12124582
12124582
    APTIV(安波福)
12124582 数据手册
Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,32 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,05 - 2,70 15324982 Arrangement 1005 1,00 / 15324982 1005 2,00 / 15324982 Nominal Insul. diam [mm] 2,23 2,58 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 1 of 25 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 120 200 1,40 1,45 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 2,95 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,32 1,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,05 - 2,40 15324982 Arrangement 1005 1,00 / 15324982 Nominal Insul. diam [mm] 2,23 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 2 of 25 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1005 Cable type / seal SN 0,32 1,00 | 2,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,05 - 2,70 15324982 Arrangement 1005 1,00 / 15324982 1005 2,00 / 15324982 Nominal Insul. diam [mm] 2,23 2,58 Cable type code legend: 1005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 3 of 25 SAE COPPER NONE PVC, PVDF, XLPE THIN Tear-out CCH force [N] [mm] 120 200 1,40 1,45 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 2,95 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,60 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,32 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,45 - 3,10 15324982 | 15324980 Arrangement Nominal Insul. diam [mm] 1007 1,00 / 15324982 1007 2,00 / 15324980 2,58 2,98 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 4 of 25 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 120 200 1,40 1,45 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 2,95 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,32 1,00 | 2,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,45 - 3,10 15324982 | 15324980 Arrangement Nominal Insul. diam [mm] 1007 1,00 / 15324982 1007 2,00 / 15324980 2,58 2,98 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 5 of 25 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 120 200 1,40 1,45 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 2,95 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1007 Cable type / seal SN 0,32 1,00 | 2,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,45 - 3,10 15324982 | 15324980 Arrangement Nominal Insul. diam [mm] 1007 1,00 / 15324982 1007 2,00 / 15324980 2,58 2,98 Cable type code legend: 1007: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 6 of 25 SAE COPPER NONE PVC, XLPA/PVDF, XLPE REGULAR Tear-out CCH force [N] [mm] 120 200 1,40 1,45 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 2,95 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,32 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,90 - 3,95 15324981 | 15324980 Arrangement Nominal Insul. diam [mm] 1009 1,00 / 15324980 1009 2,00 / 15324981 3,17 3,73 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 7 of 25 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 120 200 1,40 1,55 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 5,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 5,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,32 1,00 | 2,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,90 - 3,95 15324980 | 15324981 Arrangement Nominal Insul. diam [mm] 1009 1,00 / 15324980 1009 2,00 / 15324981 3,17 3,73 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 8 of 25 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 120 200 1,40 1,55 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 5,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 5,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1009 Cable type / seal SN 0,32 1,00 | 2,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,90 - 3,95 15324981 | 15324980 Arrangement Nominal Insul. diam [mm] 1009 1,00 / 15324980 1009 2,00 / 15324981 3,17 3,73 Cable type code legend: 1009: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 9 of 25 SAE COPPER NONE PVC, XLPE SPECIAL Tear-out CCH