13602481
13602481
    APTIV(安波福)
    APTIV / DELPHI - 13602481 - Automotive Connector Contact, SICMA 1.5 Series, Socket, Crimp
13602481 数据手册
SICMA 1.5 SERIES BENEFITS • Optimized design to keep stable contact pressure • Standard terminal cavity compatibility FEATURES • Clean body design, preventing tearing of mat seal • One-piece construction with high pressure contact • Several crimping gauges for strong slow motion and vibration performance SICMA 1.5 Female & Male Terminals AVAILABLE CONFIGURATIONS TECHNICAL CHARACTERISTICS Terminal Construction One-piece Contact Resistance < 4 mΩ Locking Mechanism Tangless / Lanceless Contact Mating Force 0.8 N Mating Cycles 10 / 20 (Au) Blade Size (mm) 1.5 Cavity Pullout Force 120 N Wire Gage Range (AWG) 26 - 14 Center Line Spacing 3.33 mm (Unsealed) 4.25 mm (Sealed) Wire Gage Range (mm²) 0.13 - 2.0 Genders Female, Male Sealing Options Unsealed, Mat Sealed, Cable Sealed Plating Options Sn, Au, Ag (only for Male) Mating Tab Dimension (mm) 1.5 x 0.8 See back page for representative part numbers and packaging dimensions. About Aptiv Aptiv is a global technology company that develops safer, greener and more connected solutions enabling the future of mobility. Visit aptiv.com aptiv.com | © 2021 Aptiv. All rights reserved MAX TEMP MAX VIBRATION 125°C 25 G MAX CURRENT AT 23°C 26 A Sealing Gender Plating Wire size range (AWG) Wire size range (mm²) Part number Other available platings Unsealed F Sn 26 - 24 0.13 - 0.22 33308333 Au Unsealed F Sn 24 0.22 13625048 Au Unsealed F Sn 22 - 18 0.35 - 0.70 10863984 Au Unsealed F Sn 18 - 16 0.75 - 1.30 10865152 Au Unsealed F Sn 16 - 14 1.35 - 2.0 10863985 Au Unsealed M Sn 26 - 24 0.13 - 0.22 33400435 Ag Unsealed M Sn 22 - 18 0.35 - 0.70 33501792 Au, Ag Unsealed M Sn 18 - 16 0.75 - 1.30 33512109 Ag Unsealed M Sn 16 - 14 1.35 - 2.0 33512190 Ag Cable Sealed F Sn 22 - 18 0.35 - 0.70 13761154 Au Cable Sealed F Sn 18 - 16 0.75 - 1.30 13761651 Au Cable Sealed F Sn 16 - 14 1.35 - 2.0 13731648 Au Cable Sealed M Sn 22 - 18 0.35 - 0.70 35174381 Ag Cable Sealed M Sn 18 - 16 0.75 - 1.30 35174382 Ag Cable Sealed M Sn 16 - 14 1.35 - 2.0 35174383 Ag COMPATIBLE SEALS Type Applicable wire size (mm2) Color Part number Cable Seal 0.5 - 0.75 Yellow 10736278 Cable Seal 1.0 - 2.0 Green 10736279 DERATING CURVE Mated to: 0.35 - 2.0 mm2 Standard Sn Single circuit in free air* SICMA Male Tab * For reference only 30 25 CURRENT (AMPERES) Cable range: Crimp method: Contact plating: Test method: 0.35 mm2 1.0 mm2 0.50 mm 2 1.5 mm2 2 2.0 mm2 0.75 mm 20 15 The test data was collected from single circuits in a draft free enclosure. This model does not account for all of the variables that would be present in an actual application. 10 5 0 0 10 20 30 40 50 60 70 80 90 100 110 ENVIRONMENTAL TEMPERATURE (°C) 120 130 For additional detailed product performance, visit our website at aptiv.com COMPATIBLE WITH SICMA HOUSINGS SICMA Inline Sealed Series SICMA Inline Unsealed Series SICMA Headers Interconnect Sealed Series SICMA Mini-Sealed Series SICMA Panel-Through Sealed Series SICMA Panel-Through Unsealed Series SICMA SensoMate™ Series On-Board Diagnostic (OBD) Series Part numbers, specifications, dimensions and performance data in this document are for general references only and are subject to change without notice. To verify product information, please contact an Aptiv representative. CS-SP59-SICMA-En0221 aptiv.com | © 2021 Aptiv. All rights reserved
13602481 价格&库存
很抱歉,暂时无法提供与“13602481”相匹配的价格&库存,您可以联系我们找货
