561-03699
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 561-03699 - Wire Marker, Snap On Pre Printed, 9, Black, White, 8mm x 3mm, 5.3 mm
561-03699 数据手册
Identification Systems 5.1 Wire and Cable Markers Pre-printed Cable Markers WIC, snap on WIC markers are applied to the wire by simply clicking them on using the WIC tool or if no tool is available they can easily be applied by hand. Simply insert the marker strip into the back of the tool and slide down to the end and simply press the marker down over the wire. Twist the marker off and apply the next marker. Once all the markers are on slide them together until the locking mechanism engages. Features and Benefits • Fast and easy to use pre-printed nylon snap-on marker • Ideal where termination is completed or for maintenance and repair • Markers lock together to give perfect text alignment • Vibration resistant markers, WIC markers lock onto wire and cable tightly • WIC tool holds 20 WIC marker in all three sizes • Gripping system locks markers onto wire and resists rotation • Available in Yellow, White and international resistor colour code • Popular 2 digit markings such as L1, L2, L3, PE are available in Yellow or colour code • Dispenser colour denotes marker size: WIC0 (GN), WIC1 (RD), WIC2 (BU), WIC3 (YE) Use the applicator to simply snap the marker onto your cable. MATERIAL Polyamide 6.6 (PA66) Operating Temperature -40 °C to +85 °C, (+105 °C, 500 h) Flammability UL94 V0 Specifications EN 60062, IEC 304, UL94 Customized marking on request WIC0 WIC1, WIC2, WIC3 TYPE Bundle Ø min. Bundle Ø max. Width (W) Height (H) Length (L) Wire Size Range (mm²) Pack Cont. WIC0 0.80 2.20 5.0 5.5 3.0 0.15 - 0.75 1,000 pcs. WIC1 2.00 2.80 5.0 6.4 3.0 0.50 - 1.50 1,000 pcs. WIC2 2.80 3.80 5.6 7.1 3.0 1.50 - 2.50 1,000 pcs. WIC3 4.30 5.30 8.0 9.6 3.0 4.00 - 6.00 500 pcs. - - - - - - 5 pcs. WIC Tool Application Tool WIC Tool All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Application Tool Date of issue: October 2015 WIC Tool 561-00001 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/identification 449 5.1 Identification Systems Wire and Cable Markers Pre-printed Cable Markers WIC, snap on WIC0 WIC0 TYPE Article-No. TYPE Article-No. TYPE Article-No. WIC0-A 561-00014 WIC0-0 561-00604 WIC0-B 561-00024 WIC0-1 561-00614 WIC0G,H,Y,Z,O, Q,J,K,X,L 561-00003 WIC0-C 561-00034 WIC0-2 561-00624 WIC0-D 561-00044 WIC0-3 561-00634 WIC0-SIGN 561-00004 WIC0-E 561-00054 WIC0-4 561-00644 WIC0-F 561-00064 WIC0-5 561-00654 WIC0L1,L2,L3,N, z 561-00303 WIC0-G 561-00074 WIC0-6 