HS5067
HS5067
    CRC(创容)
    螺栓安装
    3UF ±5% 1.2KV
HS5067 数据手册
26124D02 APPROVAL SHEET CRC NEW ENERGY TO: 缓冲吸收电容 3uF±5% 1200V Main Materials Constru MARKING & OUTLINE DRAWING MKP- HS 3.0UF J Materials ction datecode .1200V.DC Metallized Dielectric www.csdcap.com Polypropylene Film Terminal MARKING Tinned copper plate Flame-retardant Filling epoxy resin, white L×F×N×S=14.0×15.0×8.3×6.2 Flame-retardant Case plastic case, grey Part No. TYPE HS5067 Par MKP-HS 3.0µF J1200VDC Dimensions(mm) H T P1 W 57.5 45 CUSTOMER CONFIRMATION STAMP APPROVED BY 30 8 NOTE P 22 CRC OFFER CHECKED BY STAMP APPROVED BY PREPARED BY 闫佳佳 DATE DATE 2020-03-28 SHENZHEN CRC NEW ENERGY CO., LTD 6th and 7th Floor R&D Building, Yanchuan North Industrial Park, Songgang Town, Baoan District, Shenzhen, China TEL: +86 - 0755 - 29948883 / 29948998 FAX: +86 - 0755 - 29948906 http://www.csdcap.com CRC-BDE-08 26124D02 Technical Data Items Symbols Values Rated capacitance CN 3.0µF±5% Rated voltage UN 1200V.DC Non-recurrent surge voltage Us 1900V.DC Irms 10A Maximum peak current Î 470A Maximum surge current IS 1410A Series resistance RS ≤30mΩ Tangent of the loss tanδ ≤0.0015(10KHZ) Insulation Resistance C×Ris ≥5000S Le ≤24nH Θmin -40℃ Storage temperature Θstorage 105℃ Operating humidity RH 0~95% Maximum current Self inductance Lowest operating temperature Service life 100000h Failure quota <100Fit Test data Voltage test between terminals Operating altitude Vtt 1800V.DC/10S 1000m(max) Terminal tightening torque --- Bottom tightening torque --- Weight --- SHENZHEN CRC NEW ENERGY CO., LTD http://www.csdcap.com 26124D02 ELECTRICAL CHARACTERISTICS OF FILM CAPACITOR 1. Lifetime Expectancy Lifetime expectancy vs. Charging temperature Lifetime expectancy vs. Charging voltage 2. Temperature Characteristics Irms Capacitance change rate vs. Temperature Operating voltage vs. Temperature Operating current vs. Temperature (CR value) IR vs. Temperature 3. Frequency Characteristics Capacitance change rate vs. Frequency Dissipation factor vs. Frequency
HS5067 价格&库存
很抱歉,暂时无法提供与“HS5067”相匹配的价格&库存,您可以联系我们找货
HS5067
    • 1+34.51680
    • 10+29.74320
    • 25+25.30440
    库存:7
