111-00291
111-00291
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 111-00291 - Cable Tie, Stainless Steel, Black, 521 mm, 4.6 mm, 152 mm, 540 N
111-00291 数据手册
Cable Ties and Fixings Cable Ties, Stainless Steel 1.5 Cable Ties with Ball-Lock MBT-Series, Stainless Steel 304 Metal ties are ideal for all applications that require high strength, reliability and fire resistance. The MBT range of stainless steel cable ties can be used in chemical industries and on oil platforms as well as in mass transit, shipbuilding and mining industries. MBT ties are also suitable for machine building, apparatus construction and in the outside area of radio technology. Additionally, MBT ties are ideal for securing lighting in theatres and exhibition halls. Features and Benefits • MBT cable ties made from stainless steel 304 • Patented non-releasable locking feature • Corrosion resistant • Weather resistant • Outstanding chemical resistance • High temperature resistance • Non-burning L W MBT-Series 4.6 mm and 7.9 mm width L Stainless Steel Cable Ties, uncoated, MBT_SS, MBT_HS. Stainless Steel Cable Ties, uncoated, MBT_XHS. Patented Material specification please see page 24. The MBT-Series (up to 7.9 mm) can be used in combination with the stainless steel P-Mount. The mount is simple to install with a screw or bolt and ensures a durable fixing solution. Please see page 143. W MBT-Series 12.3 mm width Width (W) Length (L) Bundle Ø min. Bundle Ø max. MBT5SS 4.6 127.0 12.0 25.0 MBT8SS 4.6 201.0 17.0 MBT14SS 4.6 362.0 17.0 MBT20SS 4.6 521.0 17.0 MBT27SS 4.6 685.0 17.0 MBT33SS 4.6 838.0 17.0 MBT8HS 7.9 201.0 17.0 MBT14HS 7.9 362.0 MBT20HS 7.9 MBT27HS 7.9 MBT33HS MBT14XHS MBT20XHS MBT27XHS MBT33XHS Date of issue: October 2015 TYPE Material Pack Cont. Tools Article-No. 900 SS304 100 pcs. 15-18 111-93058 50.0 900 SS304 100 pcs. 15-18 111-93088 102.0 900 SS304 100 pcs. 15-18 111-93148 152.0 900 SS304 100 pcs. 15-18 111-93208 203.0 900 SS304 100 pcs. 15-18 111-93278 254.0 900 SS304 100 pcs. 15-18 111-93338 50.0 2,000 SS304 50 pcs. 15-18 111-94088 17.0 102.0 2,000 SS304 50 pcs. 15-18 111-94148 521.0 17.0 152.0 2,000 SS304 50 pcs. 15-18 111-94208 685.0 17.0 203.0 2,000 SS304 50 pcs. 15-18 111-94278 7.9 838.0 17.0 254.0 2,000 SS304 50 pcs. 15-18 111-94338 12.3 362.0 17.0 102.0 2,700 SS304 50 pcs. 15-18 111-95148 12.3 521.0 17.0 152.0 2,700 SS304 50 pcs. 15-18 111-95208 12.3 681.0 17.0 203.0 2,700 SS304 50 pcs. 15-18 111-95278 12.3 838.0 17.0 254.0 2,700 SS304 50 pcs. 15-18 111-95338 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 15 16 17 18 MK9SST MK9PSST HDT16 KST-STG200 For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/fixings 83 Cable Ties and Fixings 1.5 Cable Ties, Stainless Steel Cable Ties with Ball-Lock MBT-Series, Stainless Steel 316 Metal ties are ideal for all applications that require high strength, reliability and fire resistance. The MBT range of stainless steel cable ties can be used in chemical industries and on oil platforms as well as in mass transit, shipbuilding and mining industries. MBT ties are also suitable for machine building, apparatus construction and in the outside area of radio technology. Additionally, MBT ties are ideal for securing lighting in theatres and exhibition halls. Features and Benefits • MBT cable ties made from stainless steel 316 • Patented non-releasable locking feature • Corrosion resistant • Weather resistant • Outstanding chemical resistance • Antimagnetic • High temperature resistance • Non-burning Stainless Steel Cable Ties, uncoated, MBT_S, MBT_H. The MBT-Series (up to 7.9 mm) can