561-00664 0 WIC0-H 561-00084 WIC0-7 561-00674 WIC0-0 561-00600 1 WIC0-I 561-00094 WIC0-8 561-00684 WIC0-1 561-00611 2 WIC0-J 561-00104 WIC0-9 561-00694 WIC0-2 561-00622 3 WIC0-K 561-00114 WIC0-0-9 561-00101 WIC0-3 561-00633 4 WIC0-L 561-00124 WIC0-+ 561-00704 WIC0-4 561-00644 5 WIC0-M 561-00134 WIC0-- 561-00714 WIC0-5 561-00655 6 WIC0-N 561-00144 WIC0-/ 561-00724 WIC0-6 561-00666 7 WIC0-O 561-00154 561-00734 WIC0-7 561-00677 WIC0-z 8 WIC0-P 561-00164 WIC0-. 561-00744 WIC0-8 561-00688 9 WIC0-Q 561-00174 561-00764 WIC0-9 561-00699 WIC0-2 WIC0-R 561-00184 L1 WIC0-L1 561-00314 WIC0-0-9 561-00100 WIC0-S 561-00194 L2 WIC0-L2 561-00324 WIC0-T 561-00204 L3 WIC0-L3 561-00334 + WIC0-+ 561-00702 WIC0-U 561-00214 PE WIC0-PE 561-00344 - WIC0-- 561-00716 WIC0-V 561-00224 WIC0-AC 561-10000  WIC0-z 561-00735 WIC0-W 561-00234 WIC0-DC 561-10004  WIC0-z 561-00739 WIC0-X 561-00244 WIC0-2 561-00769 WIC0-Y 561-00254 WIC0A,E,L,N, R,S,T,+,-,z 561-00994 WIC0-Z 561-00264 WIC0B,C,U,V,W, P,D,F,I,M 561-00005 4 For product specific approvals and specifications please refer to the Appendix. 450 Further information at www.HellermannTyton.com/identification Date of issue: October 2015 WIC0 Identification Systems Wire and Cable Markers 5.1 Pre-printed Cable Markers WIC, snap on WIC1 Date of issue: October 2015 WIC0 WIC1 TYPE Article-No. TYPE Article-No. TYPE Article-No. L1 WIC0-L1 561-00310 WIC1-A 561-01014 WIC1-0 561-01604 L1 WIC0-L1 561-00311 WIC1-B 561-01024 WIC1-1 561-01614 L2 WIC0-L2 561-00320 WIC1-C 561-01034 WIC1-2 561-01624 L2 WIC0-L2 561-00322 WIC1-D 561-01044 WIC1-3 561-01634 L2 WIC0-L2 561-00325 WIC1-E 561-01054 WIC1-4 561-01644 L3 WIC0-L3 561-00332 WIC1-F 561-01064 WIC1-5 561-01654 L3 WIC0-L3 561-00336 WIC1-G 561-01074 WIC1-6 561-01664 L3 WIC0-L3 561-00338 WIC1-H 561-01084 WIC1-7 561-01674 PE WIC0-PE 561-00349 WIC1-I 561-01094 WIC1-8 561-01684 N WIC0-N 561-00140 WIC1-J 561-01104 WIC1-9 561-01694 N WIC0-N 561-00146 WIC1-K 561-01114 WIC1-0-9 561-01101 N WIC0-N 561-00149 WIC1-L 561-01124 WIC1-+ 561-01704 WIC0L1,L2,L3,N, z WIC1-M 561-01134 WIC1-- 561-01714 561-00300 WIC1-N 561-01144 WIC1-/ 561-01724 WIC0L1,L2,L3,N, z WIC1-O 561-01154 WIC1-z 561-01734 561-00301 WIC1-P 561-01164 WIC1-. 