12129373
12129373
    APTIV(安波福)
    Contact SKT Crimp ST Cable Mount
12129373 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1002 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 1,95 NONE Arrangement 1002 0,50 Nominal Insul. diam [mm] 1,78 Tear-out CCH force [N] [mm] 80 0,95 Cable type code legend: 1002: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 1 of 22 SAE COPPER NONE ECTFE, ETFE, PBT, PTFE, PUR, TFE THIN Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,00 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1004 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,05 - 1,40 NONE Arrangement Nominal Insul. diam [mm] 1004 0,35 1004 0,50 1,20 1,25 Cable type code legend: 1004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 2 of 22 SAE COPPER NONE PVC ULTRA THIN Tear-out CCH force [N] [mm] 55 80 0,85 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 1,80 2,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 2,50 2,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,88 NONE Arrangement 1005 0,35 1005 0,50 Nominal Insul. diam [mm] 1,60 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 3 of 22 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 55 80 0,85 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 2,00 2,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 2,50 2,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,25 0,50 (SR) SOLDER - REFLOW [LOW IMPEDANCE (SIR) CIRCUIT] 1,60 - 1,88 NONE Arrangement 1005 0,50 Nominal Insul. diam [mm] 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 4 of 22 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,00 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,25 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 1,60 - 1,88 NONE Arrangement 1005 0,50 Nominal Insul. diam [mm] 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 5 of 22 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,00 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 2,30 NONE Arrangement Nominal Insul. diam [mm] 1007 0,35 1007 0,50 1,95 2,15 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 6 of 22 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 55 80 0,85 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 2,00 2,10 Tol ICH [mm] 0,10 0,10 ICW [mm] 2,50 2,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1025 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,47 - 1,85 NONE Arrangement 1025 0,35 1025 0,50 Nominal Insul. diam [mm] 1,55 1,73 Tear-out CCH force [N] [mm] 55 80 0,85 0,90 Tol CCH [mm] 0,05 0,05 Cable type code legend: 1025: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 7 of 22 SAE COPPER SN FLUORPOLYM, HDPE, PBT, PE, PVC, XLPE THIN CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 2,00 1,90 Tol ICH [mm] 0,10 0,10 ICW [mm] 2,50 2,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1046 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,05 - 1,35 NONE Arrangement Nominal Insul. diam [mm] 1046 0,35 1,20 Cable type code legend: 1046: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 8 of 22 SAE COPPER NONE PVC, XLPE ULTRA THIN Tear-out CCH force [N] [mm] 70 0,85 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 1,80 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1047 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,75 NONE Arrangement Nominal Insul. diam [mm] 1047 0,35 1,58 Cable type code legend: 1047: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 9 of 22 SAE COPPER NONE PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 0,85 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,00 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1047 Cable type / seal SN 0,25 0,35 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 1,40 - 1,75 NONE Arrangement Nominal Insul. diam [mm] 1047 0,35 1,58 Cable type code legend: 1047: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 10 of 22 SAE COPPER NONE PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 0,85 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,00 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1055 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,75 NONE Arrangement 1055 0,35 Nominal Insul. diam [mm] 1,60 Cable type code legend: 1055: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 11 of 22 SAE COPPER SN HDPE, PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 0,85 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,00 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal SN 0,25 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,20 - 1,70 NONE Arrangement 2010 0,35 2010 0,50 Nominal Insul. diam [mm] 1,34 1,50 Tear-out CCH force [N] [mm] 50 80 1,00 1,10 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,55 1,60 Tol CCW [mm] 0,10 0,10 ICH [mm] 1,90 2,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 2,10 2,15 Tol ICW [mm] 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 12 of 22 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal