15344718
15344718
    APTIV(安波福)
15344718 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15344718 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 2010 2010 0,50 0,50 0,60 0,75 1,00 1,00 / / / / / / SN 0,32 0,50 | 0,60 | 0,75 | 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 2,10 12034365 | 15324983 | 15338470 | 15324985 Arrangement 12034365 15324983 15338470 15338470 15338470 15324985 Nominal Insul. diam [mm] 1,50 1,50 1,83 1,75 1,95 1,95 Tear-out CCH force [N] [mm] 80 80 90 120 160 160 1,25 1,25 1,30 1,35 1,45 1,45 Tol CCH [mm] 0,05 0,05 0,05 0,05 0,05 0,05 CCW [mm] 2,00 2,00 2,05 2,05 2,05 2,05 Tol CCW [mm] 0,10 0,10 0,10 0,10 0,10 0,10 ICH [mm] 4,50 3,90 4,60 4,60 4,70 4,50 Tol ICH [mm] 0,10 0,10 0,10 0,10 0,10 0,10 ICW [mm] 5,00 5,05 5,00 5,00 5,05 5,00 Tol ICW [mm] 0,10 0,10 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-28 Page 1 of 1 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC
15344718 价格&库存
很抱歉,暂时无法提供与“15344718”相匹配的价格&库存,您可以联系我们找货
