151-00300
151-00300
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 151-00300 - Fastener, Adhesive Backed Cable Clamp, Steel, White, 43 mm, 31 mm
151-00300 数据手册
SAC3 - Cable Tie Mounts self adhesive/screw fixing - HellermannTyton 1 of 1 http://www.hellermanntyton.co.uk/BaseCMP/pages/contentdelivery?... United Kingdom SAC3 151-00300 The metal 'tongue' can be bent to suit any shape or configuration of wires or cables. Cost effective with easy application on smooth, clean surfaces. These clips are ideal for use in applications which are difficult to access, or for areas where self adhesive is the only possible fixing method (for example 'holes' would be unacceptable). Typically applications include domestic appliances and trailers. SAC-Series Self Adhesive Clip Base Data Colour White (WH) Label E-Number Norway 13 240 03 Package Content 100 Quantity (Sold Unit / EDP) 100 Logisitic and Packaging Carton Quantity 0 EAN code 4031026122120 Quantity of Europallet 0 Weight (kg) (Metric) 0.61 kg Material and Specifications Adhesive Acrylate with base of Polyethylene foam Adhesive Operating Temperature (Metric) -40 °C to +70 °C Material Steel (ST) Material Shortcut ST Operating Temperature (Metric) -40 °C to +70 °C Shortcut Adhesive Acrylate Product Dimensions Bundle Diameter max (Metric) 12.0 Length L (Metric) 44.0 Width W (Metric) 33.0 © HellermannTyton 2006 08/08/2006 13:57
151-00300 价格&库存
很抱歉,暂时无法提供与“151-00300”相匹配的价格&库存,您可以联系我们找货
