SICMA 2.8 SERIES
BENEFITS
• Optimized design to keep stable contact
pressure
• Standard terminal cavity compatibility
FEATURES
• Clean body design, preventing tearing of mat
seal
• One-piece construction with high pressure
contact
• Several crimping gauges for strong slow motion
and vibration performance
SICMA 2.8
Female & Male Terminals
AVAILABLE CONFIGURATIONS
TECHNICAL CHARACTERISTICS
Terminal Construction
One-piece
Contact Resistance
< 3 mΩ
Locking Mechanism
Tangless / Lanceless
Contact Mating Force
1.5 N
Blade Size (mm)
2.8
Mating Cycles
10
Wire Gage Range (AWG)
22 - 14
Cavity Pullout Force
120 N
Wire Gage Range (mm²)
0.35 - 2.5
Center Line Spacing
5 mm
Genders
Female, Male
Sealing Options
Unsealed, Mat Sealed,
Cable Sealed
Plating Options
Sn, SnAg, Au
Mating Tab Dimension (mm)
2.8 x 0.8
See back page for representative part numbers and packaging dimensions.
About Aptiv
Aptiv is a global technology company that
develops safer, greener and more connected
solutions enabling the future of mobility.
Visit aptiv.com
aptiv.com | © 2021 Aptiv. All rights reserved
MAX
TEMP
MAX
VIBRATION
125°C
25 G
MAX CURRENT
AT 23°C
33 A
Sealing
Gender
Plating
Wire size range
(AWG)
Wire size range
(mm²)
Part number
Other
available platings
Unsealed
F
Sn
22 - 18
0.35 - 0.70
10781041
SnAg, Au
Unsealed
F
Sn
18 - 16
0.75 - 1.30
15522621
SnAg, Au
Unsealed
F
Sn
16 - 12
1.35 - 2.5
10725649
SnAg, Au
Unsealed
M
Sn
22 - 18
0.35 - 0.75
10779316
Unsealed
M
Sn
18 - 12
1.0 - 2.5
10756743
Cable Sealed
F
Sn
22 - 18
0.35 - 0.70
10740375
Cable Sealed
F
Sn
18 - 16
0.75 - 1.30
13873373
Cable Sealed
F
Sn
16 - 12
1.35 - 2.5
10740376
Cable Sealed
M
Sn
22 - 18
0.35 - 0.75
10781143
Cable Sealed
M
Sn
18 - 12
1.0 - 2.5
10793682
COMPATIBLE SEALS
Type
Applicable wire size (mm2)
Color
Part number
Cable Seal
0.35 - 0.70
Red
15327786
Cable Seal
0.75 - 1.30
Brown
13578695
Cable Seal
1.35 - 2.50
Blue
10757056
DERATING CURVE
Mated to:
* For reference only
0.35 - 2.5 mm2
Standard
Sn
Single circuit
in free air*
SICMA
Male Tab
40
0.35 mm2
1.0 mm2
35
0.50 mm2
1.5 mm2
0.75 mm
2.0 mm2
2
30
CURRENT (AMPERES)
Cable range:
Crimp method:
Contact plating:
Test method:
2.5 mm2
25
The test data was collected
from single circuits in a draft
free enclosure. This model
does not account for all of the
variables that would be present
in an actual application.
10
5
40
50
60
70
80
90
100
ENVIRONMENTAL TEMPERATURE (°C)
110
120
130
For additional detailed product
performance, visit our website at
aptiv.com
COMPATIBLE WITH SICMA HOUSINGS
SICMA
Inline
Sealed Series
24 Way (Mixed)
SICMA
Inline
Unsealed Series
24 & 36 Way
(Mixed)
SICMA
Header Interconnect
Sealed Series
6 & 24 Way
(Mixed)
SICMA
Sealed
Relay Sockets
8 Way (Mixed)
SICMA
Mini-Sealed
Series
6 Way (Mixed)
SICMA
Panel-Through
Sealed Series
14, 24, 26, 33,
34 Way (Mixed)
SICMA
Panel-Through
Unsealed Series
24, 29, 42 Way
(Mixed)
Part numbers, specifications, dimensions and performance data in this document are for general references only and are subject to change without notice.
To verify product information, please contact an Aptiv representative.
CS-SP60-SICMA-En0221
很抱歉,暂时无法提供与“10740376”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.59563
- 500+0.52918
- 1000+0.51969
- 2500+0.50901
- 5000+0.49833
- 10000+0.48766
