12052641
12052641
    APTIV(安波福)
12052641 数据手册
150 Metri-Pack Series L E A ED S S S E AL E D Cross Sectional View Terminal Terminal Connector Seal TPA TPA Cable Cable Cable Seal Cable Seal Female Connector Assembly Male Connector TPA (Terminal Position Assurance) Female Terminal Cable Seal 150 FEMALE TERMINALS SEALED Cable Range (mm2) Part # Material Plating 12048074 1.0-0.80 Silicon Bronze Tin 12084200 0.50-0.35 Silicon Bronze Tin 12160223 1.0-0.80 Beryllium Copper Silver/Nickel 12160222 0.50-0.35 Beryllium Copper Silver/Nickel Female Connector Assembly 150.2 PULL-TO-SEAT FEMALE TERMINALS* Cable Range (mm2) Part # Material Plating 12124075 1.0-0.80 Silicon Bronze Tin 12124076 0.50-0.35 Silicon Bronze Tin 1.0-0.80 Beryllium Copper Silver/Nickel 12161184 * To be used with female connections, see page 76 150 FEMALE CONNECTOR ASSEMBLIES SEALED # Cavities Conn. Asm. Color Material TPA 2 12052641 Black PA66 HS IM 12052634 150 METRI-PACK CABLE SEALS 3 12110293 Black PA66 HS IM 12052845 Reel Part # Loose Part # Cable Diameter Material Color 4 12162144 Black PA66 HS IM 12047948 12052924 12048086 2.85-2.03 Silicone Dk. Red 5 12146045 Natural PA6 12092844 12089442 12089678 2.15-1.60 Silicone White 6 12052848 Black PA6 12052850 12052925 12048087 1.70-1.29 Silicone Blue 8 12047937 Black PA66 HS IM 12066304 12124669 12084193 1.009-0.995 Silicone Tan 10 12065425 Black PA66 HS IM 12124264 http://delphi.com/products/connect 66 North American Region 1-800-PACKARD European Region 49-202-291-2000 Asia Pacific Region 65-730-9900 South American Region 55-12-378-2002
12052641 价格&库存
很抱歉,暂时无法提供与“12052641”相匹配的价格&库存,您可以联系我们找货
