13712871
13712871
    APTIV(安波福)
    1.5 Female Unsealed Tin Plating Terminal, Cable Range 0.50 -0.85 Mm2
13712871 数据手册
Etat / State MVL P/N 22.05 #0.50 DELPHI P/N 1.20 A C 5.60 A F112300 A PPI0001483 A F343100 A PPI0001484 A F443100 A A SECTION #0.10 13648599 13712871 01 13737770 01 13741954 01 13860784 01 13749482 01 13737773 01 01 125° MVL P/N F196400 - B R =F E DELPHI P/N 33510898 Revision 01 NOT AVAILABLE MVL P/N A-A Revision D A PPI0000597 PPI0000596 E F243300 E PPI0000598 - SECTION C-C SECTION D-D 33510899 33510901 F543100 E 01 F861110 33510902 01 PPI0000599 - 33510904 01 F643100 E - 33510906 01 33510908 01 33510910 01 01 Cu Ni Si NOT AVAILABLE F212300 A F961110 - F743100 A F071110 A F843100 A A GTS 2 DELPHI P/N D #0.10 PPI0001482 GTS 3 R =C ( 0.250 1.20 A 1.20 01 Revision 0.60 #0.05 33510897 Revision Pré-étamé / Pre-tinned G-G 0.80 8.00 - PPI0001580 Classe GTS 2 #0.012 ) SECTION F761110 Revision D C Material Références Pré-pisté 1.27µ Au Pré-tracked Au 1.27µ - Revision 33510900 33510903 - 01 NOT AVAILABLE MVL P/N NOT AVAILABLE 33510905 01 NOT AVAILABLE 33510907 01 NOT AVAILABLE 33510909 01 NOT AVAILABLE 33510911 01 NOT AVAILABLE 01 NOT AVAILABLE 150° NOT AVAILABLE Revision GTS 3 DELPHI P/N 5.70 3.50 2.00 Isolant pour non étanche Insulation for unsealed D - - - - - - 0.22 to 0.35 0.5 to 0.85 1.15 to 1.50 1.4 to 1.9 1 to 1.3 1.4 to 2 1.75 to 2.2 2.1 to 2.8 A 1.78 2.24 2.78 3.15 B 2.24 2.36 2.95 3.30 C 0.38 0.52 0.67 0.80 # 0.3 2.53 3.08 5.00 4.00 5.00 5.00 5.20 E 2.55 3.09 4.15 3.20 4.50 4.15 4.90 F 0.65 0.82 1.25 1.00 1.35 1.25 1.35 #0.15 #0.10 #0.10 Avec joint sur fil With wire tube 0.20 0.00 - Revision #0.15 Section / Gauge 1.40 - Avec JUF With SWS Avec JUF With SWS Avec JUF With SWS 2.20 +0.06 -0.04 #0.10 2.70 Trou sur version JUF Hole on SWS versions Marquage couloir (1 ou 2) Contact Number (1 or 2) +0.06 -0.04 H SECTION 3.00 H-H PITCH= 12 2.40 #0.10 1. H 0.65 5 + 0 0 .1 1.50 Sigle MVL MVL trademark 12.55 #0.05 B #0.10 0.40 2.36 - 0.80 #0.10 #0.10 2.80 #0.04 #0.04 B-B #0.04 2.40 SECTION #0.05 1.80 GTS 2 0.90 0.50 Version fil Wire version Version JUF SWS version - DELPHI P/N ADDED - # 0.2 - # 2° - ) NO TOLERANCED DIMENSIONS, GIVEN FOR INFORMATION A1 260 36 03 1 _ FOR CRIMP SPECIFICATION , SEE : FE CS 07 001 3_ ( SEE TABLE - NOTE : 2 _ FOR PACKAGING , SEE : PU N°077 - B GTS 3 Stephane HERNANDEZ SECTION B-B 2013/07/15 F FAURIE 2013/07/19 L DOMERGUE 2013/07/19 Patrice CAPPE 260FT0001 1.5 x 0.8 FEMALE TERMINAL K SERIAL RELEASED GTS FRA-2146 260FT0001 1 --- 1 See Table - 1:1
13712871 价格&库存
很抱歉,暂时无法提供与“13712871”相匹配的价格&库存,您可以联系我们找货
    • 5+1.09890
    • 50+1.07558
    • 150+1.06002
    库存:94
    13712871
      库存:6400
