211PL032S0049
211PL032S0049
    APTIV(安波福)
    211PL032S0049
211PL032S0049 数据手册
Engine Compartment Connectors Coupling connectors Sicma 3 way mini-sealed coupling housings for 1.5 mm terminals Features • 3 position housings • 3.33 mm pitch • Reduced size sealed housings • Female part can be used as an aggregate housing • Circumferencial interface seal on female housing • Rear sealing ensured by a pre-mounted mat-seal • Pre-assembled front grids support blade terminal guiding and mating • Terminal position assurance (T.P.A.) • CPA optional available • GO-NO-GO housing locking principle • Mechanical polarization • Several colour codings available Performance characteristics • Temperature range: from -40°C to +125°C • Contact retention force: > 100 N • Contact insertion force: < 12 N • Connector mating force: < 60 N • Sealing protection: IP 68 • Acceptable wire range: Construction • Housing material: PBT • Interface seal: Silicone • Rear mat-seal: Silicone • Usable terminals: - Sicma-2 Sicma-2 Sicma-3 Sicma-3 1.5 1.5 1.5 1.5 mm mm mm mm female terminals male terminals female terminals male terminals Tooling • T.P.A. removal tool: 210S040 • Terminal removal tool 0.5 mm2 to 2 mm2 for 1.5 mm - Female terminal: - Male terminal: • Cavity plug: Part number Connector compatibility 2115015 2115016 210A015019 No. of position Terminal size 211 PC032S0049 3 1.5 mm Female Black N 211 PC032S1049 3 1.5 mm Female Brown N 211 PC032S2049 3 1.5 mm Female Red N 211 PC032S3049 3 1.5 mm Female Orange N 211 PC032S4049 3 1.5 mm Female Yellow N 211 PC032S5049 3 1.5 mm Female Green N 211 PC032S6049 3 1.5 mm Female Blue N 211 PC032S8049 3 1.5 mm Female Grey N 211 PC032S9049 3 1.5 mm Female White N 211 PC032S0081 3 1.5 mm Female Black Y 211 PC032S1081 3 1.5 mm Female Brown Y 211 PC032S2081 3 1.5 mm Female Red Y 211 PC032S3081 3 1.5 mm Female Orange Y 6.11 Type Colour Full schroud Engine Compartment Connectors Coupling connectors Sicma 3 way mini-sealed coupling housings for 1.5 mm terminals Part number No. of position Terminal size Type Colour Full schroud 211 PC032S4081 3 1.5 mm Female Yellow Y 211 PC032S5081 3 1.5 mm Female Green Y 211 PC032S6081 3 1.5 mm Female Blue Y 211 PC032S8081 3 1.5 mm Female Grey Y 211 PC032S9081 3 1.5 mm Female White Y 211 PL032S0049 3 1.5 mm Male Black N 211 PL032S1049 3 1.5 mm Male Brown N 211 PL032S4049 3 1.5 mm Male Yellow N 211 PL032S5049 3 1.5 mm Male Green N 211 PL032S6049 3 1.5 mm Male Blue N 211 PL032S8049 3 1.5 mm Male Grey N Dimensional characteristics Female housing - half shroud Male housing Female housing - full shroud Notes : 6.12 Product Detail Page Direct Links Page 1 of 2 ... Start > Search=211PL032S6049* > 211PL032S6049 211PL032S6049 Cross Reference Assistant Add to Favorites RoHS/LF P/N search Document & Drawing search 211PL032S6049 Application tooling Services 3 way coupling Male housing ... Email Datasheet FCI Brings You More Contact us Customer Drawing Distributor list Pricing request Contact our sales/technical support Sample request Price request Order samples Literature Print Datasheet ... Brochures & catalogs Product documentation Technical library Mating Half 211PC032S6049 Specifications General Mechanical Physical Terminal 1 Type Environmental Other Features General Application Wire to Wire Ways 3 Coding version Blue Product Type Housing Coding Yes http://portal.fciconnect.com/Comergent/en/US/adirect/fci?cmd=catProductDetail&showAddButton=true&productID=211PL03... 11/23/2007 Product Detail Page Page 2 of 2 Family Wire to Wire Features Pre-assembled front grids support blade terminal guiding and mating Circumferential interface seal Terminal position assurance (T.P.A.) Go-No-Go housing locking principle Rear sealing ensured by a pre-mounted mat-seal Reduced size sealed housing - Sealing protection IP 68 Acceptable wire size range from 0.5 to 2 mm² for 1.5 mm Hybrid No Main Terminal family Sicma Main Terminal size 1.5 mm Sealed Yes Terminal Size 1.5 Mechanical Connector mating force < 60N Physical Color Blue Material PBT Temperature (Range) -40°C to+125°C Terminal 1 Type Terminal type 1 Sicma Male 1.5 mm Terminal Ways for Terminal Type 1 3 Contact insertion force for Terminal Type 1 < 12N Contact Pitch for Terminal Type 1 3.33 mm Retention force (Contact) for Terminal Type 1 > 100N Environmental IMDS Yes Other Features Type Male Disclaimer Displayed data is for information purposes only. For more information, please contact your local sales office. The supply of some products might be limited to some customers. http://portal.fciconnect.com/Comergent/en/US/adirect/fci?cmd=catProductDetail&showAddButton=true&productID=211PL03... 11/23/2007
211PL032S0049 价格&库存
很抱歉,暂时无法提供与“211PL032S0049”相匹配的价格&库存,您可以联系我们找货
211PL032S0049
    • 5+16.75795
    • 75+16.25392
    • 250+15.75197
    • 500+15.24170
    • 5000+14.88763
    库存:620