force [N] [mm] 120 200 1,40 1,55 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 3,05 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 5,00 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 5,00 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal SN 0,32 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 3,35 - 3,55 15324980 Arrangement Nominal Insul. diam [mm] 1011 1,00 / 15324980 3,45 Tear-out CCH force [N] [mm] 120 1,40 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 10 of 25 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,90 Tol ICH [mm] 0,10 ICW [mm] 5,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1011 Cable type / seal SN 0,32 1,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 3,35 - 3,55 15324980 Arrangement Nominal Insul. diam [mm] 1011 1,00 / 15324980 3,45 Tear-out CCH force [N] [mm] 120 1,40 Cable type code legend: 1011: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 11 of 25 SAE COPPER NONE EAE, POLYOLEFIN, PVC, TPE, XLPE HEAVY DUTY Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,90 Tol ICH [mm] 0,10 ICW [mm] 5,00 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1025 Cable type / seal SN 0,32 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,05 - 2,40 15324982 Arrangement 1025 1,00 / 15324982 Nominal Insul. diam [mm] 2,23 Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 Cable type code legend: 1025: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 12 of 25 SAE COPPER SN FLUORPOLYM, HDPE, PBT, PE, PVC, XLPE THIN CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1025 Cable type / seal SN 0,32 1,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,05 - 2,40 15324982 Arrangement 1025 1,00 / 15324982 Nominal Insul. diam [mm] 2,23 Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 Cable type code legend: 1025: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 13 of 25 SAE COPPER SN FLUORPOLYM, HDPE, PBT, PE, PVC, XLPE THIN CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1026 Cable type / seal SN 0,32 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,45 - 3,10 15324982 | 15324980 Arrangement Nominal Insul. diam [mm] 1026 1,00 / 15324982 1026 2,00 / 15324980 2,55 2,98 Cable type code legend: 1026: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 14 of 25 SAE COPPER SN HDPE, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 120 200 1,40 1,45 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 2,95 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1026 Cable type / seal SN 0,32 2,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,85 - 3,10 15324980 Arrangement Nominal Insul. diam [mm] 1026 2,00 / 15324980 2,98 Cable type code legend: 1026: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 15 of 25 SAE COPPER SN HDPE, PVC, XLPE REGULAR Tear-out CCH force [N] [mm] 200 1,45 Tol CCH [mm] 0,05 CCW [mm] 2,95 Tol CCW [mm] 0,10 ICH [mm] 4,70 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,32 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,90 - 3,15 15324980 Arrangement Nominal Insul. diam [mm] 1094 1,00 / 15324980 3,03 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 16 of 25 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 1094 Cable type / seal SN 0,32 1,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,90 - 3,15 15324980 Arrangement Nominal Insul. diam [mm] 1094 1,00 / 15324980 3,03 Cable type code legend: 1094: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 17 of 25 SAE COPPER NONE PVC, XLPE HEAVY DUTY Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2005 Cable type / seal SN 0,32 1,50 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,20 - 2,60 15324982 Arrangement Nominal Insul. diam [mm] 2005 1,50 / 15324982 2,40 Cable type code legend: 2005: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 18 of 25 FLR2X (SAAB C) ISO COPPER NONE PVC, XLPE THIN Tear-out CCH force [N] [mm] 160 1,45 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal SN 0,32 1,00 | 1,50 