12084200
12084200
    APTIV(安波福)
    胶壳端子 20-22AWG
12084200 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1002 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 1,95 15324976 Arrangement 1002 0,50 / 15324976 Nominal Insul. diam [mm] 1,78 Tear-out CCH force [N] [mm] 80 0,95 Cable type code legend: 1002: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 1 of 52 SAE COPPER NONE ECTFE, ETFE, PBT, PTFE, PUR, TFE THIN Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,88 15324976 | 15324974 Arrangement 1005 0,35 / 15324974 1005 0,50 / 15324976 Nominal Insul. diam [mm] 1,60 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 2 of 52 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 55 80 0,90 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,60 3,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,25 0,35 (SR) SOLDER - REFLOW [LOW IMPEDANCE (SIR) CIRCUIT] 1,45 - 1,75 15324974 Arrangement 1005 0,35 / 15324974 Nominal Insul. diam [mm] 1,60 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 3 of 52 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 55 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 1,60 - 1,88 15324976 Arrangement 1005 0,50 / 15324976 Nominal Insul. diam [mm] 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 4 of 52 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 2,30 15324973 | 15324976 Arrangement Nominal Insul. diam [mm] 1007 0,35 / 15324976 1007 0,50 / 15324973 1,95 2,15 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 5 of 52 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 55 80 0,90 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,60 3,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,25 0,35 (SR) SOLDER - REFLOW [LOW IMPEDANCE (SIR) CIRCUIT] 1,80 - 2,10 15324976 Arrangement Nominal Insul. diam [mm] 1007 0,35 / 15324976 1,95 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 6 of 52 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 55 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,00 - 2,30 15324973 Arrangement Nominal Insul. diam [mm] 1007 0,50 / 15324973 2,15 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 7 of 52 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,25 0,50 | 0,51 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,30 - 2,60 15324973 Arrangement Nominal Insul. diam [mm] 1009 0,50 / 15324973 1009 0,51 / 15324973 2,45 2,45 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 8 of 52 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 80 80 0,95 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,70 3,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,30 - 2,60 15324973 Arrangement Nominal Insul. diam [mm] 1009 0,50 / 15324973 2,45 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 9 of 52 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,65 - 2,90 15324973 Arrangement Nominal Insul. diam [mm] 1011 0,50 / 15324973 2,78 Tear-out CCH force [N] [mm] 80 0,95 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 10 of 52 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,65 - 2,90 15324973 Arrangement Nominal Insul. diam [mm] 1011 0,50 / 15324973 2,78 Tear-out CCH force [N] [mm] 80 0,95 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 11 of 52 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1023 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,05 - 1,35 15324974 Arrangement Nominal Insul. diam [mm] 1023 0,35 / 15324974 1,20 Tear-out CCH force [N] [mm] 60 Cable type code legend: 1023: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 12 of 52 SAE COPPER SN ECTFE, ETFE, PTFE, PUR, TFE ULTRA THIN 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1025 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,47 - 1,85 15324974 | 15324976 Arrangement 1025 0,35 / 15324974 1025 0,50 / 15324976 Nominal Insul. diam [mm] 1,55 1,73 Tear-out CCH force [N] [mm] 55 80 0,90 0,90 Tol CCH [mm] 0,05 0,05 Cable type code legend: 1025: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 13 of 52 SAE COPPER SN FLUORPOLYM, HDPE, PBT, PE, PVC, XLPE THIN CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,60 3,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1026 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324973 Arrangement Nominal Insul. diam [mm] 1026 0,50 / 15324973 2,15 Cable type code legend: 1026: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 14 of 52 SAE COPPER SN HDPE, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1027 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,30 - 2,60 15324973 Arrangement Nominal Insul. diam [mm] 1027 0,50 / 15324973 2,45 Cable type code legend: 1027: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 15 of 52 SAE COPPER SN PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1035 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324979 Arrangement Nominal Insul. diam [mm] 1035 0,50 / 15324979 2,15 Cable type code legend: 1035: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 16 of 52 SAE COPPER NONE XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,10 Tol CCH [mm] 0,05 CCW [mm] 1,85 Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1045 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,75 15324974 