10740367
10740367
    APTIV(安波福)
    APTIV / DELPHI - 10740367 - Automotive Connector Housing, SICMA 2.8 Series, Receptacle, 6 Ways
10740367 数据手册
SICMA INLINE SEALED SERIES BENEFITS • Clean body SICMA/BTS terminals are easily inserted in housing cavity • Tin, silver, gold plated terminals available FEATURES • Perfect solution for engine compartment at body mount, higly exposed to dirt and water • Reliable IP68 watertight 6 and 8 Way connector and IP67 for the 24 Way connector • 6 Way connector is equipped with a casing or holder for corrugated pipe by hinge principle SICMA Inline Sealed 6W Female & Male AVAILABLE CONFIGURATIONS Cavity Count (ways) 6, 8, 24 Cavity Configurations (mm) 1.5, 2.8 Centerline Spacing 2-rows 6W: 5 x 6 pitch 2-rows 8W: 4.25 x 6 pitch 3-rows 24W: 3.33 x 5 pitch Material PBT Genders Female, Male Sealing Type 6W, 8W – Cable Sealed 24W – Mat Sealed Terminal Position Assurance (TPA) Type PLR (Active Secondary Lock on 6W Female) Connector Position Assurance (CPA) No APPLICATIONS Exterior, chassis, engine compartment, inline, female mated to device About Aptiv Aptiv is a global technology company that develops safer, greener and more connected solutions enabling the future of mobility. Visit aptiv.com aptiv.com | © 2020 Aptiv. All rights reserved TEMPERATURE VIBRATION +125°C V1 CONNECTOR MATING FORCE -40°C SEALING PROTECTION < 60 N IP68 IP67 6, 8 Way 24 Way Corrugated pipe type is IPx9K guaranteed. See back page for representative part numbers and packaging dimensions. Cavity count Blade size (mm) 6 1.5 (SICMA 2&3 Plus) Gender Dimensions W x H x D (mm) Fixing type Part number F 35 x 40 x 17 N/A 10723553 M 30 x 65 x 21 Fixing grooves for panel cut-out 10752307 F 25 x 36x 31 N/A 13800077 M 25 x 27 x 50 Slot for fixing clip 13799643 F 50 x 34 x 33 N/A 33504115 M 50 x 44 x 33 Clip 15396451 or 33504091 15470023 M 59 x 44 x 38 Mount on Metal Panel 0.7 mm thick 33500427 1.5 (SICMA 2&3 Plus) 8 24 1.5 (18) + 2.8 (6) Color Indexes offered Black 2 Black 1 Black 3 ASSOCIATED PARTS Applicable Wire Size (mm) Color Part number Note SICMA 1.5 mm Cable Seal 1.25 - 1.90 Yellow 10736278 On 6 and 8 Way SICMA 1.5 mm Cable Seal 1.75 - 3.0 Green 10736279 On 6 and 8 Way Type DIMENSION MEASUREMENT SAMPLE EXPLODED VIEW Interface seal TPA TPA Female housing 13800077 13799643 13800077 Male housing 13799643 COMPATIBLE WITH SICMA 1.5 Series Terminals SICMA 2.8 Series Terminals BTS 1.5 and 2.8 Series Terminals SICMA Pin Header (24 Way) P/N 33501039 Part numbers, specifications, dimensions and performance data in this document are for general references only and are subject to change without notice. To verify product information, please contact an Aptiv representative. CS-SP137-SICMA-EN0720 aptiv.com | © 2020 Aptiv. All rights reserved
10740367 价格&库存
很抱歉,暂时无法提供与“10740367”相匹配的价格&库存,您可以联系我们找货
