804-907
804-907
    SPELSBERG
804-907 数据手册
JUNCTION BOX Abox 040-L Abox 040-L Junction box CUSTOMIZABLE 93 x 93 x 55 mm Article number: 80490701 Junction box acc. DIN EN 60670 (VDE 0606), Ui=690V, with selfsealing, soft inlet membranes, M20, seal range 2 - 16 mm grey, without terminal Technical data Certificates Measures Width: 93 mm Length: 93 mm Height: 55 mm Cover: Abox 025/040 KLS-2,5²/4² - Terminal block Abox PST - Sealing kit Material Base: Accessory ADR M20 - Sealing ring polystrole, membrane out of TPE Polystyrene Entries AST M20 - Attachment bushes AST M20-or - Attachment bushes BST M20 - Ventilation seal DMS M20 - Double-membrane seals {Vorprägungen oben}: 2 x M20 DMS M20/sw - Double-membrane seals {Vorprägungen links/rechts}: 2 x M20 GMU PA M20 - Lock nut {Vorprägungen unten}: 1 x M20 {GMU PG 16-M20} - Lock nut {Vorprägungen Rückseite}: 1 x M20 KS M20 - Combi set KVR M20 - Cable gland KVR M20-GDB - Cable gland Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) JUNCTION BOX Abox 040-L Other attributes Entries: Rated cross section: Tackable: KVR M20-GDB/MGM - Cable gland 8 4 mm² KVR M20-GDB/MGM/sw - Cable gland KVR M20-MGM - Cable gland No Environmental attributes Rated insulation voltage AC: 690 V Explosion safety: none Ambient temperature (min.): -25 °C Fire protection: none Ambient temperature (max.): 40 °C sealable: Yes Ambient temperature (24 h): 35 °C Heavy metals-free: Yes 95% PVC-free: Yes Max. rel. humidity at 25° C (short Therm): Silicone-free: Yes Max. rel. humidity at 40° C: 50% Ingress protection: Weatherproof: Equiqment: Color: IP65 - acc. EN 60529 / DIN VDE 0470-1 No None grey Created on 2015-01-26. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
804-907 价格&库存
很抱歉,暂时无法提供与“804-907”相匹配的价格&库存,您可以联系我们找货
