13955989
13955989
    APTIV(安波福)
    APTIV / DELPHI - 13955989 - TERM F GTS-1 0.64 SN CAVITY LOCK
13955989 数据手册
GTS 0.64 SERIES BENEFITS • Stable contact force with high performing copper alloy • Proven reliability in door-to-body connection system FEATURES • Clean body design to go through a mat seal • Easy and smooth insertion through mat seals GTS 0.64 Female & Male Terminals AVAILABLE CONFIGURATIONS TECHNICAL CHARACTERISTICS Terminal Construction Two-piece Contact Resistance < 6 mΩ Locking Mechanism Tangless / Lanceless Contact Mating Force 80 N Wire Gage Range (mm²) 0.22 - 0.85 Center Line Spacing 2.5 mm Genders Female, Male Sealing Options Unsealed, Mat Sealed Plating Options Sn, Au Mating Tab Dimension (mm) 0.64 x 0.64 MAX TEMP MAX VIBRATION 125°C 15 G MAX CURRENT AT 23°C 13 A APPLICATIONS EMS (Engine Management System) About Aptiv Aptiv is a global technology company that develops safer, greener and more connected solutions enabling the future of mobility. Visit aptiv.com aptiv.com | © 2021 Aptiv. All rights reserved See back page for representative part numbers and packaging dimensions. Type Sealing Gender Plating Wire size range (AWG) Wire size range (mm²) Part number GTS-1* Unsealed F Sn 24 - 22 0.22 - 0.35 13955989 GTS-1* Unsealed F Sn 20 0,5 13648598 GTS-1* Unsealed F Sn 18 0.75 - 0.85 13768627 GTS-3 Unsealed F Sn 24 - 22 0.22 - 0.35 33500712 GTS-3 Unsealed F Sn 20 0,5 33502051 GTS-3 Unsealed F Sn 18 0.75 - 0.85 33500713 GTS-3 Unsealed M Sn 24 - 22 0.22 - 0.35 33510990 GTS-3 Unsealed M Au 24 - 22 0.22 - 0.35 33285109 * CMC application DERATING CURVE Mated to: 0.22 - 0.85 mm2 Standard Sn Single circuit in free air* GTS 0.64 male terminals 0.22 - 0.35 mm² * For reference only 25 0.22 mm2 0.35 mm2 0.50 mm2 20 CURRENT (AMPERES) Cable range: Crimp method: Contact plating: Test method: 0.75 mm2 15 The test data was collected from single circuits in a draft free enclosure. This model does not account for all of the variables that would be present in an actual application. 10 5 One terminal loaded, in housing wire-to-wire configuration 0 0 10 20 30 40 50 60 70 80 90 ENVIRONMENTAL TEMPERATURE (°C) 100 110 120 130 For additional detailed product performance, visit our website at aptiv.com COMPATIBLE WITH CMC Connectors (32, 48, 64 & 86 Way) Part numbers, specifications, dimensions and performance data in this document are for general references only and are subject to change without notice. To verify product information, please contact an Aptiv representative. CS-SP113-GTS-En0221 aptiv.com | © 2021 Aptiv. All rights reserved
13955989 价格&库存
很抱歉,暂时无法提供与“13955989”相匹配的价格&库存,您可以联系我们找货
    库存:38076