Arrangement 1045 0,35 / 15324974 Nominal Insul. diam [mm] 1,58 Tear-out CCH force [N] [mm] 70 Cable type code legend: 1045: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 17 of 52 SAE COPPER NONE ECTFE, ETFE, PTFE, PUR, TFE THIN 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1047 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,75 15324974 Arrangement Nominal Insul. diam [mm] 1047 0,35 / 15324974 1,58 Cable type code legend: 1047: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 18 of 52 SAE COPPER NONE PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1047 Cable type / seal SN 0,25 0,35 (SR) SOLDER - REFLOW [LOW IMPEDANCE (SIR) CIRCUIT] 1,40 - 1,75 15324974 Arrangement Nominal Insul. diam [mm] 1047 0,35 / 15324974 1,58 Cable type code legend: 1047: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 19 of 52 SAE COPPER NONE PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1048 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 2,10 15324976 Arrangement Nominal Insul. diam [mm] 1048 0,35 / 15324976 1,95 Cable type code legend: 1048: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 20 of 52 SAE COPPER NONE PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 70 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1055 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,75 15324974 Arrangement 1055 0,35 / 15324974 Nominal Insul. diam [mm] 1,60 Cable type code legend: 1055: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 21 of 52 SAE COPPER SN HDPE, PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1056 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,75 15324974 Arrangement 1056 0,35 / 15324974 Nominal Insul. diam [mm] 1,60 Cable type code legend: 1056: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 22 of 52 SAE COPPER NI FLUORPOLYM, PTFE THIN Tear-out CCH force [N] [mm] 60 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,50 Tol ICH [mm] 0,10 ICW [mm] 3,90 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1058 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 1,85 15324976 Arrangement 1058 0,50 / 15324976 1,73 Cable type code legend: 1058: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 23 of 52 Nominal Insul. diam [mm] SAE COPPER NI XLPE THIN Tear-out CCH force [N] [mm] 80 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1059 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324973 Arrangement Nominal Insul. diam [mm] 1059 0,50 / 15324973 2,15 Cable type code legend: 1059: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 24 of 52 SAE COPPER NI XLPE REGULAR Tear-out CCH force [N] [mm] 80 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1066 Cable type / seal SN 0,25 0,80 | 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 0,00 - 0,00 12124669 Arrangement 1066 0,80 / 12124669 1066 1,00 / 12124669 0,00 0,00 Cable type code legend: 1066: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 25 of 52 Nominal Insul. diam [mm] SAE COPPER SN NONE NONE Tear-out CCH force [N] [mm] 90 120 1,05 1,30 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,85 1,85 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,80 3,80 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,00 4,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1092 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324979 Arrangement Nominal Insul. diam [mm] 1092 0,50 / 15324979 2,15 Cable type code legend: 1092: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 26 of 52 SAE ALLOY NONE XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,10 Tol CCH [mm] 0,05 CCW [mm] 1,85 Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,35 - 2,50 15324973 Arrangement Nominal Insul. diam [mm] 1094 0,50 / 15324973 2,43 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 27 of 52 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,35 - 2,50 15324973 Arrangement Nominal Insul. diam [mm] 1094 0,50 / 15324973 2,43 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 28 of 52 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1106 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,20 15324979 Arrangement Nominal Insul. diam [mm] 1106 0,50 / 15324979 2,10 Cable type code legend: 1106: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 29 of 52 SAE ALLOY NONE XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,10 Tol CCH [mm] 0,05 CCW [mm] 1,85 Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2005 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,95 15324976 Arrangement 2005 0,50 / 15324976 Nominal Insul. diam [mm] 1,68 Cable type code legend: 2005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 30 of 52 FLR2X (SAAB C) ISO COPPER NONE PVC, TPE, XLPE THIN Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 2010 0,35 0,50 0,50 0,50 0,75 / / / / / SN 0,25 0,35 | 0,50 | 0,75 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,20 - 1,90 15324974 | 12089442 | 10737671 Arrangement 15324974 15324974 12089442 10737671 15324974 Nominal Insul. diam [mm] 1,34 1,50 1,50 1,50 1,75 Tear-out CCH force [N] [mm] 50 80 80 80 120 1,00 1,10 1,10 1,10 1,20 Tol CCH [mm] 0,05 0,05 0,05 0,05 0,05 CCW [mm] 1,55 1,60 1,60 1,60 1,60 Tol CCW [mm] 0,10 0,10 0,10 0,10 0,10 