12110127
    APTIV(安波福)
12110127 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal AG 0,51 5,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,70 - 4,07 NONE Arrangement 1005 5,00 Nominal Insul. diam [mm] 3,89 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 1 of 23 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 4,30 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal AG 0,51 5,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 3,70 - 4,07 NONE Arrangement 1005 5,00 Nominal Insul. diam [mm] 3,89 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 2 of 23 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 4,30 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal AG 0,51 5,00 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 3,70 - 4,07 NONE Arrangement 1005 5,00 Nominal Insul. diam [mm] 3,89 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 3 of 23 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 4,30 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal AG 0,51 5,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 4,20 - 4,70 NONE Arrangement Nominal Insul. diam [mm] 1007 5,00 4,45 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 4 of 23 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,60 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal AG 0,51 5,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 4,20 - 4,70 NONE Arrangement Nominal Insul. diam [mm] 1007 5,00 4,45 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 5 of 23 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,60 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal AG 0,51 5,00 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 4,20 - 4,70 NONE Arrangement Nominal Insul. diam [mm] 1007 5,00 4,45 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 6 of 23 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,60 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal AG 0,51 5,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 4,80 - 5,33 NONE Arrangement Nominal Insul. diam [mm] 1009 5,00 5,07 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 7 of 23 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,70 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal AG 0,51 5,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 4,80 - 5,33 NONE Arrangement Nominal Insul. diam [mm] 1009 5,00 5,07 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 8 of 23 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,70 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal AG 0,51 5,00 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 4,80 - 5,33 NONE Arrangement Nominal Insul. diam [mm] 1009 5,00 5,07 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 9 of 23 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,70 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal AG 0,51 3,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 4,50 - 4,70 NONE Arrangement Nominal Insul. diam [mm] 1011 3,00 4,60 Tear-out CCH force [N] [mm] 240 2,25 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 10 of 23 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 4,80 Tol ICH [mm] 0,10 ICW [mm] 5,30 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1026 Cable type / seal AG 0,51 5,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 4,20 - 4,70 NONE Arrangement Nominal Insul. diam [mm] 1026 5,00 4,45 Cable type code legend: 1026: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 11 of 23 SAE COPPER SN HDPE, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,60 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1035 Cable type / seal AG 0,51 5,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 4,20 - 4,70 NONE Arrangement Nominal Insul. diam [mm] 1035 5,00 4,45 Cable type code legend: 1035: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 12 of 23 SAE COPPER NONE XLPE REGULAR Tear-out CCH force [N] [mm] 300 2,65 Tol CCH [mm] 0,05 CCW [mm] 3,80 Tol CCW [mm] 0,10 ICH [mm] 5,20 Tol ICH [mm] 0,10 ICW [mm] 5,60 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2005 Cable type / seal AG 0,51 4,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,40 - 3,80 NONE Arrangement 2005 4,00 Nominal Insul. diam [mm] 3,60 Cable type code legend: 2005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 13 of 23 FLR2X (SAAB C) ISO COPPER NONE PVC, TPE, XLPE THIN Tear-out CCH force [N] [mm] 275 2,35 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 4,40 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 2010 AG 0,51 2,50 | 3,00 | 4,00 | 5,00 | 6,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,60 - 4,30 NONE Arrangement 2,50 3,00 4,00 5,00 6,00 Nominal Insul. diam [mm] 2,80 3,10 3,45 4,05 4,05 Tear-out CCH force [N] [mm] 210 260 350 290 320 2,60 2,35 2,35 2,65 2,80 Tol