F965000
F965000
    APTIV(安波福)
    Connector Accessories Cover Housing Polybutylene Terephthalate Black
F965000 数据手册
CMC CONNECTORS CMC sealed Full interconnect 32, 48, 64 & 112 ways Features CMC (Connecteur Modulaire pour Calculateur) is one of the most popular interfaces for Engine Management Electronic Control Units Sealed connector for Electronic Control Unit applications Mat seal and circumferential interface seal Accepts reversible wire dress cover Right or left mountable rotating lever for mate assistance 32 ways 48 ways 64 ways 112 ways Suitable for harsh environment 15 g sinus vibration resistant with Tin terminals 1.5 Bar pressure proof sealing Typical application: Powertrain Electronic Control Units Technical characteristics Number of ways Sealing protection Terminals 32 ways 48 ways 64 ways 112 ways IPx9K/IP68 24 8 -40°C to +125°C > 100 N < 10 N < 60 N IPx9K/IP68 40 8 -40°C to +125°C > 100 N < 10 N < 60 N IPx9K/IP68 56 8 -40°C to +125°C > 100 N < 10 N < 60 N IPx9K/IP68 88 24 -40°C to +125°C > 100 N < 10 N < 60 N Female housings 4 4 3 1 Black left lever Black right lever Blue left lever Blue right lever Brown left lever Brown right lever Grey left lever Grey right lever Black Black Black F670000 (blue) PPI0001492 PPI0001493* PPI0001522* - 17464807 (black) PPI0001494 PPI0001495* F965000* - F932300 (black) PPI0001500 PPI0001501* PPI0001526* 1746B207M (black) PPI0001487 (32 w)* PPI0001488 (32 w) F765000 (48 w)* F865000 (48 w) PPI0001506 (32 w) PPI0001489 (32 w)* PPI0001522* F965000* - 0.64 mm GTS-1 1.50 mm GTS-2 Temperature range Terminal retention force Terminal insertion force Connector mating force Number of mechanical coding Part numbers Pin headers Female housings Cover 32 ways Cover 48 ways Cover 64 ways Other color codings available, please consult us. * Preferred parts CMC TERMINALS & TOOLING GTS Terminals 0.64 & 1.5 mm Features High performing one-piece terminal Lanceless version compatible with mat seal Temperature range -40 to +125°C Dual spring design with pre-loaded beam for enhanced contact force Low mating - unmating force GTS 0.64 mm Front protection of active beams GTS 1.5 mm Performance characteristics Terminal size Pitch Contact resistance Contact mating force Contact unmating force 0.64 mm GTS-1 1.5 mm GTS-2 2.2 mm < 5 mΩ
F965000 价格&库存
很抱歉,暂时无法提供与“F965000”相匹配的价格&库存,您可以联系我们找货
