12077628
12077628
    APTIV(安波福)
    胶壳端子 20-22AWG
12077628 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,38 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,88 15324976 | 15324974 Arrangement 1005 0,35 / 15324974 1005 0,50 / 15324976 Nominal Insul. diam [mm] 1,60 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 1 of 32 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 55 80 1,10 1,15 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,05 2,00 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,00 4,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,38 0,50 (SR) SOLDER - REFLOW [LOW IMPEDANCE (SIR) CIRCUIT] 1,60 - 1,88 15324976 Arrangement 1005 0,50 / 15324976 Nominal Insul. diam [mm] 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 2 of 32 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,38 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 1,60 - 1,88 15324976 Arrangement 1005 0,50 / 15324976 Nominal Insul. diam [mm] 1,74 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 3 of 32 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,38 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 2,30 15324973 | 15324976 Arrangement Nominal Insul. diam [mm] 1007 0,35 / 15324976 1007 0,50 / 15324973 1,95 2,15 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 4 of 32 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 55 80 1,10 1,15 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,05 2,00 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,00 4,10 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,38 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,00 - 2,30 15324973 Arrangement Nominal Insul. diam [mm] 1007 0,50 / 15324973 2,15 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 5 of 32 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,38 0,50 | 0,51 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,30 - 2,60 15324973 Arrangement Nominal Insul. diam [mm] 1009 0,50 / 15324973 1009 0,51 / 15324973 2,45 2,45 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 6 of 32 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 80 80 1,15 1,15 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,00 2,00 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,10 4,10 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,38 0,50 | 0,51 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,30 - 2,60 15324973 Arrangement Nominal Insul. diam [mm] 1009 0,50 / 15324973 1009 0,51 / 15324973 2,45 2,45 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 7 of 32 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 80 80 1,15 1,15 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,00 2,00 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,10 4,10 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1023 Cable type / seal SN 0,38 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,05 - 1,35 15324974 Arrangement Nominal Insul. diam [mm] 1023 0,35 / 15324974 1,20 Tear-out CCH force [N] [mm] 60 Cable type code legend: 1023: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 8 of 32 SAE COPPER SN ECTFE, ETFE, PTFE, PUR, TFE ULTRA THIN 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 3,70 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1025 Cable type / seal SN 0,38 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,47 - 1,85 15324974 | 15324976 Arrangement 1025 0,35 / 15324974 1025 0,50 / 15324976 Nominal Insul. diam [mm] 1,55 1,73 Tear-out CCH force [N] [mm] 55 80 1,10 1,15 Tol CCH [mm] 0,05 0,05 Cable type code legend: 1025: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 9 of 32 SAE COPPER SN FLUORPOLYM, HDPE, PBT, PE, PVC, XLPE THIN CCW [mm] 2,00 2,00 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,00 4,10 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1026 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324973 Arrangement Nominal Insul. diam [mm] 1026 0,50 / 15324973 2,15 Cable type code legend: 1026: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 10 of 32 SAE COPPER SN HDPE, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1027 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,30 - 2,60 15324973 Arrangement Nominal Insul. diam [mm] 1027 0,50 / 15324973 2,45 Cable type code legend: 1027: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 11 of 32 SAE COPPER SN PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1035 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324979 Arrangement Nominal Insul. diam [mm] 1035 0,50 / 15324979 2,15 Cable type code legend: 1035: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 12 of 32 SAE COPPER NONE XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,30 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1040 Cable type / seal SN 0,38 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,75 15324974 Arrangement 1040 0,35 / 15324974 Nominal Insul. diam [mm] 1,58 Tear-out CCH force [N] [mm] 90 Cable type code legend: 1040: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 13 of 32 SAE STAINLESS STEEL NONE ECTFE, ETFE, PTFE, PUR, TFE THIN 1,10 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 3,80 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1047 Cable type / seal SN 0,38 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,75 15324974 Arrangement Nominal Insul. diam [mm] 1047 0,35 / 15324974 1,58 Cable type code legend: 1047: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 14 of 32 SAE COPPER NONE PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 1,10 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1048 Cable type / seal SN 0,38 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 2,10 15324976 Arrangement Nominal Insul. diam [mm] 1048 0,35 / 15324976 1,95 Cable type code legend: 1048: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 15 of 32 SAE COPPER NONE PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 70 1,10 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1055 Cable type / seal SN 0,38 0,35 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,75 15324974 Arrangement 1055 0,35 / 15324974 Nominal Insul. diam [mm] 1,60 Cable type code legend: 1055: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 16 of 32 SAE COPPER SN HDPE, PVC, XLPE THIN Tear-out CCH force [N] [mm] 70 1,10 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1056 Cable type / seal SN 0,38 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,45 - 1,85 15324974 | 15324976 Arrangement 1056 0,35 / 15324974 1056 0,50 / 15324976 Nominal Insul. diam [mm] 1,60 1,73 Cable type code legend: 1056: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 17 of 32 SAE COPPER NI FLUORPOLYM, PTFE THIN Tear-out CCH force [N] [mm] 70 80 