15363934
15363934
    APTIV(安波福)
    Contact SKT Crimp ST Cable Mount
15363934 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15363934 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 1,88 15324974 Arrangement 1005 0,50 / 15324974 Nominal Insul. diam [mm] 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 1 of 7 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 80 1,10 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15363934 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 2010 0,50 0,50 0,75 1,00 1,00 / / / / / SN 0,50 | 0,75 | 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 2,10 15324976 | 15324974 Arrangement 15324976 15324974 15324976 15324976 15324974 Nominal Insul. diam [mm] 1,50 1,50 1,75 1,95 1,95 Tear-out CCH force [N] [mm] 80 80 120 160 160 1,15 1,15 1,25 1,35 1,35 Tol CCH [mm] 0,05 0,05 0,05 0,05 0,05 CCW [mm] 1,90 1,90 1,90 1,95 1,95 Tol CCW [mm] 0,10 0,10 0,10 0,10 0,10 ICH [mm] 3,90 3,70 4,00 4,10 3,90 Tol ICH [mm] 0,10 0,10 0,10 0,10 0,10 ICW [mm] 4,05 4,05 4,05 4,05 4,05 Tol ICW [mm] 0,10 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 2 of 7 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15363934 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2023 Cable type / seal SN 0,75 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,20 - 2,50 15324973 Arrangement Nominal Insul. diam [mm] 2023 0,75 / 15324973 2,35 Cable type code legend: 2023: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 3 of 7 FL2G DIN COPPER SN SIL, SIR REGULAR Tear-out CCH force [N] [mm] 120 1,25 Tol CCH [mm] 0,05 CCW [mm] 1,90 Tol CCW [mm] 0,10 ICH [mm] 4,20 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15363934 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2044 Cable type / seal 2044 2044 2044 2044 0,50 0,75 1,00 1,40 / / / / SN 0,50 | 0,75 | 1,00 | 1,40 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 2,40 15324974 | 15324973 Arrangement 15324974 15324974 15324974 15324973 Nominal Insul. diam [mm] 1,50 1,78 1,96 2,30 Tear-out CCH force [N] [mm] 80 120 160 120 Cable type code legend: 2044: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 4 of 7 A3Z, F3Z, FL RENAULT A3Z NRA COPPER NONE XLPA/PVDF, XLPE, X-POLY ZH THIN 1,15 1,25 1,35 1,30 Tol CCH [mm] 0,05 0,05 0,05 0,05 CCW [mm] 1,90 1,90 1,95 2,25 Tol CCW [mm] 0,10 0,10 0,10 0,10 ICH [mm] 3,70 3,80 3,90 3,90 Tol ICH [mm] 0,10 0,10 0,10 0,10 ICW [mm] 4,05 4,05 4,05 4,20 Tol ICW [mm] 0,10 0,10 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15363934 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2055 Cable type / seal SN 0,50 | 0,75 | 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 2,10 15324974 Arrangement Nominal Insul. diam [mm] 2055 0,50 / 15324974 2055 0,75 / 15324974 2055 1,00 / 15324974 Tear-out CCH force [N] [mm] 1,50 1,70 1,93 Cable type code legend: 2055: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 5 of 7 AGP0119, RENAULT F3Z NRA COPPER NONE POLYOLEFIN THIN 80 120 160 1,15 1,25 1,35 Tol CCH [mm] 0,05 0,05 0,05 CCW [mm] 1,90 1,90 1,90 Tol CCW [mm] 0,10 0,10 0,10 ICH [mm] 3,80 3,90 4,00 Tol ICH [mm] 0,10 0,10 0,10 ICW [mm] 4,10 4,10 4,10 Tol ICW [mm] 0,10 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15363934 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2083 Cable type / seal SN 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,70 15324974 Arrangement Nominal Insul. diam [mm] 2083 0,50 / 15324974 1,55 Cable type code legend: 2083: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 6 of 7 ISO COPPER NONE PVC (YW) THIN Tear-out CCH force [N] [mm] 75 1,10 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15363934 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3004 Cable type / seal SN 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,50 - 1,70 15324974 Arrangement 3004 0,50 / 15324974 Nominal Insul. diam [mm] 1,60 Cable type code legend: 3004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 7 of 7 AVSS JIS/JA COPPER NONE PVC, XLPE, X-PVC THIN Tear-out CCH force [N] [mm] 75 1,05 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10
15363934 价格&库存
很抱歉,暂时无法提供与“15363934”相匹配的价格&库存,您可以联系我们找货
    • 100+0.91434
    • 1000+0.89559
    • 2500+0.86852
    • 5000+0.84769
    • 10000+0.82895
    库存:10000
