252_259_chapter 3.1_prod07_08_gb.qxp
25.09.2008
13:55
Seite 259
Cable Protection Systems
P r o t e c t i v e Tu b i n g
3.1
Heladuct HTC
Flexible Cable Support
Features and Benefits
The HTC cable supports are a space-saving
wiring system which holds the routed cable
clearly open to view. Cables can be routed in
or out over the whole length of the support.
The supports can be rapidly mounted either
with screws or an adhesive strip. The highquality foam bonding layer smooths over
irregularities in the underlying surface and
works particularly well on powder-coated
surfaces. Due to their flexibility, it is possible
to install the supports at 90º angles.
Application
HTC cable supports are commonly used in
switching cabinets. They are also used in
the furniture industry, where cables need to
be routed rapidly and attractively.
Simple and efficient cable and wire routing with the flexible Heladuct cable support.
Material Data
Material
Colour
Operating
Temperature
Adhesive
Flammability
Polypropylene (PP)
White (WH)
-20 °C to +70 °C
Synthetic rubber with base of polyethylene foam
UL94 V0 (excluding adhesive)
halogenfree
HTC20-HTC40
HTC10SK
Technical Table
No. of Wires
Article-No.
Screwable
Type
ØD
0,75 mm2 1,5 mm2 2,5 mm2
Max. load on a length
of 500 mm at 70 °C (g)
164-10008 HTC10
9 x 11
9
6
4
100
164-20008 HTC20
22
14
300
164-30008 HTC30
30
67
50
34
650
164-40008 HTC40
40
81
60
1100
Adhesive
164-10108 HTC10SK
9 x 11
9
6
4
100
164-20108 HTC20SK
22
14
300
164-30108 HTC30SK
30
67
50
34
500
164-40108 HTC40SK
40
81
60
400
All dimensions in mm. Subject to technical changes.
Supplied in 500mm length. Sk = Adhesive
Please Note for Product Specific Approvals please refer to the Appendix
259
很抱歉,暂时无法提供与“164-11108”相匹配的价格&库存,您可以联系我们找货