1,10 1,15 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,05 2,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,00 4,10 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,10 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1057 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324973 Arrangement Nominal Insul. diam [mm] 1057 0,50 / 15324973 2,15 Cable type code legend: 1057: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 18 of 32 SAE COPPER NI PTFE REGULAR Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1058 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 1,85 15324976 Arrangement 1058 0,50 / 15324976 1,73 Cable type code legend: 1058: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 19 of 32 Nominal Insul. diam [mm] SAE COPPER NI XLPE THIN Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1059 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324973 Arrangement Nominal Insul. diam [mm] 1059 0,50 / 15324973 2,15 Cable type code legend: 1059: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 20 of 32 SAE COPPER NI XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1066 Cable type / seal SN 0,38 0,80 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 0,00 - 0,00 12084193 Arrangement 1066 0,80 / 12084193 0,00 Cable type code legend: 1066: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 21 of 32 Nominal Insul. diam [mm] SAE COPPER SN NONE NONE Tear-out CCH force [N] [mm] 90 1,25 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,00 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1092 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 15324979 Arrangement Nominal Insul. diam [mm] 1092 0,50 / 15324979 2,15 Cable type code legend: 1092: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 22 of 32 SAE ALLOY NONE XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,30 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,35 - 2,50 15324973 Arrangement Nominal Insul. diam [mm] 1094 0,50 / 15324973 2,43 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 23 of 32 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,38 0,50 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,35 - 2,50 15324973 Arrangement Nominal Insul. diam [mm] 1094 0,50 / 15324973 2,43 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 24 of 32 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2005 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,95 15324976 Arrangement 2005 0,50 / 15324976 Nominal Insul. diam [mm] 1,68 Cable type code legend: 2005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 25 of 32 FLR2X (SAAB C) ISO COPPER NONE PVC, TPE, XLPE THIN Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2006 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,35 15324973 Arrangement Nominal Insul. diam [mm] 2006 0,50 / 15324973 2,18 Cable type code legend: 2006: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 26 of 32 ISO COPPER NONE EPR, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 0,35 0,35 0,50 0,50 / / / / SN 0,38 0,35 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,20 - 1,70 12084193 | 15324974 Arrangement 12084193 15324974 12084193 15324974 Nominal Insul. diam [mm] 1,34 1,34 1,50 1,50 Tear-out CCH force [N] [mm] 50 50 80 80 1,20 1,20 1,30 1,30 Tol CCH [mm] 0,05 0,05 0,05 0,05 CCW [mm] 1,90 1,90 1,90 1,90 Tol CCW [mm] 0,10 0,10 0,10 0,10 ICH [mm] 3,95 3,95 4,05 4,05 Tol ICH [mm] 0,10 0,10 0,10 0,10 ICW [mm] 4,15 4,15 4,20 4,20 Tol ICW [mm] 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-01-09 Page 27 of 32 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2011 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,00 - 2,30 12089442 Arrangement Nominal Insul. diam [mm] 2011 0,50 / 12089442 2,15 Tear-out CCH force [N] [mm] 115 1,20 Cable type code legend: 2011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 28 of 32 FL33X, FLK, FLY, FLYKW, IH WIRE DIN COPPER NONE P/EST, PE, PVC, XLPE REGULAR Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 4,20 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2019 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 1,70 15324974 Arrangement 2019 0,50 / 15324974 Nominal Insul. diam [mm] 1,50 Tear-out CCH force [N] [mm] 60 1,20 Tol CCH [mm] 0,05 CCW [mm] 2,05 Cable type code legend: 2019: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 29 of 32 FL7Y 179, FLR7Y, FLR7Y-A, FLR7Y-B, FLU7Y DIN COPPER SN ETFE THIN Tol CCW [mm] 0,10 ICH [mm] 3,95 Tol ICH [mm] 0,10 ICW [mm] 1,20 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3004 Cable type / seal SN 0,38 0,30 | 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,30 - 1,70 15324974 Arrangement 3004 0,30 / 15324974 3004 0,50 / 15324974 Nominal Insul. diam [mm] 1,40 1,60 Cable type code legend: 3004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 30 of 32 AVSS JIS/JA COPPER NONE PVC, XLPE, X-PVC THIN Tear-out CCH force [N] [mm] 50 75 1,05 1,10 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,00 2,00 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,70 3,90 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,00 4,10 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 8000 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,40 - 1,60 15324976 Arrangement Nominal Insul. diam [mm] 8000 0,50 / 15324976 1,50 Cable type code legend: 8000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 31 of 32 N/G COPPER NONE SYNTHRESIN THIN Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 3,90 Tol ICH [mm] 0,10 ICW [mm] 4,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12077628 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 9003 Cable type / seal SN 0,38 0,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,92 - 2,06 15324973 Arrangement 9003 0,50 / 15324973 1,99 Cable type code legend: 9003: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-01-09 Page 32 of 32 Nominal Insul. diam [mm] N/G COPPER SN PVDF MIX Tear-out CCH force [N] [mm] 80 1,15 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 4,10 Tol ICH [mm] 0,10 ICW [mm] 4,10 Tol ICW [mm] 0,10
12077628 价格&库存
很抱歉,暂时无法提供与“12077628”相匹配的价格&库存,您可以联系我们找货
    • 500+0.28860
    库存:10571
    12077628
    • 11200+1.4452711200+0.18788
    • 22400+1.4385022400+0.18700
    • 33600+1.3818133600+0.17963
    • 56000+1.3682756000+0.17787
    • 112000+1.35388112000+0.17600
    • 280000+1.33950280000+0.17413
    库存:89600
    12077628
    • 2800+0.938412800+0.12199
    • 5600+0.912185600+0.11858
    • 11200+0.8927211200+0.11605
    • 25200+0.8876425200+0.11539
    • 50400+0.8825650400+0.11473
    库存:84000
    12077628
      • 10+0.32909
      • 100+0.30655
      • 500+0.28401
      • 2000+0.26147
      • 5000+0.24569
      • 10000+0.23893
      库存:50
