12066614
12066614
    APTIV(安波福)
    胶壳端子 14-17AWG
12066614 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,40 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,45 - 2,70 NONE Arrangement 1005 2,00 Nominal Insul. diam [mm] 2,58 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 1 of 19 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 200 1,65 Tol CCH [mm] 0,05 CCW [mm] 3,05 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 3,80 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,40 2,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,45 - 2,70 NONE Arrangement 1005 2,00 Nominal Insul. diam [mm] 2,58 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 2 of 19 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 200 1,65 Tol CCH [mm] 0,05 CCW [mm] 3,05 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 3,80 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,40 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,45 - 3,10 NONE Arrangement Nominal Insul. diam [mm] 1007 1,00 1007 2,00 2,58 2,98 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 3 of 19 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 120 200 1,50 1,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,00 3,20 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,80 3,80 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,40 1,00 | 2,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,45 - 3,10 NONE Arrangement Nominal Insul. diam [mm] 1007 1,00 1007 2,00 2,58 2,98 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 4 of 19 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 120 200 1,50 1,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,00 3,20 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,80 3,80 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,40 1,00 | 2,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,45 - 3,10 NONE Arrangement Nominal Insul. diam [mm] 1007 1,00 1007 2,00 2,58 2,98 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 5 of 19 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 120 200 1,50 1,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,00 3,20 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,80 3,80 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,40 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,90 - 3,95 NONE Arrangement Nominal Insul. diam [mm] 1009 1,00 1009 2,00 3,17 3,73 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 6 of 19 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 120 200 1,50 1,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,10 3,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,80 3,90 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,40 1,00 | 2,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,90 - 3,95 NONE Arrangement Nominal Insul. diam [mm] 1009 1,00 1009 2,00 3,17 3,73 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 7 of 19 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 120 200 1,50 1,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,10 3,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,80 3,90 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,40 1,00 | 2,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,90 - 3,95 NONE Arrangement Nominal Insul. diam [mm] 1009 1,00 1009 2,00 3,17 3,73 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 8 of 19 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 120 200 1,50 1,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,10 3,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,80 3,90 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal SN 0,40 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,35 - 3,55 NONE Arrangement Nominal Insul. diam [mm] 1011 1,00 3,45 Tear-out CCH force [N] [mm] 120 1,50 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 9 of 19 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,50 Tol ICH [mm] 0,10 ICW [mm] 3,90 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal SN 0,40 1,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 3,35 - 3,55 NONE Arrangement Nominal Insul. diam [mm] 1011 1,00 3,45 Tear-out CCH force [N] [mm] 120 1,50 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 10 of 19 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,50 Tol ICH [mm] 0,10 ICW [mm] 3,90 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1030 Cable type / seal SN 0,40 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,35 - 4,20 NONE Arrangement Nominal Insul. diam [mm] 1030 1,00 1030 2,00 2,65 3,88 Cable type code legend: 1030: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 11 of 19 SAE COPPER SN PVC, XLPE SPECIAL HEAVY Tear-out CCH force [N] [mm] 120 200 1,50 1,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,60 3,90 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,80 3,90 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1085 Cable type / seal SN 0,40 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,90 - 3,10 NONE Arrangement 1085 1,00 3,00 Cable type code legend: 1085: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 12 of 19 Nominal Insul. diam [mm] SAE COPPER SN TPE HEAVY Tear-out CCH force [N] [mm] 120 1,50 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,00 Tol ICH [mm] 0,10 ICW [mm] 3,70 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,40 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,90 - 3,15 NONE Arrangement Nominal Insul. diam [mm] 1094 1,00 3,03 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 13 of 19 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 120 1,50 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 3,80 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,40 1,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,90 - 3,15 NONE Arrangement Nominal Insul. diam [mm] 1094 1,00 3,03 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 14 of 19 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 120 1,50 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 3,80 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2005 Cable type / seal SN 0,40 1,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,20 - 2,60 NONE Arrangement 2005 1,50 Nominal Insul. diam [mm] 2,40 Cable type code legend: 2005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 15 of 19 FLR2X (SAAB C) ISO COPPER NONE PVC, TPE, XLPE THIN Tear-out CCH force [N] [mm] 160 1,60 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 3,70 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2006 Cable type / seal SN 0,40 1,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,70 - 3,35 NONE Arrangement Nominal Insul. diam [mm] 2006 1,50 3,03 Cable type code legend: 2006: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 16 of 19 ISO COPPER NONE EPR, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 160 1,60 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,20 Tol ICH [mm] 0,10 ICW [mm] 3,70 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 SN 0,40 1,00 | 1,50 | 2,00 | 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 3,00 NONE Arrangement 1,00 1,50 2,00 2,50 Nominal Insul. diam [mm] 1,95 2,20 2,46 2,80 Tear-out CCH force [N] [mm] 160 200 230 210 1,65 1,75 1,85 1,75 Tol CCH [mm] 0,05 0,05 0,05 0,05 CCW [mm] 2,55 2,55 2,65 3,00 Tol CCW [mm] 0,10 0,10 0,10 0,10 ICH [mm] 2,90 3,10 3,30 3,50 Tol ICH [mm] 0,10 0,10 0,10 0,10 ICW [mm] 3,60 3,65 3,70 3,80 Tol ICW [mm] 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-03-04 Page 17 of 19 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2039 Cable type / seal SN 0,40 1,25 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,76 - 1,92 NONE Arrangement Nominal Insul. diam [mm] 2039 1,25 1,84 Cable type code legend: 2039: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 18 of 19 ISO COPPER NONE PPE, PVC ULTRA THIN Tear-out CCH force [N] [mm] 135 1,45 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 2,90 Tol ICH [mm] 0,10 ICW [mm] 3,70 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12066614 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3002 Cable type / seal SN 0,40 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,00 - 3,40 NONE Arrangement Nominal Insul. diam [mm] 3002 2,00 3,20 Cable type code legend: 3002: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 19 of 19 JIS/JA COPPER NONE PVC, XLPVC REGULAR Tear-out CCH force [N] [mm] 180 1,60 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 3,40 Tol ICH [mm] 0,10 ICW [mm] 3,80 Tol ICW [mm] 0,10
12066614 价格&库存
很抱歉,暂时无法提供与“12066614”相匹配的价格&库存,您可以联系我们找货
    • 50+1.90810
    库存:450
    12066614
      • 1+0.76283
      • 30+0.73539
      • 100+0.68051
      • 500+0.62563
      • 1000+0.59819
        • 1+2.23740
        • 2000+1.67860
        • 4000+1.11870
        库存:8084
