12129497
12129497
    APTIV(安波福)
12129497 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,38 2,00 | 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,45 - 3,25 15324982 | 15324980 Arrangement 1005 2,00 / 15324982 1005 3,00 / 15324980 Nominal Insul. diam [mm] 2,58 3,13 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 1 of 17 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 200 250 1,65 1,90 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,30 3,35 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,70 5,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,60 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,38 3,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 3,00 - 3,25 15324980 Arrangement 1005 3,00 / 15324980 Nominal Insul. diam [mm] 3,13 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 2 of 17 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 250 1,90 Tol CCH [mm] 0,05 CCW [mm] 3,35 Tol CCW [mm] 0,10 ICH [mm] 5,00 Tol ICH [mm] 0,10 ICW [mm] 4,60 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,38 2,00 | 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,85 - 3,81 15324980 | 15324981 Arrangement Nominal Insul. diam [mm] 1007 2,00 / 15324980 1007 3,00 / 15324981 2,98 3,63 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 3 of 17 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 200 250 1,65 1,90 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,30 3,35 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,70 5,20 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,70 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,38 2,00 | 3,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,85 - 3,81 15324981 | 15324980 Arrangement Nominal Insul. diam [mm] 1007 2,00 / 15324980 1007 3,00 / 15324981 2,98 3,63 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 4 of 17 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 200 250 1,65 1,90 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,30 3,35 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,70 5,20 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,70 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,38 2,00 | 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,50 - 4,25 15324981 Arrangement Nominal Insul. diam [mm] 1009 2,00 / 15324981 1009 3,00 / 15324981 3,73 4,13 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 5 of 17 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 200 250 1,65 1,90 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,30 3,35 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,90 5,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 5,10 4,60 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,38 2,00 | 3,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 3,50 - 4,25 15324981 Arrangement Nominal Insul. diam [mm] 1009 2,00 / 15324981 1009 3,00 / 15324981 3,73 4,13 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 6 of 17 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 200 250 1,65 1,90 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,30 3,35 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,90 5,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 5,10 4,60 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,38 3,00 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 4,00 - 4,25 15324981 Arrangement Nominal Insul. diam [mm] 1009 3,00 / 15324981 4,13 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 7 of 17 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 250 1,90 Tol CCH [mm] 0,05 CCW [mm] 3,35 Tol CCW [mm] 0,10 ICH [mm] 5,00 Tol ICH [mm] 0,10 ICW [mm] 4,60 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal SN 0,38 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,80 - 4,00 15324981 Arrangement Nominal Insul. diam [mm] 1011 2,00 / 15324981 3,90 Tear-out CCH force [N] [mm] 200 1,65 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 8 of 17 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 3,30 Tol CCW [mm] 0,10 ICH [mm] 4,90 Tol ICH [mm] 0,10 ICW [mm] 5,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2004 Cable type / seal SN 0,38 1,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,41 - 2,60 15324982 Arrangement Nominal Insul. diam [mm] 2004 1,50 / 15324982 2,51 Cable type code legend: 2004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 9 of 17 FLR41X-B DIN COPPER SN PVC, XLPE THIN Tear-out CCH force [N] [mm] 160 1,55 Tol CCH [mm] 0,05 CCW [mm] 3,25 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2005 Cable type / seal SN 0,38 1,50 | 