10590601
10590601
    SPELSBERG
10590601 数据手册
EMPTY ENCLOSURE TK PS 1811-11-m TK PS 1811-11-m Empty enclosure CUSTOMIZABLE 180 x 110 x 111 mm Article number: 10590601 Empty enclosure, Base and cover: polystyrene, Grey, similar to RAL 7035 with metric knockouts Technical data Accessory ASS-gro - External hinge set Measures HBA - Mounting material Width: 180 mm MPS-KRI - Mounting plate Length: 110 mm NS 35-144 - Standard rail Height: 111 mm NS 35-81 - Standard rail Inner height: 97 mm TK ABL - External fixing lugs kit TK MPI-1811 - Mounting plate Material Base: Polystyrene, grey, similar to RAL 7035 Cover: Polystyrene, grey, similar to RAL 7035 Ambient temperature (min.): -25 °C Ambient temperature (max.): 40 °C Polyurethane Ambient temperature (24 h): 35 °C Sealing: Cover screw: Polyamide 6, fiberglass reinforced Environmental attributes Max. rel. humidity at 25° C (short term): 95% Max. rel. humidity at 40° C: 50% Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 1 of 2 Powered by TCPDF (www.tcpdf.org) EMPTY ENCLOSURE TK PS 1811-11-m Other attributes Ingress protection: IP66 - acc. EN 60529 / DIN VDE 0470-1 Impact resistance: IK07 acc. DIN EN 5012 / VDE 0470 Part 100 Protection class: II - isolate protection acc. VDE 0106 Rated insulation voltage AC: 690 V Rated insulation voltage DC: 1000 V Heavy metals-free: Yes PVC-free: Yes Silicone-free: Yes Fitted for outdoor application: No Combustion behaviour acc. to UL 94: Combustion behaviour acc. to VDE: HB acc. UL94 650°C acc. VDE 0471/ EN 60695 sealable: Yes Weatherproof: No Cable entries: Yes Created on 2015-07-14. No responsibility is taken for the correctness of this information. Improvements for technical progress reserved. Günther Spelsberg GmbH + Co. KG · Im Gewerbepark 1 · D-58579 Schalksmühle · Germany · Phone: +49 (0) 23 55 / 892-0 · Fax: +49 (0) 23 55 / 892-299 Page 2 of 2
10590601
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光隔离型集成电路,用于红外发射和接收。
3. 引脚分配:EL817有5个引脚,包括Vcc、Out、GND、Vo和LE。
4. 参数特性:工作电压为3-15V,工作电流为10mA,隔离电压为2.5kV。
5. 功能详解:EL817通过红外信号实现电信号的传输,具有抗干扰能力强、传输距离远等优点。
6. 应用信息:EL817广泛应用于通信、工业控制、仪器仪表等领域。
7. 封装信息:EL817采用DIP-5封装。
10590601 价格&库存
很抱歉,暂时无法提供与“10590601”相匹配的价格&库存,您可以联系我们找货
  • 1+237.387201+30.76990
  • 2+217.684852+28.21610
  • 20+197.8953120+25.65100
