13923559
13923559
    APTIV(安波福)
    APTIV / DELPHI - 13923559 - Connector Accessory, Seal, Aptiv RCS800 Series Automotive Connectors
13923559 数据手册
ZONE DE MARQUAGE MARKING AREA A-A SECTION REFERENCE MVL/ MVL PART-N 73.5 D 2 D CLIPS RCS800 ARGENTE' SILVER RCS800 FEMALE TERMINAL 1 D 13 Y SEE DETAIL 1.55 D H 20.6 $#3.0 CODING 1 SHOWN $ 0.4 K 1.3 0.5 D K DETAIL SCALE F F527600 EMBASE 2V RCS800 V2 CODE1 2W RCS800 V2 CODE1 HEADER F473110 EMBASE 2V RCS800 V2 CODE2 2W RCS800 V2 CODE2 HEADER F573110 EMBASE 2V RCS800 V2 CODE3 2W RCS800 V2 CODE3 HEADER A DEFINIR TO BE DEFINED 2:1 F 36.5 0.5 G 32.5 0.75 C C C 0.5 8.35 A-B 10 MIN - 11 MAXI F427600 13893888 NOIR BLACK 50² 11.9 MIN - 12.9 MAXI F327600 13923559 GRIS GREY 56.5 AXE DU PION PEG AXIS A-B 27.7 COULEUR COLOR MATIERE MATERIAL QUANTITE QUANTITY BOITIER EXTERNE OUTER HOUSING ORANGE ORANGE PBT 15% FV PBT GF 15 1 2 BOITIER INTERNE INNER HOUSING ORANGE ORANGE PBT 15% FV PBT GF 15 1 3 ETRIER SLIDER DEVICE PA6.6 30% FV PA6.6 GF 30 1 4 CAME ROTATIVE GEAR CAM NOIR BLACK PA6.6 30% FV PA6.6 GF 30 1 5 JOINT INTERFACIAL INTERFACIAL SEAL GRIS GREY SILICONE LSR LSR SILICON 1 6 SHUNT SHORTING BAR ACIER INOXYDABLE STAINLESS STEEL 1 7 CPA CPA PA6.6 30% FV PA6.6 GF 30 1 8 BLINDAGE SHIELD PLUG ALLIAGE DE CUIVRE COPPER ALLOY 2 9 CAPUCHON DE PROTECTION PROTECTIVE CAP PA6.6 30% FV PA6.6 GF 30 2 BLEU BLUE NOIR BLACK C D 21.1 0.5 Z 2:1 COULEUR/ REFERENCE MVL/ REFERENCE DELPHI/ MVL PART-N $ DELPHI PART-N $ COLOR 1 1 G DETAIL SCALE JUF SWS 35² DESIGNATION TITLE REPERE B 5 .00 B Y GRILLE ARRIERE SWS RETAINER DIAMETRE EXTERNE DU FIL/ EXTERNAL WIRE DIAMETER 13893887 Ø 17.4 0.4 F385400 0.5 H H $ REFERENCE DELPHI/ SECTION DU FIL/ DELPHI PART-N $ WIRE SECTION TABLEAU DES COMPOSANTS CONSTITUANT LE PRODUIT COMPONENTS TABLE CONSTITUTING THE PRODUCT Ø 17.4 1.00 0.4 A 19.7 #0.2 B 65.50 C D 19.7 C #0.2 A 0.6 ASSOCIATED PARTS (FOR INFORMATION) PRODUITS ASSOCIES (POUR INFORMATION) / 74.3 A SEE DETAIL Z SEE DETAIL A 6 A 0.5 A-B B-B SECTION 3 9 7 4 8 B 24.00 1 49.4 #0.3 0.3 29.0 C 2.50 #0.20 A-B C D 1.2 DETAIL SCALE H 0.8 C-C SECTION REPRISE DE BLINDAGE BRAID SHIELDING CONTINUITY H A 2:1 INDICATION DE DEVERROUILLAGE DE LA POSITION INTERLOCK INDICATION TO UNLOCK THE INTERLOCK POSITION SHUNT DORE SUR SON POINT DE CONTACT GOLD PLATED SHORTING BAR ON ITS CONTACT POINT INDICE REV. CONNECTEUR CONNECTOR REVISION LEVEL SIGLE MVL MVL LOGO NUMERO DE VOIE (2) WAY NUMBER (2) C EST DEFINIE AU MILIEU DU SEGMENT [AB] NORMALE A LA REFERENCE C IS DEFINED IN THE MIDDLE OF THE SEGMENT [AB] NORMAL TO THE REFERENCE [A-B] REFERENCE MVL / REFERENCE DELPHI / MVL PART-N DELPHI PART-N $ $ [A-B] F673110 REVISION G F773110 REVISION G 13974469 REVISION 01 33511761 REVISION 01 CODAGE 1 (NOIR) KEY 1 (BLACK) CODAGE MECANIQUE=COULEUR DE L'ETRIER MECHANICAL KEY= SLIDER COLOR IDENTIFIANT IMDS IMDS ID A DEFINIR TO BE DEFINED - CODAGE 2 (MARRON) KEY 2 (BROWN) NOTAS : 1- CAHIER DES CHARGES MVL : FE PS 10 008 - CLASSE DE TEMPERATURE DU CONNECTEUR : CLASSE 3 (-40°C . +125°C) - CLASSE DE VIBRATION : - PRECONDITIONNEMENT - VIBRATION 3x 16H (COMBINE AVEC TEMPERATURE -40°C / +125°C) ; 3.9g - CLASSE D'ETANCHEITE : - 1000mb INITIAL - 500mb APRES LES TESTS D'ENVIRONNEMENT - EFFORT D'ACCOUPLEMENT : F
13923559 价格&库存
很抱歉,暂时无法提供与“13923559”相匹配的价格&库存,您可以联系我们找货
