305-01600
    HELLERMAN(海尔曼太通)
305-01600 数据手册
Insulation Heat Shrinkable Tubing 2.1 Heat Shrinkable Tubing 2:1 flexible and coloured HFT-A - self extinguishing This high performance thin wall tubing is used extensively for electrical and mechanical protection. It is also well proven for sleeve marking to identify wiring circuits. It shrinks uniformly to form a permanent insulation covering. The transparent version is used for bundling and cable protection where visual inspection is required. It is often used as a see through protective sleeve over cable markers. Features and Benefits • Flexible heat shrink tubing • Fast shrinking, easy handling, good mechanical strength • Easy to print on • Wide range of colours • Internal diameters up to 4 inches (101.6 mm) • UL-224 ,CSA listed and VG approved HFT-A conforms to major standards used in all Defence industries. Standard sizes available in colours black, red, blue, yellow, white and green-yellow. MATERIAL Polyolefin, cross-linked (PO-X) Shrink Ratio 2:1 Operating Temperature -55 °C to +135 °C Minimum Shrink Temperature +100 °C Longitudinal change after shrinkage +5 %/-10 % Dielectric Strength 20 kV/mm according to IEC 60684 P2 Flammability Self extinguishing Specifications ASN-E0126, CSA, DEF STAN 59-97/3, LEA, MIL-DTL-23053/5C, NF F 00-608, NSA937211, PAN6493, SAE - AMS DTL-23053 / 5C, UL224 125 °C 600V, VG 95343 Heat Shrinkable Tubing 2:1 TYPE HFT-A-1.2/0.6 HFT-A-1.6/0.8 Supplied Ø D min. Size (imperial) Recov. Ø d max. Wall (WT) Reel Length Colour Designation as per VG-Norm 1.2 3/64 " 0.6 0.40 400 m Black (BK) VG 95343 T05 A 001A 305-01200 1.2 3/64 " 0.6 0.40 400 m Blue (BU) VG 95343 T05 A 001 G 305-01206 1.2 3/64 " 0.6 0.40 400 m Red (RD) VG 95343 T05 A 001 C 305-01202 1.2 3/64 " 0.6 0.40 400 m White (WH) VG 95343 T05 A 001 L 305-01209 1.2 3/64 " 0.6 0.40 400 m Yellow (YE) VG 95343 T05 A 001 E 305-01204 1.6 1/16 " 0.8 0.40 400 m Black (BK) VG 95343 T05 A 002 A 305-01600 1.6 1/16 " 0.8 0.40 400 m Blue (BU) VG 95343 T05 A 002 G 305-01606 1.6 1/16 " 0.8 0.40 400 m Red (RD) VG 95343 T05 A 002 C 305-01602 1.6 1/16 " 0.8 0.40 400 m White (WH) VG 95343 T05 A 002 L 305-01609 1.6 1/16 " 0.8 0.40 400 m Yellow (YE) VG 95343 T05 A 002 E 305-01604 Article-No. Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. ASN LEA For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation 211 Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing 2:1 flexible and coloured HFT-A - self extinguishing Heat Shrinkable Tubing 2:1 TYPE HFT-A-2.4/1.2 HFT-A-3.2/1.6 HFT-A-4.8/2.4 HFT-A-6.4/3.2 HFT-A-9.5/4.8 HFT-A-12.7/6.4 Supplied Ø D min. Size (imperial) Recov. Ø