143_154_chapter 1.5_prod 07_08_gb_2005_1484.qxp
25.09.2008
11:06
Seite 153
Cable Ties and Fixings
Cable and Wire Mounts
1.5
LOK Fixing Base
Features and Benefits
The LOK01 - LOK05 were primarily designed
to be used with the RPE and PE series of
cable ties but will function just as well with
any cable ties up to 9 mm wide.
Suitable for use in a wide range of materials
including, concrete, brick, block or wood.
Installed by knocking into a 7 mm or 8 mm
diameter hole (depending on the material).
The LOK01B is designed for soft brickwork
and 6 mm holes. Because of its elongated
head, the bundles can be located at a distance from the brickwork with the LOK05.
Application
The LOK mounts, in conjunction with a cable
tie can be used either indoors or outdoors
for a diverse range of applications from
holding climbing plants, to securing cables
running between buildings.
LOK01, LOK01B, LOK01S Fixing Base
LOK05 Fixing Base
LOK02 Fixing Base
Material Data
LOK04 Fixing Base
Material Data
Material
Polyamide 6.6 (PA66)
Material
Operating
Temperature
-40 °C to +85 °C Continuous,
(+105 °C for 500 h)
Flammability
UL94 V2
halogenfree
Polyamide 6
high impact modified (PA6HIR)
Operating
Temperature
-40 °C to +105 °C Continuous,
(+105 °C for 500 h)
Flammability
UL94 HB
Technical Table
Article-No.
Type
Length Length Length
(L)
(L2)
(L3)
Width
(W)
ØD
Strap Width max.
(G)
Fixing Hole Ø
(FH)
Colour
Material
151-80110 LOK01
44.0
6.5
2.5
12.0
9.2
9.0
7.0-8.0
Black (BK)
PA6HIR
151-80210 LOK02
21.0
18.0
14.0
9.0
4.9-5.1
Black (BK)
PA6HIR
151-80500 LOK01B
30.0
6.5
2.5
12.0
7.2
9.0
6.0
Black (BK)
PA6HIR
151-80600 LOK01S
34.0
6.5
2.5
12.0
9.2
9.0
7.0-8.0
Black (BK)
PA6HIR
151-80700 LOK05
49.0
12.5
2.5
12.0
9.2
9.0
7.0-8.0
Black (BK)
PA66
151-80410 LOK04
4.0
16.0
9.0
Black (BK)
PA66
All dimensions in mm. Subject to technical changes.
153
很抱歉,暂时无法提供与“151-80110”相匹配的价格&库存,您可以联系我们找货
