Metri-Pack Series
METRI-PACK SERIES
SE
AL
SE
AL
N
E
U
D
D
U
E
U
N
Available in device and in-line
connections for vehicle applications,
Metri-Pack 280 Series connectors can
meet or exceed the requirements for
E AL E D
S
S
S
E
AL E
D
280
connections for underhood vehicle
applications, Metri-Pack 280 Series sealed
connectors can meet or exceed the
most marine, appliance, and industrial
control applications.
requirements for most marine, appliance,
and industrial control applications.
Ideally suited for limited space
applications that do not require environ-
Utilizing triple-rib peripheral silicone
rubber seals, Metri-Pack 280 Series
mental protection, Metri-Pack 280 Series
products are extremely versatile.
sealed systems are ideally suited for
critical, low-energy electronic applications that require protection from
environmental hazards.
280 Metri-Pack Features
• Connector Position Assurance (CPA)
• Terminal Position Assurance (TPA)
• 30 Amps continuous maximum
current rating
• Small overall dimensions
• Low energy, low voltage capability
• Excellent resistance to temperature,
chemicals and abrasion
• Standard ISO 2.8mm configuration
• -40ºC to 125ºC temperature range
77
280
Metri-Pack Series
A
SE L
N
SE
E
U
D
D
U
E
U
N
AL
Cross Sectional View
Terminal
Terminal
TPA
Cable
Cable
TPA
TANGLESS
Female Connector
Male Connector
TPA
(Terminal Position
Assurance)
CPA
(Connector Position
Assurance)
Tangless Female
Terminal
TANGLESS
280 TANGLESS FEMALE TERMINALS UNSEALED
Part #
Cable Range (mm2)
Material
Plating
12129425
5.0
Tin Brass
Tin
12129663
3.0
Tin Brass
Tin
12129424
2.0-1.0
Tin Brass
Tin
12110842*
3.0-2.0
Tin Brass
Tin
12110844*
1.0-0.80
Tin Brass
Tin
12110843*
0.50-0.35
Tin Brass
Tin
12129061*
0.35 (2 Req’d.)
Tin Brass
Tin
Female Connector
*Thin Stock—Electrical current restrictions apply, contact your regional
support representative at the number listed below.
TANGLESS
280 FLEXLOCK FEMALE CONNECTORS UNSEALED
280 FEMALE TERMINALS UNSEALED
Part #
2
Cable Range (mm )
Material
Plating
12015858
5.0
Tin Brass
Tin
12129494
3.0-2.0
Tin Brass
Tin
12066214
2.0-1.0
Tin Brass
Tin
12034046
1.0-0.80
Tin Brass
Tin
12052217
0.50-0.35
Tin Brass
# Cavities
Connector
Color
Material
TPA
2
12129081
Black
PA66 HS IM
12129083
3
12129489
Black
PA66 HS IM
12129491
4
12129136
Black
PA66 HS IM
12129138
280 FEMALE CONNECTORS UNSEALED
Tin
# Cavities
Connector
Color
Material
TPA
12064752
Black
PA66 HS IM
12064753
12064998
Black
PBT
12064999
12162597*
3.0-2.0
Tin Brass
Tin
6
12162595*
1.0-0.80
Tin Brass
Tin
8
12162596*
0.50-0.35
Tin Brass
Tin
http://delphi.com/products/connect
78
North American Region
1-800-PACKARD
European Region
49-202-291-2000
Asia Pacific Region
65-730-9900
South American Region
55-12-378-2002
280
Metri-Pack Series
SE
AL
SE
AL
N
E
U
D
D
U
E
U
N
Unsealed System Application Information
280 SERIES TERMINALS – Tin Plated
TEMPERATURE
RISE ABOVE
o
AMBIENT (25 C) VS CURRENT*
CURRENT RANGE (AMPS):
TEMP RANGE OC:
RESISTANCE:
........ 0-30
.......... -40 to 125
很抱歉,暂时无法提供与“12040977”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+17.39206
- 25+16.84107
- 75+16.34997
- 200+15.69118
- 400+15.22404
- 国内价格
- 1+7.20940
- 550+5.40760
- 1100+3.60470
- 国内价格
- 1+4.49840
- 10+4.11718
- 30+4.04093
