15326267
15326267
    APTIV(安波福)
15326267 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,30 0,80 | 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,85 - 2,40 15305351 | 15366060 Arrangement 1005 0,80 / 15305351 1005 0,80 / 15366060 1005 1,00 / 15305351 Nominal Insul. diam [mm] 2,03 2,03 2,23 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 1 of 11 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 90 90 120 1,25 1,25 1,30 Tol CCH [mm] 0,05 0,05 0,05 CCW [mm] 2,05 2,05 2,10 Tol CCW [mm] 0,10 0,10 0,10 ICH [mm] 3,20 3,40 3,30 Tol ICH [mm] 0,10 0,10 0,10 ICW [mm] 3,00 3,00 3,10 Tol ICW [mm] 0,10 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,30 0,80 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 1,85 - 2,20 15305351 Arrangement 1005 0,80 / 15305351 Nominal Insul. diam [mm] 2,03 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 2 of 11 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 90 1,25 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 3,20 Tol ICH [mm] 0,10 ICW [mm] 3,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,30 0,80 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,20 - 2,45 15305351 Arrangement Nominal Insul. diam [mm] 1007 0,80 / 15305351 2,33 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 3 of 11 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 90 1,30 Tol CCH [mm] 0,05 CCW [mm] 2,00 Tol CCW [mm] 0,10 ICH [mm] 3,30 Tol ICH [mm] 0,10 ICW [mm] 3,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1019 Cable type / seal SN 0,30 0,80 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,70 - 1,90 15305351 Arrangement Nominal Insul. diam [mm] 1019 0,80 / 15305351 1,80 Cable type code legend: 1019: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 4 of 11 SAE COPPER NONE PVC, XLPE THIN SPECIAL Tear-out CCH force [N] [mm] 90 1,25 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 3,20 Tol ICH [mm] 0,10 ICW [mm] 3,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1025 Cable type / seal SN 0,30 0,80 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,85 - 2,18 15305351 Arrangement 1025 0,80 / 15305351 Nominal Insul. diam [mm] 2,02 Tear-out CCH force [N] [mm] 90 1,25 Tol CCH [mm] 0,05 Cable type code legend: 1025: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 5 of 11 SAE COPPER SN FLUORPOLYM, HDPE, PBT, PE, PVC, XLPE THIN CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 3,20 Tol ICH [mm] 0,10 ICW [mm] 3,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal 2010 2010 2010 2010 0,75 0,75 1,00 1,00 / / / / SN 0,30 0,75 | 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 2,10 15344324 | 15305351 Arrangement 15344324 15305351 15305351 15344324 Nominal Insul. diam [mm] 1,75 1,75 1,95 1,95 Tear-out CCH force [N] [mm] 120 120 160 160 1,25 1,25 1,40 1,40 Tol CCH [mm] 0,05 0,05 0,05 0,05 CCW [mm] 2,05 2,05 2,10 2,10 Tol CCW [mm] 0,10 0,10 0,10 0,10 ICH [mm] 3,10 3,10 3,20 3,20 Tol ICH [mm] 0,10 0,10 0,10 0,10 ICW [mm] 3,05 3,05 3,05 3,05 Tol ICW [mm] 0,10 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2014-07-29 Page 6 of 11 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2017 Cable type / seal SN 0,30 0,75 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,60 - 1,90 15305351 Arrangement 2017 0,75 / 15305351 Nominal Insul. diam [mm] 1,75 Cable type code legend: 2017: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 7 of 11 FLR41X-B, FLRY-A DIN COPPER SN PA, PP, PVC, XLPE THIN Tear-out CCH force [N] [mm] 120 1,25 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 3,05 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2083 Cable type / seal SN 0,30 0,75 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,70 - 1,90 15305351 Arrangement Nominal Insul. diam [mm] 2083 0,75 / 15305351 1,80 Cable type code legend: 2083: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 8 of 11 ISO COPPER NONE PVC (YW) THIN Tear-out CCH force [N] [mm] 85 1,30 Tol CCH [mm] 0,05 CCW [mm] 2,05 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 3,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3003 Cable type / seal SN 0,30 0,85 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,70 - 1,90 15305351 | 15366022 Arrangement Nominal Insul. diam [mm] 3003 0,85 / 15305351 3003 0,85 / 15366022 1,80 1,80 Cable type code legend: 3003: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 9 of 11 AVSS JIS/JA COPPER NONE PVC, X-PVC THIN Tear-out CCH force [N] [mm] 127 95 1,30 1,30 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,05 2,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,20 3,20 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,00 3,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 3004 Cable type / seal SN 0,30 0,85 | 1,25 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,70 - 2,20 15305351 Arrangement 3004 0,85 / 15305351 3004 1,25 / 15305351 Nominal Insul. diam [mm] 1,80 2,10 Cable type code legend: 3004: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 10 of 11 AVSS JIS/JA COPPER NONE PVC, XLPE, X-PVC THIN Tear-out CCH force [N] [mm] 90 135 1,30 1,40 Tol CCH [mm] 0,05 0,05 CCW [mm] 2,05 2,10 Tol CCW [mm] 0,10 0,10 ICH [mm] 3,20 3,40 Tol ICH [mm] 0,10 0,10 ICW [mm] 3,00 3,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 15326267 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 8000 Cable type / seal SN 0,30 0,75 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,70 - 1,90 15305351 Arrangement Nominal Insul. diam [mm] 8000 0,75 / 15305351 1,80 Cable type code legend: 8000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2014-07-29 Page 11 of 11 N/G COPPER NONE SYNTHRESIN THIN Tear-out CCH force [N] [mm] 85 1,30 Tol CCH [mm] 0,05 CCW [mm] 1,95 Tol CCW [mm] 0,10 ICH [mm] 3,10 Tol ICH [mm] 0,10 ICW [mm] 2,80 Tol ICW [mm] 0,10
15326267 价格&库存
很抱歉,暂时无法提供与“15326267”相匹配的价格&库存,您可以联系我们找货
    • 1+0.44770
    • 8000+0.33550
    • 16000+0.22330
    库存:131888
    15326267
      • 4500+0.20466
      库存:13500
      15326267
        • 100+0.76126
        库存:2600
