.): 80 °C Ambient temperature (24 h): 60 °C Max. rel. humidity at 25° C (short Therm): 95% Max. rel. humidity at 40° C: 50% Created on 2015-04-30. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 EMPTY ENCLOSURE TK PC 2518-9-to Other attributes Ingress protection: IP66 - acc. EN 60529 / DIN VDE 0470-1 Impact resistance: IK08 acc. DIN EN 5012 / VDE 0470 segment 100 Protection class: II - isolate protection acc. VDE 0106 Rated insulation voltage AC: 690V V Rated insulation voltage DC: 1000 V Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Fitted for outdoor application: Yes Combustion behaviour to UL 50 / UL 746C: Combustion behaviour to UL 94: Combustion behaviour to VDE: 5VA nach UL 50 / UL 746C V-2 acc. UL 94 960°C acc. VDE 0471/ EN 60695 sealable: Yes Weatherproof: Yes Knockouts: Yes Created on 2015-04-30. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
130-008 价格&库存
很抱歉,暂时无法提供与“130-008”相匹配的价格&库存,您可以联系我们找货
