12033769
    APTIV(安波福)
12033769 数据手册
Metri-Pack Series METRI-PACK SERIES SE AL SE AL N E U D D U E U N Available in device and in-line connections for vehicle applications, Metri-Pack 630 Series connectors can meet or exceed the requirements for E AL E D S S S E AL E D 630 Available in device and in-line connections for underhood vehicle applications, Metri-Pack 630 Series sealed connectors can meet or exceed the most marine, appliance, and industrial control applications. requirements for most marine, appliance, and industrial control applications. Ideally suited for high current applications that do not require Utilizing triple-rib peripheral silicone rubber seals, Metri-Pack 630 Series sealed environmental protection, Metri-Pack 630 Series products are extremely rugged systems are ideally suited for high current applications that require protection from and versatile. environmental hazards. 630 Metri-Pack Features • Connector Position Assurance (CPA) • Terminal Position Assurance (TPA) • 46 Amps continuous maximum current rating • Low energy, low voltage capability • Excellent resistance to temperature, chemicals and abrasion • -40ºC to 125ºC temperature range 105 630 Metri-Pack Series A SE L N SE E U D D U E U N AL Cross Sectional View Terminal Terminal TPA Cable Cable TPA Female Connector Male Connector CPA (Connector Position Assurance) Female Terminal TPA (Terminal Position Assurance) Female Connector 630 FEMALE TERMINALS UNSEALED 630 FEMALE CONNECTORS UNSEALED Part # Cable Range (mm2) Material Plating # Cavities Connector Color Material TPA 12084590 5.0 Tin Brass Tin 2 12129939 Black PA66 HS IM 12129940 12052224 3.0 Tin Brass Tin 4 12015664 Black PA6 – 12084596 3.0 (2 Req’d.) Tin Brass Tin 12015870 2.0-1.0 Tin Brass Tin 12015869 1.0-0.80 Tin Brass Tin 12020035 0.80-0.50 (2 Req’d.) Tin Brass Tin 12052222 0.50-0.35 Tin Brass Tin http://delphi.com/products/connect 106 North American Region 1-800-PACKARD European Region 49-202-291-2000 Asia Pacific Region 65-730-9900 South American Region 55-12-378-2002 630 Metri-Pack Series SE AL SE AL N E U D D U E U N Unsealed System Application Information 630 SERIES TERMINALS–Tin Plated TEMPERATURE RISE ABOVE o AMBIENT (25 C ) VS CURRENT* TEMPERATURE DERATING CURVES* MAXIMUM CURRENT (AMPS) ........ 0.35-5.0 0.50 O TEMPERATURE RISE ( C ) CABLE RANGE (mm2): 100 CURRENT RANGE (AMPS): TEMP RANGE OC: RESISTANCE: ......... 0-46 ........... -40 to 125 .......
12033769 价格&库存
很抱歉,暂时无法提供与“12033769”相匹配的价格&库存,您可以联系我们找货
  • 4+14.11596
  • 40+13.81708
  • 100+13.39532
库存:788
12033769
    • 1+4.97200
    • 700+3.72900
    • 1400+2.75000
    库存:3697
