12064737
    APTIV(安波福)
12064737 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,38 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,00 - 3,25 15324994 Arrangement 1005 3,00 / 15324994 Nominal Insul. diam [mm] 3,13 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 1 of 11 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 250 2,05 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 6,20 Tol ICH [mm] 0,20 ICW [mm] 6,60 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,38 3,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 3,00 - 3,25 15324994 Arrangement 1005 3,00 / 15324994 Nominal Insul. diam [mm] 3,13 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 2 of 11 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 250 2,05 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 6,20 Tol ICH [mm] 0,20 ICW [mm] 6,60 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,38 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,45 - 3,81 15324994 Arrangement Nominal Insul. diam [mm] 1007 3,00 / 15324994 3,63 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 3 of 11 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 250 2,05 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 6,20 Tol ICH [mm] 0,20 ICW [mm] 6,60 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,38 3,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 3,45 - 3,81 15324994 Arrangement Nominal Insul. diam [mm] 1007 3,00 / 15324994 3,63 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 4 of 11 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 250 2,05 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 6,20 Tol ICH [mm] 0,20 ICW [mm] 6,60 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,38 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 4,00 - 4,25 15324996 Arrangement Nominal Insul. diam [mm] 1009 3,00 / 15324996 4,13 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 5 of 11 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 250 2,05 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 6,20 Tol ICH [mm] 0,20 ICW [mm] 6,60 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,38 3,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 4,00 - 4,25 15324996 Arrangement Nominal Insul. diam [mm] 1009 3,00 / 15324996 4,13 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 6 of 11 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 250 2,05 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 6,20 Tol ICH [mm] 0,20 ICW [mm] 6,60 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1043 Cable type / seal SN 0,38 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,40 - 3,81 15324994 Arrangement Nominal Insul. diam [mm] 1043 3,00 / 15324994 3,61 Cable type code legend: 1043: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 7 of 11 SAE STEEL NONE XLPE REGULAR Tear-out CCH force [N] [mm] 250 1,95 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 6,10 Tol ICH [mm] 0,20 ICW [mm] 6,60 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2005 Cable type / seal SN 0,38 2,50 | 4,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,70 - 3,80 12059258 Arrangement 2005 2,50 / 12059258 2005 4,00 / 12059258 Nominal Insul. diam [mm] 2,85 3,60 Cable type code legend: 2005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 8 of 11 FLR2X (SAAB C) ISO COPPER NONE PVC, TPE, XLPE THIN Tear-out CCH force [N] [mm] 359 368 1,95 2,05 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,60 3,65 Tol CCW [mm] 0,10 0,10 ICH [mm] 5,80 5,95 Tol ICH [mm] 0,10 0,10 ICW [mm] 6,70 6,90 Tol ICW [mm] 0,20 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 2,50 3,00 4,00 4,00 / / / / SN 0,38 2,50 | 3,00 | 4,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,60 - 3,70 15324994 | 12059258 Arrangement 15324994 15324994 15324994 12059258 Nominal Insul. diam [mm] 2,80 3,10 3,45 3,45 Tear-out CCH force [N] [mm] 225 300 265 357 1,85 2,10 2,05 2,05 Tol CCH [mm] 0,05 0,05 0,05 0,05 CCW [mm] 3,60 3,15 3,60 3,65 Tol CCW [mm] 0,10 0,10 0,10 0,10 ICH [mm] 6,00 6,10 6,25 5,95 Tol ICH [mm] 0,10 0,20 0,20 0,10 ICW [mm] 6,20 6,60 6,60 6,90 Tol ICW [mm] 0,20 0,20 0,20 0,20 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-03-04 Page 9 of 11 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2017 Cable type / seal SN 0,38 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,60 - 3,00 12059258 Arrangement 2017 2,50 / 12059258 Nominal Insul. diam [mm] 2,80 Cable type code legend: 2017: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 10 of 11 FLR41X-B, FLRY-A DIN COPPER SN PA, PP, PVC, XLPE THIN Tear-out CCH force [N] [mm] 331 1,95 Tol CCH [mm] 0,05 CCW [mm] 3,60 Tol CCW [mm] 0,10 ICH [mm] 5,80 Tol ICH [mm] 0,10 ICW [mm] 6,70 Tol ICW [mm] 0,20 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12064737 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 8000 Cable type / seal SN 0,38 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,70 - 3,00 15324994 Arrangement Nominal Insul. diam [mm] 8000 2,50 / 15324994 2,85 Cable type code legend: 8000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-03-04 Page 11 of 11 N/G COPPER NONE SYNTHRESIN THIN Tear-out CCH force [N] [mm] 225 1,85 Tol CCH [mm] 0,05 CCW [mm] 3,60 Tol CCW [mm] 0,10 ICH [mm] 6,00 Tol ICH [mm] 0,10 ICW [mm] 6,20 Tol ICW [mm] 0,20
12064737 价格&库存
很抱歉,暂时无法提供与“12064737”相匹配的价格&库存,您可以联系我们找货
    • 50+5.75990
    • 500+5.58703
    • 1250+5.41520
    • 2500+5.29961
    • 5000+5.18401
    库存:1150