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,80 - 2,61 15324982 | 15324985 Arrangement 2010 1,00 / 15324985 2010 1,50 / 15324982 2010 2,00 / 15324982 Nominal Insul. diam [mm] 1,95 2,20 2,46 Tear-out CCH force [N] [mm] 160 200 230 1,55 1,65 1,75 Tol CCH [mm] 0,05 0,05 0,05 CCW [mm] 2,40 2,40 2,40 Tol CCW [mm] 0,10 0,10 0,10 ICH [mm] 4,40 4,50 4,60 Tol ICH [mm] 0,10 0,10 0,10 ICW [mm] 4,95 4,95 4,95 Tol ICW [mm] 0,10 0,10 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2013-10-30 Page 19 of 25 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 2010 Cable type / seal SN 0,32 2,50 (V) SOLDER - VARIAC - CORE IS BARE COPPER OR TINNED 2,60 - 3,00 15324982 Arrangement 2010 2,50 / 15324982 Nominal Insul. diam [mm] 2,80 Tear-out CCH force [N] [mm] 250 1,70 Tol CCH [mm] 0,05 CCW [mm] 2,60 Tol CCW [mm] 0,10 ICH [mm] 4,75 Tol ICH [mm] 0,10 ICW [mm] 5,10 Tol ICW [mm] 0,10 Cable type code legend: 2010: ACW0219, FIAT T2 FLRY, FL RENAULT R1, FL RENAULT R3, FLR (AGP0219), FLR2X-A, FLR4Y-A, FLR9Y, FLRX-B, FLRY-A, FLRYB, FLRY-B Industry Designator: Conductor Material: Conductor Plating: Insul. Material: DIN Insul. Wall Designator: THIN File generated: 2013-10-30 Page 20 of 25 COPPER NONE PA, POLYOLEFIN, PP, PVC, SYNTHRESIN, XLCOPOLY, XLPBT, XLPE, XLPE/PVDF, XLPVC Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 7000 Cable type / seal SN 0,32 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 1,25 - 1,35 15324983 Arrangement 7000 1,00 / 15324983 1,30 Cable type code legend: 7000: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 21 of 25 Nominal Insul. diam [mm] SAE COPPER SN NONE NONE Tear-out CCH force [N] [mm] 120 1,45 Tol CCH [mm] 0,05 CCW [mm] 2,45 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 9002 Cable type / seal SN 0,32 1,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,51 - 2,72 15324982 Arrangement 9002 1,00 / 15324982 2,62 Cable type code legend: 9002: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 22 of 25 Nominal Insul. diam [mm] MISC COPPER NONE PVDF MIX Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 9002 Cable type / seal SN 0,32 1,00 (R) SOLDER - REFLOW [NON-SIR CIRCUIT] CORE IS DIP SOLD 2,51 - 2,72 15324982 Arrangement 9002 1,00 / 15324982 2,62 Cable type code legend: 9002: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 23 of 25 Nominal Insul. diam [mm] MISC COPPER NONE PVDF MIX Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 9002 Cable type / seal SN 0,32 1,00 (T) CRIMP ONLY - CORE IS DIP SOLDERED, THEN CRIMPED 2,51 - 2,72 15324982 Arrangement 9002 1,00 / 15324982 2,62 Cable type code legend: 9002: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 24 of 25 Nominal Insul. diam [mm] MISC COPPER NONE PVDF MIX Tear-out CCH force [N] [mm] 120 1,40 Tol CCH [mm] 0,05 CCW [mm] 3,00 Tol CCW [mm] 0,10 ICH [mm] 4,60 Tol ICH [mm] 0,10 ICW [mm] 4,50 Tol ICW [mm] 0,10 Crimp Information Sheet Terminal Part Number: Surface Plating: Material Thickness [mm]: Cross Section [mm²]: 12124582 Cable Type codes: Crimp Process: Insulation Range Φ[mm]: Seal(s): 9003 Cable type / seal SN 0,32 1,00 | 2,00 (C) CRIMP ONLY - TERMINAL IS APPLIED CRIMP ONLY 2,38 - 3,10 15324980 | 15324982 Arrangement 9003 1,00 / 15324982 9003 2,00 / 15324980 2,46 2,95 Cable type code legend: 9003: Industry Designator: Conductor Material: Conductor Plating: Insul. Material: Insul. Wall Designator: File generated: 2013-10-30 Page 25 of 25 Nominal Insul. diam [mm] N/G COPPER SN PVDF MIX Tear-out CCH force [N] [mm] 120 200 1,40 1,45 Tol CCH [mm] 0,05 0,05 CCW [mm] 3,00 2,95 Tol CCW [mm] 0,10 0,10 ICH [mm] 4,60 4,70 Tol ICH [mm] 0,10 0,10 ICW [mm] 4,50 4,50 Tol ICW [mm] 0,10 0,10
12124582 价格&库存
很抱歉,暂时无法提供与“12124582”相匹配的价格&库存,您可以联系我们找货
  • 2200+0.858042200+0.11109
  • 4400+0.849934400+0.11004
  • 8800+0.841828800+0.10899
库存:22000
12124582
    • 1+0.96910
    • 1000+0.62150
    • 2200+0.50930
    库存:727
    12124582
    • 99+1.4577399+0.18874
    • 250+1.37812250+0.17843
    • 500+1.11132500+0.14389
    库存:775
