HS4002
HS4002
    CRC(创容)
    螺栓安装
    220NF ±10% 1.2KV
HS4002 数据手册
26124D02 APPROVAL SHEET CRC NEW ENERGY TO: 缓冲吸收电容 220nF±10% 1200V Main Materials Constru MARKING & OUTLINE DRAWING Materials ction MKP- HS 0.22uF K Dielectric Terminal Metallized datecode .1200V.DC Polypropylene Film www.csdcap.com MARKING Tinned copper plate Flame-retardant Filling epoxy resin, white L×F×N×S=14.0×15.0×8.5×6.5 Flame-retardant Case plastic case, grey Part No. TYPE HS4002 Par MKP-HS/0.22µF K 1200VDC Dimensions(mm) H T P1 W 42.5 27.5 24.5 CUSTOMER CONFIRMATION STAMP APPROVED BY 12 NOTE P 26 CRC OFFER CHECKED BY STAMP APPROVED BY PREPARED BY 田星月 DATE DATE 2019-5-17 SHENZHEN CRC NEW ENERGY CO., LTD 6th and 7th Floor R&D Building, Yanchuan North Industrial Park, Songgang Town, Baoan District, Shenzhen, China TEL: +86 - 0755 - 29948883 / 29948998 FAX: +86 - 0755 - 29948906 http://www.crccapacitor.com CRC-BDE-08 26124D02 Technical Data Items Symbols Values Rated capacitance CN 0.22µF±10% Rated voltage UN 1200V.DC Irms 10A Maximum peak current Î 220A Maximum surge current IS 660A Series resistance RS ≤7.4mΩ Tangent of the loss tanδ ≤0.0010(10KHZ) Insulation Resistance C×Ris ≥5000S Le ≤24nH Lowest operating temperature Θmin -40℃ Maximum operating temperature Θmax 105℃ operating humidity RH 0~95% Storage temperature Θstorage 105℃ Maximum current Self inductance Service life 100000h At Θhotspot ≤85℃ Failure quota <100Fit Test data Voltage test between terminals A.C. voltage test between terminals and case Vtt 1800V.DC/10S Vt-c --- Operating altitude 2000m(max) Terminal tightening torque 4.5Nm(max) Bottom tightening torque Weight SHENZHEN CRC NEW ENERGY CO., LTD 7Nm(max) -- http://www.crccapacitor.com 26124D02 ELECTRICAL CHARACTERISTICS OF FILM CAPACITOR 1. Lifetime Expectancy Lifetime(h) Lifetime(h) 1.0E+06 1.0E+06 1.0E+05 1.0E+05 1.0E+04 1.0E+04 1.0E+03 1.0E+03 40 50 60 70 80 90 Temperature(℃) Lifetime expectancy vs. Charging temperature 0.5Un 0.6Un 0.7Un 0.8Un 0.9Un 1.0Un 1.1Un 1.2Un 1.3Un Lifetime expectancy vs. Charging voltage 2. Temperature Characteristics Irms Capacitance change rate vs. Temperature Operating voltage vs. Temperature Operating current vs. Temperature (CR value) IR vs. Temperature 3. Frequency Characteristics Capacitance change rate vs. Frequency SHENZHEN CRC NEW ENERGY CO., LTD Dissipation factor vs. Frequency http://www.crccapacitor.co m
HS4002 价格&库存
很抱歉,暂时无法提供与“HS4002”相匹配的价格&库存,您可以联系我们找货
HS4002
    • 1+22.10760
    • 10+19.21320
    • 42+16.41600
    库存:24