SN 0,25 0,35 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 1,20 - 1,48 NONE Arrangement 2010 0,35 Nominal Insul. diam [mm] 1,34 Tear-out CCH force [N] [mm] 55 0,85 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 1,80 Tol ICH [mm] 0,10 ICW [mm] 2,40 Tol ICW [mm] 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 13 of 22 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Seal(s): 2010 + 2010 Cable type / seal SN 0,25 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY NONE Arrangement 2010 0,35 + 2010 0,35 Nominal Insul. diam [mm] 1,34 + 1,34 Tear-out CCH force [N] [mm] 50 1,00 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,30 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 14 of 22 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2039 Cable type / seal SN 0,25 0,35 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 1,03 - 1,24 NONE Arrangement Nominal Insul. diam [mm] 2039 0,35 1,14 Cable type code legend: 2039: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 15 of 22 ISO COPPER NONE PPE, PVC ULTRA THIN Tear-out CCH force [N] [mm] 50 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 1,90 Tol ICH [mm] 0,10 ICW [mm] 2,40 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2046 Cable type / seal SN 0,25 0,13 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 0,81 - 0,95 NONE Arrangement Nominal Insul. diam [mm] 2046 0,13 0,88 Cable type code legend: 2046: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 16 of 22 CHFUS, FLMU142Y ISO ALLOY - DP NONE PPE, PVC ULTRA THIN Tear-out CCH force [N] [mm] 50 0,90 Tol CCH [mm] 0,05 CCW [mm] 1,55 Tol CCW [mm] 0,10 ICH [mm] 1,80 Tol ICH [mm] 0,10 ICW [mm] 2,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Seal(s): 2046 + 2010 Cable type / seal SN 0,25 0,13 | 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY NONE Arrangement Nominal Insul. diam [mm] 2046 0,13 + 2010 0,35 0,88 + 1,34 Tear-out CCH force [N] [mm] 50 1,03 Tol CCH [mm] 0,05 CCW [mm] 1,60 Tol CCW [mm] 0,10 ICH [mm] 2,40 Tol ICH [mm] 0,10 ICW [mm] 2,20 Tol ICW [mm] 0,10 Cable type code legend: 2046: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: 2010: CHFUS, FLMU142Y ISO ALLOY - DP NONE PPE, PVC ULTRA THIN ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 17 of 22 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Seal(s): 2046 + 2046 Cable type / seal SN 0,25 0,13 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY NONE Arrangement Nominal Insul. diam [mm] 2046 0,13 + 2046 0,13 0,88 + 0,88 Cable type code legend: 2046: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 18 of 22 CHFUS, FLMU142Y ISO ALLOY - DP NONE PPE, PVC ULTRA THIN Tear-out CCH force [N] [mm] 50 0,87 Tol CCH [mm] 0,05 CCW [mm] 1,50 Tol CCW [mm] 0,10 ICH [mm] 1,90 Tol ICH [mm] 0,10 ICW [mm] 2,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2085 Cable type / seal SN 0,25 0,13 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 0,95 - 1,05 NONE Arrangement Nominal Insul. diam [mm] 2085 0,13 1,00 Cable type code legend: 2085: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 19 of 22 DIN ALLOY - DP NONE PVC THIN Tear-out CCH force [N] [mm] 50 0,87 Tol CCH [mm] 0,05 CCW [mm] 1,50 Tol CCW [mm] 0,10 ICH [mm] 1,60 Tol ICH [mm] 0,10 ICW [mm] 2,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3004 Cable type / seal SN 0,25 0,30 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 1,70 NONE Arrangement 3004 0,30 3004 0,50 Nominal Insul. diam [mm] 1,40 1,60 Cable type code legend: 3004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 20 of 22 AVSS JIS/JA COPPER NONE PVC, XLPE, X-PVC THIN Tear-out CCH force [N] [mm] 50 80 0,85 0,95 Tol CCH [mm] 0,05 0,05 CCW [mm] 1,80 1,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 1,90 2,10 Tol ICH [mm] 0,10 0,10 ICW [mm] 2,50 2,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3004 Cable type / seal SN 0,25 0,50 (SR) SOLDER - REFLOW [LOW IMPEDANCE (SIR) CIRCUIT] 1,50 - 1,70 NONE Arrangement 3004 0,50 Nominal Insul. diam [mm] 1,60 Cable type code legend: 3004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 21 of 22 AVSS JIS/JA COPPER NONE PVC, XLPE, X-PVC THIN Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 2,10 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129373 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 8000 Cable type / seal SN 0,25 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,60 NONE Arrangement Nominal Insul. diam [mm] 8000 0,50 1,50 Cable type code legend: 8000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 22 of 22 N/G COPPER NONE SYNTHRESIN THIN Tear-out CCH force [N] [mm] 80 0,95 Tol CCH [mm] 0,05 CCW [mm] 1,80 Tol CCW [mm] 0,10 ICH [mm] 1,90 Tol ICH [mm] 0,10 ICW [mm] 2,50 Tol ICW [mm] 0,10
12129373 价格&库存
很抱歉,暂时无法提供与“12129373”相匹配的价格&库存,您可以联系我们找货
    • 1+0.44000
    • 1000+0.33000
    • 5000+0.23650
    库存:1
    12129373
      • 100+0.69981
      • 1200+0.68523
      • 2300+0.67066
      库存:200
