12010996
12010996
    APTIV(安波福)
    Housing
12010996 数据手册
WEATHER-PACK Special Products L E A ED S S S E AL E D Cross Sectional View Hinged TPA Sleeve Pin Hinged TPA Cable Cable Cable Seal Connector Seal Cable Seal Female Connector Assembly Male Connector Cable Seal WEATHER-PACK FEMALE TERMINALS (SLEEVE) SEALED* Sleeve Part # Cable Range (mm2) Material Plating 12124581 3.0 Tin Brass Tin 12124580 2.0-1.0 Tin Brass Tin 15408312 0.80-0.50 Tin Brass Tin 12020801 0.35 Tin Brass Tin Female Terminal (Sleeve) *Use of the Weather-Pack 6060 gage as a process control aid is recommended for Weather-Pack terminals. See page 327 in the Application Tooling section for details. Female Connector Assembly WEATHER-PACK CABLE SEALS WEATHER-PACK FEMALE CONNECTOR ASSEMBLIES SEALED Reel Part # Loose Part # Cable Diameter Material Color # Cavities Connector Assembly Color Material 12015360 12015193 4.30-3.45 Silicone Blue 1 12015791 Black PA6 12015359 12010293 3.49-2.81 Silicone Lt. Gray 2 12015792 Black PA6 12015284 12015323 2.85-2.03 Silicone Green 3 12020829 Black PA6 12041352 12041351 2.42-2.03 Silicone Tan 4 12015798 Black PA6 12089444 12089679 2.15-1.60 Silicone Purple 4 12020832 Black PA6 12034365 12015899 1.70-1.29 Silicone Dk. Red 6 12020926 Black PA6 22 12020991 Black PA6 http://delphi.com/products/connect 242 North American Region 1-800-PACKARD European Region 49-202-291-2000 Asia Pacific Region 65-730-9900 South American Region 55-12-378-2002 WEATHER-PACK Special Products L E A ED S S S E AL E D Sealed System Application Information WEATHER-PACK TERMINALS–Tin Plated ........ 0.35-3.0 CURRENT RANGE (AMPS): TEMP RANGE OC: RESISTANCE: ......... 0-20 ........... -40 to 125 .......
12010996 价格&库存
很抱歉,暂时无法提供与“12010996”相匹配的价格&库存,您可以联系我们找货
    • 1+16.91208
    库存:689