d max. Wall (WT) Reel Length Colour Designation as per VG-Norm Article-No. 2.4 3/32 " 1.2 0.50 100 m Blue (BU) VG 95343 T05 A 003 G 305-02406 2.4 3/32 " 1.2 0.50 100 m Red (RD) VG 95343 T05 A 003 C 305-02402 2.4 3/32 " 1.2 0.50 100 m White (WH) VG 95343 T05 A 003 L 305-02409 2.4 3/32 " 1.2 0.50 100 m Yellow (YE) VG 95343 T05 A 003 E 305-02404 2.4 3/32 " 1.2 0.50 400 m Black (BK) VG 95343 T05 A 003 A 305-02400 3.2 1/8 " 1.6 0.50 100 m Blue (BU) VG 95343 T05 A 004 G 305-03206 3.2 1/8 " 1.6 0.50 100 m Green-Yellow (GNYE) VG 95343 T05 A 004 N 305-03245 3.2 1/8 " 1.6 0.50 100 m Red (RD) VG 95343 T05 A 004 C 305-03202 3.2 1/8 " 1.6 0.50 100 m White (WH) VG 95343 T05 A 004 L 305-03209 3.2 1/8 " 1.6 0.50 100 m Yellow (YE) VG 95343 T05 A 004 E 305-03204 3.2 1/8 " 1.6 0.50 400 m Black (BK) VG 95343 T05 A 004 A 305-03200 4.8 3/16 " 2.4 0.50 75 m Blue (BU) VG 95343 T05 A 005 G 305-04806 4.8 3/16 " 2.4 0.50 75 m Green-Yellow (GNYE) VG 95343 T05 A 005 N 305-04845 4.8 3/16 " 2.4 0.50 75 m Red (RD) VG 95343 T05 A 005 C 305-04802 4.8 3/16 " 2.4 0.50 75 m White (WH) VG 95343 T05 A 005 L 305-04809 4.8 3/16 " 2.4 0.50 75 m Yellow (YE) VG 95343 T05 A 005 E 305-04804 4.8 3/16 " 2.4 0.50 300 m Black (BK) VG 95343 T05 A 005 A 305-04800 6.4 1/4 " 3.2 0.60 75 m Blue (BU) VG 95343 T05 A 006 G 305-06406 6.4 1/4 " 3.2 0.60 75 m Green-Yellow (GNYE) VG 95343 T05 A 006 N 305-06445 6.4 1/4 " 3.2 0.60 75 m Red (RD) VG 95343 T05 A 006 C 305-06402 6.4 1/4 " 3.2 0.60 75 m White (WH) VG 95343 T05 A 006 L 305-06409 6.4 1/4 " 3.2 0.60 75 m Yellow (YE) VG 95343 T05 A 006 E 305-06404 6.4 1/4 " 3.2 0.60 300 m Black (BK) VG 95343 T05 A 006 A 305-06400 9.5 3/8 " 4.8 0.60 50 m Blue (BU) VG 95343 T05 A007 G 305-09506 9.5 3/8 " 4.8 0.60 50 m Green-Yellow (GNYE) VG 95343 T05 A007 N 305-09545 9.5 3/8 " 4.8 0.60 50 m Red (RD) VG 95343 T05 A007 C 305-09502 9.5 3/8 " 4.8 0.60 50 m White (WH) VG 95343 T05 A007 L 305-09509 9.5 3/8 " 4.8 0.60 50 m Yellow (YE) VG 95343 T05 A007 E 305-09504 9.5 3/8 " 4.8 0.60 150 m Black (BK) VG 95343 T05 A007 A 305-09500 12.7 1/2 " 6.4 0.60 50 m Blue (BU) VG 95343 T05 A 008 G 305-12706 12.7 1/2 " 6.4 0.60 50 m Green-Yellow (GNYE) VG 95343 T05 A 008 N 305-12745 12.7 1/2 " 6.4 0.60 50 m Red (RD) VG 95343 T05 A 008 C 305-12702 12.7 1/2 " 6.4 0.60 50 m White (WH) VG 95343 T05 A 008 L 305-12709 12.7 1/2 " 6.4 0.60 50 m Yellow (YE) VG 95343 T05 A 008 E 305-12704 12.7 1/2 " 6.4 0.60 100 m Black (BK) VG 95343 T05 A 008 A 305-12700 ASN 212 LEA For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Insulation Heat Shrinkable Tubing 2.1 Heat Shrinkable Tubing 2:1 flexible and coloured HFT-A - self extinguishing Heat