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,20 - 3,00 15324982 | 15324980 Arrangement 2005 1,50 / 15324982 2005 2,50 / 15324980 Nominal Insul. diam [mm] 2,40 2,85 Cable type code legend: 2005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 10 of 17 FLR2X (SAAB C) ISO COPPER NONE PVC, TPE, XLPE THIN Tear-out CCH force [N] [mm] 160 225 1,55 1,70 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,25 3,30 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,80 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2006 Cable type / seal SN 0,38 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,40 - 4,30 15324981 Arrangement Nominal Insul. diam [mm] 2006 2,50 / 15324981 3,85 Cable type code legend: 2006: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 11 of 17 ISO COPPER NONE EPR, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 225 1,70 Tol CCH [mm] 0,05 CCW [mm] 3,30 Tol CCW [mm] 0,10 ICH [mm] 5,00 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 1,50 2,50 3,00 3,00 / / / / SN 0,38 1,50 | 2,50 | 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 3,40 15324980 | 15324981 | 15324982 Arrangement 15324982 15324980 15324980 15324981 Nominal Insul. diam [mm] 2,20 2,80 3,10 3,10 Tear-out CCH force [N] [mm] 160 250 240 240 1,55 1,90 1,70 1,80 Tol CCH [mm] 0,05 0,05 0,05 0,05 CCW [mm] 3,25 2,85 3,20 3,25 Tol CCW [mm] 0,10 0,10 0,10 0,10 ICH [mm] 4,60 5,05 5,10 5,20 Tol ICH [mm] 0,10 0,10 0,10 0,10 ICW [mm] 4,50 5,15 4,60 4,90 Tol ICW [mm] 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-28 Page 12 of 17 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2011 Cable type / seal SN 0,38 1,50 | 2,50 | 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,60 - 4,10 15324982 | 15324981 | 15324980 Arrangement Nominal Insul. diam [mm] 2011 1,50 / 15324982 2011 2,50 / 15324980 2011 3,00 / 15324981 2,85 3,45 3,78 Tear-out CCH force [N] [mm] 160 225 240 1,55 1,70 1,70 Cable type code legend: 2011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 13 of 17 FL33X, FLK, FLY, FLYKW, IH WIRE DIN COPPER NONE P/EST, PE, PVC, XLPE REGULAR Tol CCH [mm] 0,05 0,05 0,05 CCW [mm] 3,25 3,25 3,25 Tol CCW [mm] 0,10 0,10 0,10 ICH [mm] 4,70 5,00 5,20 Tol ICH [mm] 0,10 0,10 0,10 ICW [mm] 4,50 4,60 4,90 Tol ICW [mm] 0,10 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2017 Cable type / seal SN 0,38 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,60 - 3,00 12015284 Arrangement 2017 2,50 / 12015284 Nominal Insul. diam [mm] 2,80 Cable type code legend: 2017: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 14 of 17 FLR41X-B, FLRY-A DIN COPPER SN PA, PP, PVC, XLPE THIN Tear-out CCH force [N] [mm] 326 1,80 Tol CCH [mm] 0,05 CCW [mm] 3,10 Tol CCW [mm] 0,10 ICH [mm] 4,90 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2023 Cable type / seal SN 0,38 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,20 - 3,70 15324981 Arrangement Nominal Insul. diam [mm] 2023 2,50 / 15324981 3,45 Cable type code legend: 2023: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 15 of 17 FL2G DIN COPPER SN SIL, SIR REGULAR Tear-out CCH force [N] [mm] 250 1,90 Tol CCH [mm] 0,05 CCW [mm] 2,85 Tol CCW [mm] 0,10 ICH [mm] 4,90 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3003 Cable type / seal SN 0,38 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,50 - 2,80 15324982 Arrangement Nominal Insul. diam [mm] 3003 2,00 / 15324982 2,65 Cable type code legend: 3003: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 16 of 17 AVSS JIS/JA COPPER NONE PVC, X-PVC THIN Tear-out CCH force [N] [mm] 180 1,65 Tol CCH [mm] 0,05 CCW [mm] 3,25 Tol CCW [mm] 0,10 ICH [mm] 4,70 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12129497 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 8000 Cable type / seal SN 0,38 1,50 | 2,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,20 - 3,00 15324982 Arrangement Nominal Insul. diam [mm] 8000 1,50 / 15324982 8000 2,50 / 15324982 2,30 2,85 Cable type code legend: 8000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-28 Page 17 of 17 N/G COPPER NONE SYNTHRESIN THIN Tear-out CCH force [N] [mm] 160 225 1,55 1,70 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,25 3,25 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 5,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,60 Tol ICW [mm] 0,10 0,10
12129497 价格&库存
很抱歉,暂时无法提供与“12129497”相匹配的价格&库存,您可以联系我们找货
    • 1+1.98880
    • 500+1.49160
    • 2000+1.39260
    库存:117
    12129497
      • 100+2.69719
      • 2500+2.62950
      • 7500+2.56389
      • 20000+2.50453
      • 40000+2.43892
      库存:2900