be used in combination with the stainless steel P-Mount. The mount is simple to install with a screw or bolt and ensures a durable fixing solution. Please see page 143. Patented L W MBT-Series 4.6 mm and 7.9 mm width TYPE Width (W) Length (L) Bundle Ø min. Bundle Ø max. Material Pack Cont. Tools Article-No. MBT5S 4.6 127.0 12.0 25.0 MBT8S 4.6 201.0 12.0 50.0 900 SS316 100 pcs. 15-18 111-93059 900 SS316 100 pcs. 15-18 111-93089 MBT14S 4.6 362.0 12.0 MBT20S 4.6 521.0 12.0 102.0 900 SS316 100 pcs. 15-18 111-93149 152.0 900 SS316 100 pcs. 15-18 111-93209 MBT27S 4.6 685.0 MBT33S 4.6 838.0 12.0 203.0 900 SS316 100 pcs. 15-18 111-93279 12.0 254.0 900 SS316 100 pcs. 15-18 MBT8H 7.9 111-93339 201.0 12.0 50.0 2,000 SS316 50 pcs. 15-18 111-94089 MBT14H MBT20H 7.9 362.0 12.0 102.0 2,000 SS316 50 pcs. 15-18 111-94149 7.9 521.0 12.0 152.0 2,000 SS316 50 pcs. 15-18 111-94209 MBT27H 7.9 685.0 12.0 203.0 2,000 SS316 50 pcs. 15-18 111-94279 MBT33H 7.9 838.0 12.0 254.0 2,000 SS316 50 pcs. 15-18 111-94339 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. 15 16 17 18 MK9SST MK9PSST HDT16 KST-STG200 For more information on toolings please refer to the Application Tooling chapter. For product specific approvals and specifications please refer to the Appendix. 84 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 Recommended Tools Cable Ties and Fixings Cable Ties, Stainless Steel 1.5 Cable Ties with Ball-Lock MBT-Series, Stainless Steel 316 L W MBT-Series 12.3 mm width L Material specification please see page 24. W MBT-Series 16.0 mm width Width (W) Length (L) Bundle Ø min. Bundle Ø max. MBT14XH 12.3 362.0 12.0 102.0 MBT20XH 12.3 521.0 12.0 152.0 MBT27XH 12.3 681.0 12.0 MBT33XH 12.3 838.0 MBT14UH 16.0 362.0 MBT20UH 16.0 MBT27UH 16.0 MBT33UH 16.0 838.0 12.0 254.0 4,100 SS316 50 pcs. 15;17 111-01304 MBT43UH 16.0 1,092.0 12.0 330.0 4,100 SS316 25 pcs. 15;17 111-01305 MBT49UH 16.0 1,245.0 12.0 380.0 4,100 SS316 25 pcs. 15;17 111-01306 TYPE Material Pack Cont. Tools Article-No. 2,700 SS316 50 pcs. 15-18 111-95149 2,700 SS316 50 pcs. 15-18 111-95209 203.0 2,700 SS316 50 pcs. 15-18 111-95279 12.0 254.0 2,700 SS316 50 pcs. 15-18 111-95339 12.0 102.0 4,100 SS316 50 pcs. 15;17 111-01301 521.0 12.0 152.0 4,100 SS316 50 pcs. 15;17 111-01302 681.0 12.0 203.0 4,100 SS316 50 pcs. 15;17 111-01303 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 15 16 17 18 MK9SST MK9PSST HDT16 KST-STG200 Date of issue: October 2015 For more information on toolings please refer to the Application Tooling chapter. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/fixings 85 Cable Ties and Fixings 1.5 Cable Ties, Stainless Steel Double Wrap Cable Ties with Ball-Lock MBTXHD- / MBTUHD-Series, Stainless Steel 316 The double wrap ties of the MBT-series are used in applications where a fixing requires an extraordinary high tensile strength. Features and Benefits • Stainless steel MBT ties with double wrap operation • Wraps around the bundle and passes through the head twice • Very high tensile strength to carry enormous applied loads • Head with two locking balls • Resistant to arduous conditions and environments Double wrap Stainless Steel Cable Ties, uncoated, MBT_UHD. Patented Material specification please see page 24. L W MBT-Series 12.3 mm width Double wrap Stainless Steel Cable Ties, uncoated MBT_UHD. L W MBT-Series 16.0 mm width TYPE Width (W) Length (L) Bundle Ø min. Bundle Ø max. Material Pack Cont. Tools Article-No. MBT27XHD 12.3 681.0 17.0 100.0 5,000 SS316 50 pcs. 15-18 111-01307 MBT33XHD 12.3 838.0 17.0 120.0 5,000 SS316 50 pcs. 15-18 111-01308 