Shrinkable Tubing 2:1 TYPE HFT-A-19.0/9.5 HFT-A-25.4/12.7 HFT-A-38.0/19.0 HFT-A-50.8/25.4 HFT-A-76.0/38.0 HFT-A-101.6/50.8 Supplied Ø D min. Size (imperial) Recov. Ø d max. Wall (WT) Reel Length Colour Designation as per VG-Norm Article-No. 19.0 3/4 " 9.5 0.80 25 m Blue (BU) VG 95343 T05 A 009 G 305-19006 19.0 3/4 " 9.5 0.80 25 m Green-Yellow (GNYE) VG 95343 T05 A 009 N 305-19045 19.0 3/4 " 9.5 0.80 25 m Red (RD) VG 95343 T05 A 009 C 305-19002 19.0 3/4 " 9.5 0.80 25 m White (WH) VG 95343 T05 A 009 L 305-19009 305-19004 19.0 3/4 " 9.5 0.80 25 m Yellow (YE) VG 95343 T05 A 009 E 19.0 3/4 " 9.5 0.80 50 m Black (BK) VG 95343 T05 A 009 A 305-19000 25.4 1" 12.7 0.90 25 m Blue (BU) VG 95343 T05 A 010 G 305-25406 25.4 1" 12.7 0.90 25 m Green-Yellow (GNYE) VG 95343 T05 A 010 N 305-25445 25.4 1" 12.7 0.90 25 m Red (RD) VG 95343 T05 A 010 C 305-25402 25.4 1" 12.7 0.90 25 m White (WH) VG 95343 T05 A 010 L 305-25409 25.4 1" 12.7 0.90 25 m Yellow (YE) VG 95343 T05 A 010 E 305-25404 25.4 1" 12.7 0.90 50 m Black (BK) VG 95343 T05 A 010 A 305-25400 38.0 1-1/2 " 19.0 1.00 50 m Black (BK) VG 95343 T05 A 011 A 305-38100 38.0 1-1/2 " 19.0 1.00 50 m Blue (BU) VG 95343 T05 A 011 G 305-38106 38.0 1-1/2 " 19.0 1.00 50 m Green-Yellow (GNYE) VG 95343 T05 A 011 N 305-38145 38.0 1-1/2 " 19.0 1.00 50 m Red (RD) VG 95343 T05 A 011 C 305-38102 38.0 1-1/2 " 19.0 1.00 50 m White (WH) VG 95343 T05 A 011 L 305-38109 38.0 1-1/2 " 19.0 1.00 50 m Yellow (YE) VG 95343 T05 A 011 E 305-38104 51.0 2" 25.4 1.10 35 m Black (BK) VG 95343 T05 A 012 A 305-50800 51.0 2" 25.4 1.10 35 m Blue (BU) VG 95343 T05 A 012 G 305-50806 51.0 2" 25.4 1.10 35 m Red (RD) VG 95343 T05 A 012 C 305-50802 51.0 2" 25.4 1.10 35 m White (WH) VG 95343 T05 A 012 L 305-50809 51.0 2" 25.4 1.10 35 m Yellow (YE) VG 95343 T05 A 012 E 305-50804 76.0 3" 38.0 1.30 25 m Black (BK) VG 95343 T05 A 013 A 305-76200 76.0 3" 38.0 1.30 25 m Blue (BU) VG 95343 T05 A 013 G 305-76206 76.0 3" 38.0 1.30 25 m Red (RD) VG 95343 T05 A 013 C 305-76202 76.0 3" 38.0 1.30 25 m White (WH) VG 95343 T05 A 013 L 305-76209 76.0 3" 38.0 1.30 25 m Yellow (YE) VG 95343 T05 A 013 E 305-76204 101.6 4" 50.8 1.40 25 m Black (BK) VG 95343 T05 A 014 A 305-91600 101.6 4" 50.8 1.40 25 m Blue (BU) VG 95343 T05 A 014 G 305-91606 101.6 4" 50.8 1.40 25 m Red (RD) VG 95343 T05 A 014 C 305-91602 101.6 4" 50.8 1.40 25 m White (WH) VG 95343 T05 A014 L 305-91609 101.6 4" 50.8 1.40 25 m Yellow (YE) VG 95343 T05 A 014 E 305-91604 Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. ASN LEA For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation 213
305-01600 价格&库存
很抱歉,暂时无法提供与“305-01600”相匹配的价格&库存,您可以联系我们找货
