13873373
13873373
    APTIV(安波福)
    APTIV / DELPHI - 13873373 - SICMA-3 2.8 SN SEALED CAVITY LOCK
13873373 数据手册
SICMA 2.8 SERIES BENEFITS • Optimized design to keep stable contact pressure • Standard terminal cavity compatibility FEATURES • Clean body design, preventing tearing of mat seal • One-piece construction with high pressure contact • Several crimping gauges for strong slow motion and vibration performance SICMA 2.8 Female & Male Terminals AVAILABLE CONFIGURATIONS TECHNICAL CHARACTERISTICS Terminal Construction One-piece Contact Resistance < 3 mΩ Locking Mechanism Tangless / Lanceless Contact Mating Force 1.5 N Blade Size (mm) 2.8 Mating Cycles 10 Wire Gage Range (AWG) 22 - 14 Cavity Pullout Force 120 N Wire Gage Range (mm²) 0.35 - 2.5 Center Line Spacing 5 mm Genders Female, Male Sealing Options Unsealed, Mat Sealed, Cable Sealed Plating Options Sn, SnAg, Au Mating Tab Dimension (mm) 2.8 x 0.8 See back page for representative part numbers and packaging dimensions. About Aptiv Aptiv is a global technology company that develops safer, greener and more connected solutions enabling the future of mobility. Visit aptiv.com aptiv.com | © 2021 Aptiv. All rights reserved MAX TEMP MAX VIBRATION 125°C 25 G MAX CURRENT AT 23°C 33 A Sealing Gender Plating Wire size range (AWG) Wire size range (mm²) Part number Other available platings Unsealed F Sn 22 - 18 0.35 - 0.70 10781041 SnAg, Au Unsealed F Sn 18 - 16 0.75 - 1.30 15522621 SnAg, Au Unsealed F Sn 16 - 12 1.35 - 2.5 10725649 SnAg, Au Unsealed M Sn 22 - 18 0.35 - 0.75 10779316 - Unsealed M Sn 18 - 12 1.0 - 2.5 10756743 - Cable Sealed F Sn 22 - 18 0.35 - 0.70 10740375 - Cable Sealed F Sn 18 - 16 0.75 - 1.30 13873373 - Cable Sealed F Sn 16 - 12 1.35 - 2.5 10740376 - Cable Sealed M Sn 22 - 18 0.35 - 0.75 10781143 - Cable Sealed M Sn 18 - 12 1.0 - 2.5 10793682 - COMPATIBLE SEALS Type Applicable wire size (mm2) Color Part number Cable Seal 0.35 - 0.70 Red 15327786 Cable Seal 0.75 - 1.30 Brown  13578695  Cable Seal 1.35 - 2.50 Blue 10757056 DERATING CURVE Mated to: * For reference only 0.35 - 2.5 mm2 Standard Sn Single circuit in free air* SICMA Male Tab 40 0.35 mm2 1.0 mm2 35 0.50 mm2 1.5 mm2 0.75 mm 2.0 mm2 2 30 CURRENT (AMPERES) Cable range: Crimp method: Contact plating: Test method: 2.5 mm2 25 20 15 The test data was collected from single circuits in a draft free enclosure. This model does not account for all of the variables that would be present in an actual application. 10 5 0 0 10 20 30 40 50 60 70 80 90 100 ENVIRONMENTAL TEMPERATURE (°C) 110 120 130 For additional detailed product performance, visit our website at aptiv.com COMPATIBLE WITH SICMA HOUSINGS SICMA Inline Sealed Series 24 Way (Mixed) SICMA Inline Unsealed Series 24 & 36 Way (Mixed) SICMA Header Interconnect Sealed Series 6 & 24 Way (Mixed) SICMA Sealed Relay Sockets 8 Way (Mixed) SICMA Mini-Sealed Series 6 Way (Mixed) SICMA Panel-Through Sealed Series 14, 24, 26, 33, 34 Way (Mixed) SICMA Panel-Through Unsealed Series 24, 29, 42 Way (Mixed) Part numbers, specifications, dimensions and performance data in this document are for general references only and are subject to change without notice. To verify product information, please contact an Aptiv representative. CS-SP60-SICMA-En0221 aptiv.com | © 2021 Aptiv. All rights reserved
13873373 价格&库存
很抱歉,暂时无法提供与“13873373”相匹配的价格&库存,您可以联系我们找货