MBT43XHD 12.3 1,092.0 17.0 160.0 5,000 SS316 25 pcs. 15-18 111-01309 MBT49XHD 12.3 1,245.0 17.0 180.0 5,000 SS316 25 pcs. 15-18 111-01310 MBT60XHD 12.3 1,524.0 17.0 230.0 5,000 SS316 25 pcs. 15-18 111-01311 MBT27UHD 16.0 681.0 25.0 100.0 7,000 SS316 50 pcs. 15;17 111-01312 MBT33UHD 16.0 838.0 25.0 120.0 7,000 SS316 50 pcs. 15;17 111-01313 MBT43UHD 16.0 1,092.0 25.0 160.0 7,000 SS316 25 pcs. 15;17 111-01314 MBT49UHD 16.0 1,245.0 25.0 180.0 7,000 SS316 25 pcs. 15;17 111-01315 MBT60UHD 16.0 1,524.0 25.0 230.0 7,000 SS316 25 pcs. 15;17 111-01316 Recommended Tools 15 16 17 18 MK9SST MK9PSST HDT16 KST-STG200 For more information on toolings please refer to the Application Tooling chapter. 86 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Cable Ties and Fixings Cable Ties, Stainless Steel 1.5 Cable Ties with Ball-Lock and Coating MBT-FC-Series, Stainless Steel 316 The MBT range of stainless steel cable ties can be used in the most arduous of conditions or where the additional security, strength and fire resistance of a metal fixing is required. Used in all areas from mass transit, ship building, oil rigs, mining and chemical industries to theatres and exhibition halls. In the event of a fire, cables will remain securely held in place and will not fall to block emergency exits. Features and Benefits • Fully coated MBT, made from type 316 stainless steel with polyester coating • Patented non-releasable locking feature • Coated cable tie with smooth edges • Comfortable handling and installation • Eliminates contact corrosion between dissimilar materials during application Stainless Steel Cable Ties, coated, MBT_SFC, MBT_HFC. Patented The MBT-Series (up to 7.9 mm) can be used in combination with the stainless steel P-Mount. The mount is simple to install with a screw or bolt and ensures a durable fixing solution. Please see page 143. Stainless Steel Cable Ties, coated, MBT_XHFC. L W MBT-Series 4.6 mm and 7.9 mm width TYPE Width (W) Length (L) Bundle Ø min. Bundle Ø max. 4.6 127.0 15.0 25.0 Date of issue: October 2015 MBT5SFC 540 Material Pack Cont. Tools Article-No. SS316, SP 100 pcs. 15-18 111-00288 MBT8SFC 4.6 201.0 17.0 50.0 540 SS316, SP 100 pcs. 15-18 111-00289 MBT14SFC 4.6 362.0 17.0 102.0 540 SS316, SP 100 pcs. 15-18 111-00290 MBT20SFC 4.6 521.0 17.0 152.0 540 SS316, SP 100 pcs. 15-18 111-00291 MBT27SFC 4.6 681.0 17.0 203.0 540 SS316, SP 100 pcs. 15-18 111-00292 MBT33SFC 4.6 838.0 17.0 254.0 540 SS316, SP 100 pcs. 15-18 111-00293 MBT8HFC 7.9 201.0 17.0 50.0 1,020 SS316, SP 50 pcs. 15-18 111-00294 MBT14HFC 7.9 362.0 17.0 102.0 1,020 SS316, SP 50 pcs. 15-18 111-00295 MBT20HFC 7.9 521.0 17.0 152.0 1,020 SS316, SP 50 pcs. 15-18 111-00296 MBT27HFC 7.9 681.0 17.0 203.0 1,020 SS316, SP 50 pcs. 15-18 111-00297 MBT33HFC 7.9 838.0 17.0 254.0 1,020 SS316, SP 50 pcs. 15-18 111-00298 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 15 16 17 18 MK9SST MK9PSST HDT16 KST-STG200 For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/fixings 87 Cable Ties and Fixings 1.5 Cable Ties, Stainless Steel Cable Ties with Ball-Lock and Coating MBT-FC-Series, Stainless Steel 316 L W MBT-Series 12.3 mm width L Material specification please see page 24. W MBT-Series 16.0 mm width TYPE Width (W) Length (L) Bundle Ø min. Bundle Ø max. Material Pack Cont. Tools Article-No. MBT14XHFC 12.3 362.0 17.0 102.0 1,620 SS316, SP 50 pcs. 15-18 111-00299 MBT17XHFC 12.3 434.0 17.0 125.0 1,620 SS316, SP 50 pcs. 15-18 111-01500 MBT20XHFC 12.3 521.0 17.0 152.0 1,620 SS316, SP 50 pcs. 15-18 111-00300 MBT23XHFC 12.3 575.0 17.0 168.0 1,620 SS316, SP 50 pcs. 