CCH [mm] 0,05 0,05 0,05 0,05 0,05 CCW [mm] 3,70 3,80 4,10 3,80 3,80 Tol CCW [mm] 0,10 0,10 0,10 0,10 0,10 ICH [mm] 4,90 3,80 4,50 4,50 4,30 Tol ICH [mm] 0,10 0,10 0,10 0,10 0,10 ICW [mm] 5,20 5,35 4,85 5,30 5,50 Tol ICW [mm] 0,10 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 14 of 23 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal AG 0,51 6,00 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 3,80 - 4,30 NONE Arrangement 2010 6,00 Nominal Insul. diam [mm] 4,05 Tear-out CCH force [N] [mm] 435 2,80 Tol CCH [mm] 0,05 CCW [mm] 3,90 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 5,40 Tol ICW [mm] 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 15 of 23 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Seal(s): 2010 + 2010 AG 0,51 0,75 | 1,00 | 2,50 | 4,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY NONE Cable type / seal Arrangement Nominal Insul. diam [mm] 2010 0,75 + 2010 2,50 2010 1,00 + 2010 4,00 2010 2,50 + 2010 2,50 TOP 1,75 + 2,80 1,95 + 3,45 2,80 + 2,80 Tear-out CCH force [N] [mm] 120 158 210 2,30 2,65 2,60 Tol CCH [mm] 0,05 0,05 0,05 CCW [mm] 4,15 3,80 3,70 Tol CCW [mm] 0,10 0,10 0,10 ICH [mm] 4,80 4,55 4,90 Tol ICH [mm] 0,10 0,10 0,10 ICW [mm] 4,85 5,45 5,20 Tol ICW [mm] 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 16 of 23 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Seal(s): 2010 + 2010 Cable type / seal AG 0,51 2,50 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED NONE Arrangement 2010 2,50 + 2010 2,50 Nominal Insul. diam [mm] 2,80 + 2,80 Tear-out CCH force [N] [mm] 210 2,60 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 4,90 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 17 of 23 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2011 Cable type / seal AG 0,51 4,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 4,00 - 4,50 NONE Arrangement Nominal Insul. diam [mm] 2011 4,00 4,25 Tear-out CCH force [N] [mm] 275 2,35 Cable type code legend: 2011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 18 of 23 FL33X, FLK, FLY, FLYKW, IH WIRE DIN COPPER NONE P/EST, PE, PVC, XLPE REGULAR Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 4,20 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2017 Cable type / seal AG 0,51 4,00 | 6,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,20 - 4,30 NONE Arrangement 2017 4,00 2017 6,00 Nominal Insul. diam [mm] 3,45 4,05 Cable type code legend: 2017: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 19 of 23 FLR41X-B, FLRY-A DIN COPPER SN PA, PP, PVC, XLPE THIN Tear-out CCH force [N] [mm] 265 320 2,35 2,80 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,70 3,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,00 4,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 5,20 5,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2017 Cable type / seal AG 0,51 6,00 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 3,80 - 4,30 NONE Arrangement 2017 6,00 Nominal Insul. diam [mm] 4,05 Cable type code legend: 2017: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 20 of 23 FLR41X-B, FLRY-A DIN COPPER SN PA, PP, PVC, XLPE THIN Tear-out CCH force [N] [mm] 1135 2,80 Tol CCH [mm] 0,05 CCW [mm] 3,85 Tol CCW [mm] 0,10 ICH [mm] 4,35 Tol ICH [mm] 0,10 ICW [mm] 5,35 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2083 Cable type / seal AG 0,51 4,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,40 - 3,80 NONE Arrangement Nominal Insul. diam [mm] 2083 4,00 3,60 Cable type code legend: 2083: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 21 of 23 ISO COPPER NONE PVC (YW) THIN Tear-out CCH force [N] [mm] 275 2,35 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3002 Cable type / seal AG 0,51 3,00 | 5,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,40 - 4,60 NONE Arrangement Nominal Insul. diam [mm] 3002 3,00 3002 5,00 3,60 4,40 Cable type code legend: 3002: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 22 of 23 JIS/JA COPPER NONE PVC, XLPVC REGULAR Tear-out CCH force [N] [mm] 240 290 2,25 2,65 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,65 3,80 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,90 4,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 5,20 5,40 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12110127 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 8000 Cable type / seal AG 0,51 4,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,40 - 3,70 NONE Arrangement Nominal Insul. diam [mm] 8000 4,00 3,55 Cable type code legend: 8000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 23 of 23 N/G COPPER NONE SYNTHRESIN THIN Tear-out CCH force [N] [mm] 275 2,35 Tol CCH [mm] 0,05 CCW [mm] 3,70 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 5,20 Tol ICW [mm] 0,10
12110127 价格&库存
很抱歉,暂时无法提供与“12110127”相匹配的价格&库存,您可以联系我们找货