ICH [mm] 3,70 3,80 3,80 3,10 3,90 Tol ICH [mm] 0,10 0,10 0,10 0,10 0,10 ICW [mm] 4,10 4,10 4,10 4,10 4,15 Tol ICW [mm] 0,10 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 31 of 52 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2011 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,79 - 2,30 15393249 | 12052924 Arrangement Nominal Insul. diam [mm] 2011 0,35 / 15393249 2011 0,50 / 12052924 1,95 2,15 Tear-out CCH force [N] [mm] 55 101 0,90 0,95 Cable type code legend: 2011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 32 of 52 FL33X, FLK, FLY, FLYKW, IH WIRE DIN COPPER NONE P/EST, PE, PVC, XLPE REGULAR Tol CCH [mm] 0,05 0,05 CCW [mm] 1,85 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,60 3,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2013 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 1,90 15324976 Arrangement 2013 0,50 / 15324976 Nominal Insul. diam [mm] 1,85 Tear-out CCH force [N] [mm] 80 1,00 Tol CCH [mm] 0,05 CCW [mm] Cable type code legend: 2013: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 33 of 52 DIN COPPER NONE PUR, PVC, SYNTHRESIN, XLPE, XLPE/PVDF THIN 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2013 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 1,80 - 1,90 15324976 Arrangement 2013 0,50 / 15324976 Nominal Insul. diam [mm] 1,85 Tear-out CCH force [N] [mm] 80 1,00 Tol CCH [mm] 0,05 CCW [mm] Cable type code legend: 2013: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 34 of 52 DIN COPPER NONE PUR, PVC, SYNTHRESIN, XLPE, XLPE/PVDF THIN 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2016 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 0,75 - 1,00 15324974 Arrangement Nominal Insul. diam [mm] 2016 0,50 / 15324974 0,88 Cable type code legend: 2016: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 35 of 52 DIN-CORE DIN COPPER SN NONE NONE Tear-out CCH force [N] [mm] 75 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,50 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2017 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 1,70 15324974 Arrangement 2017 0,50 / 15324974 Nominal Insul. diam [mm] 1,50 Cable type code legend: 2017: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 36 of 52 FLR41X-B, FLRY-A DIN COPPER SN PA, PP, PVC, XLPE THIN Tear-out CCH force [N] [mm] 80 1,10 Tol CCH [mm] 0,05 CCW [mm] 1,60 Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2019 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 1,70 15324976 Arrangement 2019 0,50 / 15324976 Nominal Insul. diam [mm] 1,50 Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Cable type code legend: 2019: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 37 of 52 FL7Y 179, FLR7Y, FLR7Y-A, FLR7Y-B, FLU7Y DIN COPPER SN ETFE THIN Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2044 Cable type / seal 2044 2044 2044 2044 2044 2044 0,35 0,50 0,50 0,50 0,60 0,75 / / / / / / SN 0,25 0,35 | 0,50 | 0,60 | 0,75 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,25 - 1,90 10737671 | 15324974 | 15344953 Arrangement 15344953 10737671 15324974 15344953 15344953 15344953 Nominal Insul. diam [mm] 1,33 1,50 1,50 1,50 1,80 1,78 Tear-out CCH force [N] [mm] 50 80 80 80 90 120 Cable type code legend: 2044: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 38 of 52 A3Z, F3Z, FL RENAULT A3Z NRA COPPER NONE XLPA/PVDF, XLPE, X-POLY ZH THIN 1,00 1,10 1,10 1,10 1,15 1,20 Tol CCH [mm] 0,05 0,05 0,05 0,05 0,05 0,05 CCW [mm] 1,55 1,60 1,60 1,60 1,60 1,60 Tol CCW [mm] 0,10 0,10 0,10 0,10 0,10 0,10 ICH [mm] 3,70 3,20 3,80 3,80 3,90 4,00 Tol ICH [mm] 0,10 0,10 0,10 0,10 0,10 0,10 ICW [mm] 4,10 4,10 4,10 4,10 4,15 4,15 Tol ICW [mm] 0,10 0,10 0,10 0,10 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2050 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324974 Arrangement Nominal Insul. diam [mm] 2050 0,50 / 15324974 2,15 Cable type code legend: 2050: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 39 of 52 DIN COPPER SN EVA REGULAR Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2051 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 1,40 15324974 Arrangement Nominal Insul. diam [mm] 2051 0,50 / 15324974 1,35 Cable type code legend: 2051: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 40 of 52 FLU7Y-A ISO COPPER NONE ETFE ULTRA THIN Tear-out CCH force [N] [mm] 75 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,40 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2053 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,60 15327786 | 10737671 Arrangement 2053 0,50 / 15327786 2053 0,50 / 10737671 Nominal Insul. diam [mm] 1,50 1,50 Tear-out CCH force [N] [mm] 70 70 1,00 1,00 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,70 1,70 Cable type code legend: 2053: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 41 of 52 PSA T2 ZH ID, PSA T3 ZH ID, PSA T4 ZH ID PSA COPPER NONE POLYOLEFIN, X-POLY ID Tol CCW [mm] 0,10 0,10 ICH [mm] 2,90 2,90 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,05 4,05 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2054 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,70 15324974 Arrangement 2054 0,50 / 15324974 Nominal Insul. diam [mm] 1,55 Tear-out CCH force [N] [mm] 70 1,00 Tol CCH [mm] 0,05 CCW [mm] 1,70 Tol CCW [mm] 0,10 Cable type code legend: 2054: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 42 of 52 PSA T2 IR, PSA T3 IR, PSA T3 ZH IR, PSA T4 LH IR PSA COPPER NONE POLYOLEFIN, PVC, X-POLY IR ICH [mm] 3,30 Tol ICH [mm] 0,10 ICW [mm] 4,15 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2055 Cable type / seal SN 0,25 0,75 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 1,80 15344953 Arrangement Nominal Insul. diam [mm] 2055 0,75 / 15344953 Tear-out CCH force [N] [mm] 1,70 Cable type code legend: 2055: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 43 of 52 AGP0119, RENAULT F3Z NRA COPPER NONE POLYOLEFIN THIN 120 1,20 Tol CCH [mm] 0,05 CCW [mm] 1,60 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 4,15 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2083 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,20 - 1,70 15324974 Arrangement Nominal Insul. diam [mm] 2083 0,35 / 15324974 2083 0,50 / 15324974 1,30 1,55 Cable type code legend: 2083: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 44 of 52 ISO COPPER NONE PVC (YW) THIN Tear-out CCH force [N] [mm] 55 80 0,90 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,85 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,60 3,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3000 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,40 - 2,50 15324976 Arrangement Nominal Insul. diam [mm] 3000 0,50 / 15324976 2,45 Cable type code legend: 3000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 45 of 52 AV JIS/JA COPPER NONE PVC REGULAR Tear-out CCH force [N] [mm] 80 1,05 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3004 Cable type / seal 3004 3004 3004 3004 3004 0,30 0,30 0,50 0,50 0,50 / / / / / SN 0,25 0,30 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 1,70 15324976 | 15324974 | 12052925 Arrangement 15324974 15324976 15324976 15324974 12052925 Nominal Insul. diam [mm] 1,40 1,40 1,60 1,60 1,60 Cable type code legend: 3004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 46 of 52 AVSS JIS/JA COPPER NONE PVC, XLPE, X-PVC THIN Tear-out CCH force [N] [mm] 50 50 75 75 75 0,90 0,90 0,95 0,95 0,95 Tol CCH [mm] 0,05 0,05 0,05 0,05 0,05 CCW [mm] 1,80 1,80 1,80 1,80 1,80 Tol CCW [mm] 0,10 0,10 0,10 0,10 0,10 ICH [mm] 3,50 3,20 3,70 3,40 3,50 Tol ICH [mm] 0,10 0,10 0,10 0,10 0,10 ICW [mm] 4,10 4,00 4,10 4,00 4,10 Tol ICW [mm] 0,10 0,10 0,10 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3004 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 1,50 - 1,70 15324974 Arrangement 3004 0,50 / 15324974 Nominal Insul. diam [mm] 1,60 Cable type code legend: 3004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 47 of 52 AVSS JIS/JA COPPER NONE PVC, XLPE, X-PVC THIN Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3022 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 2,20 15324973 Arrangement Nominal Insul. diam [mm] 3022 0,50 / 15324973 2,00 Cable type code legend: 3022: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 48 of 52 JIS/JA COPPER NONE XLPE REGULAR Tear-out CCH force [N] [mm] 75 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,60 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3024 Cable type / seal SN 0,25 0,30 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 0,70 - 0,70 15324974 Arrangement 3024 0,30 / 15324974 0,70 Cable type code legend: 3024: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 49 of 52 Nominal Insul. diam [mm] JIS/JA COPPER SN NONE NONE Tear-out CCH force [N] [mm] 50 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,50 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 8000 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,20 - 1,60 15324974 | 15324976 Arrangement Nominal Insul. diam [mm] 8000 0,35 / 15324974 8000 0,50 / 15324976 1,30 1,50 Cable type code legend: 8000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 50 of 52 N/G COPPER NONE SYNTHRESIN THIN Tear-out CCH force [N] [mm] 55 80 0,90 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,85 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,60 3,80 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 9000 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,90 - 2,05 15324973 Arrangement 9000 0,50 / 15324973 1,98 Cable type code legend: 9000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 51 of 52 Nominal Insul. diam [mm] MISC COPPER NONE PVDF MIX Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12084200 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 9003 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,92 - 2,06 15324973 Arrangement 9003 0,50 / 15324973 1,99 Cable type code legend: 9003: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 52 of 52 Nominal Insul. diam [mm] N/G COPPER SN PVDF MIX Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10
12084200 价格&库存
很抱歉,暂时无法提供与“12084200”相匹配的价格&库存,您可以联系我们找货
  • 135000+0.21303135000+0.02756
库存:210000
12084200
    • 1+0.26520
    • 1000+0.25200
    • 3000+0.24250
    库存:6995
    12084200
      • 1+0.24948
      库存:640
      12084200
        • 10+0.35045
        • 100+0.32693
        • 500+0.30341
        • 2000+0.27989
        • 5000+0.26342
        • 10000+0.25637
        库存:200