15-18 111-01501 MBT27XHFC 12.3 681.0 17.0 203.0 1,620 SS316, SP 50 pcs. 15-18 111-00301 MBT30XHFC 12.3 754.0 17.0 225.0 1,620 SS316, SP 50 pcs. 15-18 111-01502 MBT33XHFC 12.3 838.0 17.0 254.0 1,620 SS316, SP 50 pcs. 15-18 111-00302 MBT43XHFC 12.3 1,092.0 17.0 330.0 1,620 SS316, SP 25 pcs. 15-18 111-01503 MBT49XHFC 12.3 1,245.0 17.0 380.0 1,620 SS316, SP 25 pcs. 15-18 111-01504 MBT14UHFC 16.0 362.0 25.0 102.0 2,500 SS316, SP 50 pcs. 15;17 111-01512 MBT17UHFC 16.0 434.0 25.0 125.0 2,500 SS316, SP 50 pcs. 15;17 111-01513 MBT20UHFC 16.0 521.0 25.0 152.0 2,500 SS316, SP 50 pcs. 15;17 111-01514 MBT23UHFC 16.0 575.0 25.0 168.0 2,500 SS316, SP 50 pcs. 15;17 111-01515 MBT27UHFC 16.0 681.0 25.0 203.0 2,500 SS316, SP 50 pcs. 15;17 111-01516 MBT30UHFC 16.0 754.0 25.0 225.0 2,500 SS316, SP 50 pcs. 15;17 111-01517 MBT33UHFC 16.0 838.0 25.0 254.0 2,500 SS316, SP 50 pcs. 15;17 111-01518 MBT43UHFC 16.0 1,092.0 25.0 330.0 2,500 SS316, SP 25 pcs. 15;17 111-01519 MBT49UHFC 16.0 1,245.0 25.0 380.0 2,500 SS316, SP 25 pcs. 15;17 111-01520 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 15 16 17 18 MK9SST MK9PSST HDT16 KST-STG200 Date of issue: October 2015 For more information on toolings please refer to the Application Tooling chapter. 88 Further information at www.HellermannTyton.com/fixings Cable Ties and Fixings Cable Ties, Stainless Steel 1.5 Double Wrap Cable Ties with Ball-Lock and Coating MBTXHDFC- / MBTUHDFC-Series, Stainless Steel 316 The MBT range of stainless steel cable ties can be used in the most arduous of conditions or where the additional security, strength and fire resistance of a metal fixing is required. Used in all areas from mass transit, ship building, oil rigs, mining and chemical industries to theatres and exhibition halls. In the event of a fire, cables will remain securely held in place and will not fall to block emergency exits. Features and Benefits • MBT cable ties, made from stainless steel SS316 with a polyester coating • Patented non-releasable locking feature • Double wrap operation • Corrosion resistant • Weather resistant • Outstanding chemical resistance • Antimagnetic • High temperature resistant • Non-burning Stainless Steel Cable Ties, coated, MBT_UHDFC. L W Patented MBT-Series 12.3 mm width L W MBT-Series 16.0 mm width TYPE MBT27XHDFC Width (W) Length (L) Bundle Ø min. Bundle Ø max. 12.3 681.0 17.0 100.0 Material Pack Cont. Tools Article-No. 2,500 SS316, SP 50 pcs. 15-18 111-01505 MBT33XHDFC 12.3 838.0 17.0 120.0 2,500 SS316, SP 50 pcs. 15-18 111-01506 MBT43XHDFC 12.3 1,092.0 17.0 160.0 2,500 SS316, SP 25 pcs. 15-18 111-01507 MBT49XHDFC 12.3 1,245.0 17.0 180.0 2,500 SS316, SP 25 pcs. 15-18 111-01508 MBT60XHDFC 12.3 1,524.0 17.0 230.0 2,500 SS316, SP 25 pcs. 15-18 111-01509 MBT27UHDFC 16.0 681.0 25.0 100.0 5,000 SS316, SP 50 pcs. 15;17 111-01521 MBT33UHDFC 16.0 838.0 25.0 120.0 5,000 SS316, SP 50 pcs. 15;17 111-01522 MBT43UHDFC 16.0 1,092.0 25.0 160.0 5,000 SS316, SP 25 pcs. 15;17 111-01523 MBT49UHDFC 16.0 1,245.0 25.0 180.0 5,000 SS316, SP 25 pcs. 15;17 111-01524 MBT60UHDFC 16.0 1,524.0 25.0 230.0 5,000 SS316, SP 25 pcs. 15;17 111-01525 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Date of issue: October 2015 Recommended Tools 15 16 17 18 MK9SST MK9PSST HDT16 KST-STG200 For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/fixings 89 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25
111-00291 价格&库存
很抱歉,暂时无法提供与“111-00291”相匹配的价格&库存,您可以联系我们找货
  • 100+26.89061
  • 500+24.59083
  • 1500+21.48853
  • 100+26.78474100+3.46910
  • 500+24.42908500+3.16400
  • 1500+21.375451500+2.76850
