13741954
13741954
    APTIV(安波福)
    Conn Terminal F Crimp ST Cable Mount
13741954 数据手册
GTS 1.5 SERIES BENEFITS • Stable contact force with high performing copper alloy • Best ratio of base material usage for a 1.5 mm female terminal in the market • High vibration performance in 2 and 3 Way housings (up to 42 G at 85 °C) FEATURES • Easy and smooth insertion through mat seals • Clean Body geometry without any sharp edges, preventing operator injury and wire damage • Wide range of crimping cable section gauges • Compatible with cable seals GTS 1.5 Female & Male Terminals AVAILABLE CONFIGURATIONS TECHNICAL CHARACTERISTICS Terminal Construction Two-piece Contact Resistance < 1.5 mΩ Locking Mechanism Tangless / Lanceless Contact Mating Force 120 N Wire Gage Range (AWG) 24 - 14 Center Line Spacing 3.5 mm Wire Gage Range (mm²) 0.22 - 2.0 Genders Female, Male Sealing Options Unsealed, Mat Sealed, Cable Sealed Plating Options Sn, Au Mating Tab Dimension (mm) 1.5 x 0.8 MAX TEMP MAX VIBRATION 150°C 42 G MAX CURRENT AT 23°C 27.5 A APPLICATIONS Engine compartment, ECU, sensors, actuators About Aptiv Aptiv is a global technology company that develops safer, greener and more connected solutions enabling the future of mobility. Visit aptiv.com aptiv.com | © 2021 Aptiv. All rights reserved See back page for representative part numbers and packaging dimensions. Sealing Gender Plating Wire size range (AWG) Wire size range (mm²) Part number Other available platings Unsealed F Sn 24 - 22 0.22 - 0.35 33510898 Au Unsealed F Sn 20 - 18 0.50 - 0.85 13648599 Au Unsealed F Sn 16 1.0 - 1.3 13741954 Au Unsealed F Sn 14 1.4 - 2.0 13749482 Au Unsealed M Sn 20 - 18 0.50 - 0.85 33510912 - Unsealed M Sn 16 1.0 - 1.3 33500741 - Unsealed M Sn 14 1.4 - 2.0 33510913 - Cable Sealed F Sn 20 - 18 0.50 - 0.85 29828026 Au Cable Sealed F Sn 16 1.0 - 1.3 13860784 Au Cable Sealed F Sn 14 1.4 - 2.0 13737773 Au COMPATIBLE SEALS Type Applicable wire size (mm2) Color Part number Cable Seal 0.50 - 0.85 Yellow 10736278 Cable Seal 1.0 - 2.0 Green 10736279 DERATING CURVE Mated to: 0.22 - 2.0 mm2 Standard Sn Single circuit in free air* GTS 1.5 male terminals * For reference only One terminal loaded, in housing wire-to-wire configuration 35 0.35 mm2 0.50 mm2 30 0.75 mm2 CURRENT (AMPERES) Cable range: Crimp method: Contact plating: Test method: 1.0 mm2 25 1.5 mm2 20 2.0 mm2 15 The test data was collected from single circuits in a draft free enclosure. This model does not account for all of the variables that would be present in an actual application. 10 5 0 0 10 20 30 40 50 60 70 80 ENVIRONMENTAL TEMPERATURE (°C) 90 100 110 120 130 For additional detailed product performance, visit our website at aptiv.com COMPATIBLE WITH CMC Connectors (32, 48, 64 & 86 Way) GTS SensoMate™ (2 & 3 Way) Part numbers, specifications, dimensions and performance data in this document are for general references only and are subject to change without notice. To verify product information, please contact an Aptiv representative. CS-SP114-GTS-En0221 aptiv.com | © 2021 Aptiv. All rights reserved
13741954 价格&库存
很抱歉,暂时无法提供与“13741954”相匹配的价格&库存,您可以联系我们找货
    • 1+0.44770
    • 11600+0.33550
    • 23200+0.22330
    库存:1160
