184-11006
184-11006
    HELLERMAN(海尔曼太通)
    HDSLOTTEDDUCT1X16'
184-11006 数据手册
Home Worldwide Events Careers How To Buy Products Cable Ties Search Contact Industries Resources News About Us SLHD1X1W4 Cable Ties with Fasteners Find a Distributor High Density Slotted Duct - 1"" X 1"" Non-Adhesive, PVC, White, 120' / carton Cable Tie Tools Order Samples Clamps and Clips Mounts Article Number: 184 - 11006 Heavy Duty Mounts Part Number: SLHD1X1W4 Wiring Duct Type: SLHD1X1 Material: PVC Solid Wall Get Technical Drawings Slotted Wall High Density Slotted Wall Covers Accessories Wiring Protection Labels, Printers and Software Pre - Terminated Networking 1. Base Data Copper Network Solutions Fiber Network Solutions Jacks and Wall Plates Part No. SLHD1X1W4 Type SLHD1X1 Color White Features High density slotted wall duct comes with narrow fingers, equaling a 2 - to - 1 finger ratio compared to standard slotted wiring duct. Narrow fingers reduce fanning of the wires to the terminal blocks. Compact designs and components are more easily accommodated with the high density ductâ €™s 2 - to - 1 finger ratio. High density duct also incorporates the double scored design, similar to the standard slotted wall duct. With sizes 2â €? high and above, high density duct features a double restriction on each finger of the duct. The double restriction helps retain wires in the bottom portion of the duct for easier installation. Mounting holes are uniform in size to the solid and slotted wall duct, but are offered every 2 inches to accommodate compact designs and installations. Residential Solutions Racks - Cable Management Surface Raceway Systems 2. Product Dimensions Length (L) 6 ft / 1.83 m Width (W) 1.00 " / 25.4 Width (W2) 1.00 " / 25.4 mm Width (W3) 4.1 mm Width (W4) .40 " / 10.2 mm Width (W5) .75 " / 19.1 mm Height (H) 1.05 " / 26.7 mm Mounting Hole Centers 2.00 " / 50.80 mm 4. Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Certification CSA / UL CSA Certified Yes Flammability self - extinguishing Material Specification RoHS Operating Temperature +122 °F (+50 °C) Logistic and Packaging Packaging Type carton Pkg. Qty. 120 ft / 36.6 m Carton Qty. 120 UPC 08930611331 Miscellaneous UL Recognized (US and Canada) Yes Width (W3) .16 " Find a Distributor Get Product Samples Get Technical Drawings Customers Who Bought This Item Also Bought Wiring Duct Cover Width 1.00"" PVC, White, 120' / Pkg. Qty. Part No: TC1W4 Article No: 181 - 91008 Cable Tie, 18lb., 3.27"", Max. Bun. Dia .87"" PA66, Natural, 1000/pk Part No: T18R9M4 Article No: 111 - 01872 High Density Slotted Duct - 1"" X 3"" Non - Adhesive, PVC, White, 120' / carton Part No: SLHD1X3W4 Article No: 184 - 13007 Cable Tie, 50 lb. 7.9"" Max. Bun. Dia. 1.97"", PA66, Black, 1000/pk Part No: T50R0M4 Article No: 111 - 04846 High Density Slotted Duct - 2"" X 2"" Non - Adhesive, PVC, White, 120' / carton Part No: SLHD2X2W4 Article No: 184 - 22008 This product was foundWiring in Duct> High Density Slotted Wall Home About HellermannTyton Products Careers Contact Terms © HellermannTyton North America 2008 TS16949:2002 , ISO 9001:2000 7930 N. Faulkner Rd. Milwaukee, WI 53224 - 9517 Fax: 800 - 848 - 9866 and ISO14001 Certified Phone: 800 - 537 - 1512
184-11006 价格&库存
很抱歉,暂时无法提供与“184-11006”相匹配的价格&库存,您可以联系我们找货
