15344866
15344866
    APTIV(安波福)
    Contact PIN Crimp ST Cable Mount
15344866 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15344866 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 2010 0,50 0,75 0,75 1,00 1,00 / / / / / SN 0,38 0,50 | 0,75 | 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 2,10 15324974 | 15324976 Arrangement 15324974 15324974 15324976 15324976 15324974 Nominal Insul. diam [mm] 1,50 1,75 1,75 1,95 1,95 Tear-out CCH force [N] [mm] 80 120 120 160 160 1,30 1,40 1,40 1,50 1,50 Tol CCH [mm] 0,05 0,05 0,05 0,05 0,05 CCW [mm] 2,05 2,10 2,10 2,10 2,10 Tol CCW [mm] 0,10 0,10 0,10 0,10 0,10 ICH [mm] 4,10 4,20 4,20 4,30 4,30 Tol ICH [mm] 0,10 0,10 0,10 0,10 0,10 ICW [mm] 4,15 4,15 4,15 4,20 4,20 Tol ICW [mm] 0,10 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2013-10-29 Page 1 of 1 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC
15344866 价格&库存
很抱歉,暂时无法提供与“15344866”相匹配的价格&库存,您可以联系我们找货
    • 1+1.09340
    • 2000+0.82060
    • 4000+0.54670
    库存:11808
    15344866
      • 100+2.63875
      • 1000+2.57407
      • 2500+2.51179
      • 5000+2.46028
      • 10000+2.40758
      库存:1000
