FC6020
FC6020
    CRC(创容)
    插件
    75UF ±5% 500V
FC6020 数据手册
26124D02 APPROVAL SHEET CRC NEW ENERGY TO: 直流支撑电容 75uF±5%500V Main Materials Construction MARKING & OUTLINE DRAWING Materials W ± 1 T ± 1 Metallized Dielectric Polypropylene Film Tinned copper Terminal H±1 MKP- FC 75 uF J Date code 500V.DC www.csdcap.com wire/plate Flame-retardant Filling ФD Flame-retardant Case P1± 1.0 plastic case,grey Part No. TYPE FC6020 Par MKP-FC 75µF J500VDC W H 57.5 50 APPROVED BY 35 52.5 20.3 6 ΦD NOTE 1.2CU CRC OFFER CHECKED BY STAMP APPROVED BY 张东泽 DATE P2±1.0 Dimensions(mm) T P1 P2 L CUSTOMER CONFIRMATION STAMP L±1 epoxy resin , white DATE PREPARED BY 李道燕 2019-10-13 SHENZHEN CRC NEW ENERGY CO., LTD 6th and 7th Floor R&D Building, Yanchuan North Industrial Park, Songgang Town, Baoan District, Shenzhen, China TEL: +86 - 0755 - 29948883 / 29948998 FAX: +86 - 0755 - 29948906 http://www.crccapacitor.com CRC-BDE-09 26124D02 Technical Data Items Symbols Values Rated capacitance CN 75µF±5% Rated voltage UN 500V.DC Non-recurrent surge voltage Us 750V.DC Irms 25.5A Maximum peak current Î 1300A Maximum surge current IS 3900A Series resistance RS ≤4.4mΩ Tangent of the loss tanδ ≤0.0037(1KHZ) Insulation Resistance C×Ris ≥5000s Le ≤15nH Lowest operating temperature Θmin -40℃ Maximum operating temperature Θmax 105℃ RH 0~95% Θstorage 85℃ Maximum current Self inductance operating humidity Storage temperature Service life 100000h At Θhotspot ≤70℃ Failure quota 300Fit Test data Voltage test between terminals A.C. voltage test between terminals and case Operating altitude Vtt 750V.DC/10S Vt-c 3000V.AC/10S 2000m(max) Terminal tightening torque _ Bottom tightening torque _ Weight kg SHENZHEN CRC NEW ENERGY CO., LTD http://www.crccapacitor.com 26124D02 ELECTRICAL CHARACTERISTICS OF FILM CAPACITOR 1. Lifetime Expectancy Lifetime(h) Lifetime(h) 1.0E+06 1.0E+06 1.0E+05 1.0E+05 1.0E+04 1.0E+04 1.0E+03 1.0E+03 40 50 60 70 80 90 Temperature(℃) Lifetime expectancy vs. Charging temperature 0.5Un 0.6Un 0.7Un 0.8Un 0.9Un 1.0Un 1.1Un 1.2Un 1.3Un Lifetime expectancy vs. Charging voltage 2. Temperature Characteristics Irms Capacitance change rate vs. Temperature Operating voltage vs. Temperature Operating current vs. Temperature (CR value) IR vs. Temperature 3. Frequency Characteristics Capacitance change rate vs. Frequency SHENZHEN CRC NEW ENERGY CO., LTD Dissipation factor vs. Frequency http://www.crccapacitor.com
FC6020 价格&库存
很抱歉,暂时无法提供与“FC6020”相匹配的价格&库存,您可以联系我们找货
FC6020
    • 1+84.24000
    • 200+32.60520
    • 500+31.46040
    • 1000+30.88800