561-01744 WIC1-Q 561-01174 WIC1-2 561-01764 WIC1-R 561-01184 L1 WIC1-L1 561-01314 WIC1-S 561-01194 L2 WIC1-L2 561-01324 WIC1-T 561-01204 L3 WIC1-L3 561-01334 WIC1-U 561-01214 PE WIC1-PE 561-01344 WIC1-V 561-01224 WIC1-AC 561-01000 WIC1-W 561-01234 WIC1-DC 561-01001 WIC1-X 561-01244 WIC1-Y 561-01254 WIC1A,E,L,N, R,S,T,+,-,z 561-01994 WIC1-Z 561-01264 WIC1-SIGN 561-01004 WIC1L1,L2,L3,N, z 561-01303 WIC0L1,L2,L3,N, z 561-00302 WIC0-BLACK 561-00750 WIC0-BROWN 561-00751 WIC0-RED 561-00752 WIC0-ORANGE 561-00753 WIC0-YELLOW 561-00754 WIC0-GREEN 561-00755 WIC0-BLUE 561-00756 WIC0-VIOLET 561-00757 WIC0-GREY 561-00758 WIC0-WHITE 561-00759 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/identification 451 5.1 Identification Systems Wire and Cable Markers Pre-printed Cable Markers WIC, snap on WIC1 TYPE Article-No. WIC1-0 561-01600 WIC1-1 WIC1 TYPE Article-No. TYPE Article-No. + WIC1-+ 561-01702 WIC1-BLACK 561-01750 561-01611 - WIC1-- 561-01716 WIC1-BROWN 561-01751 WIC1-2 561-01622  WIC1-z 561-01735 WIC1-RED 561-01752 WIC1-3 561-01633  WIC1-z 561-01739 WIC1-ORANGE 561-01753 WIC1-4 561-01644 L1 WIC1-L1 561-01310 WIC1-YELLOW 561-01754 WIC1-5 561-01655 L1 WIC1-L1 561-01311 WIC1-GREEN 561-01755 WIC1-6 561-01666 L2 WIC1-L2 561-01320 WIC1-BLUE 561-01756 WIC1-7 561-01677 L2 WIC1-L2 561-01322 WIC1-VIOLET 561-01757 WIC1-8 561-01688 L2 WIC1-L2 561-01325 WIC1-GREY 561-01758 WIC1-9 561-01699 L3 WIC1-L3 561-01332 WIC1-WHITE 561-01759 L3 WIC1-L3 561-01336 WIC1-0-9 561-01100 L3 WIC1-L3 561-01338 PE WIC1-PE 561-01349 N WIC1-N 561-01146 N WIC1-N 561-01140 N WIC1-N 561-01149 WIC1L1,L2,L3,N, z 561-01300 WIC1L1,L2,L3,N, z 561-01301 WIC1L1,L2,L3,N, z 561-01302 For product specific approvals and specifications please refer to the Appendix. 452 Further information at www.HellermannTyton.com/identification Date of issue: October 2015 WIC1 Identification Systems Wire and Cable Markers 5.1 Pre-printed Cable Markers WIC, snap on Date of issue: October 2015 WIC2 WIC2 WIC2 TYPE Article-No. TYPE Article-No. TYPE Article-No. WIC2-A 561-02014 WIC2-0 561-02604 WIC2-0 561-02600 WIC2-B 561-02024 WIC2-1 561-02614 WIC2-1 561-02611 WIC2-C 561-02034 WIC2-2 561-02624 WIC2-2 561-02622 WIC2-D 561-02044 WIC2-3 561-02634 WIC2-3 561-02633 WIC2-E 561-02054 WIC2-4 561-02644 WIC2-4 561-02644 WIC2-F 561-02064 WIC2-5 561-02654 WIC2-5 561-02655 WIC2-G 561-02074 WIC2-6 561-02664 WIC2-6 561-02666 WIC2-H 561-02084 WIC2-7 561-02674 WIC2-7 561-02677 WIC2-I 561-02094 WIC2-8 561-02684 WIC2-8 561-02688 WIC2-J 561-02104 WIC2-9 561-02694 WIC2-9 561-02699 WIC2-K 561-02114 WIC2-0-9 561-02101 WIC2-L 561-02124 WIC2-+ 561-02704 WIC2-0-9 561-02100 WIC2-M 561-02134 WIC2-- 561-02714 WIC2-N 561-02144 WIC2-/ 561-02724 WIC2-O 561-02154 WIC2- z 561-02734 WIC2-P 561-02164 WIC2-. 561-02744 WIC2-Q 561-02174 WIC2-2 561-02764 WIC2-R 561-02184 L1 WIC2-L1 561-02314 WIC2-S 561-02194 L2 WIC2-L2 561-02324 WIC2-T 561-02204 L3 WIC2-L3 561-02334 WIC2-U 561-02214 PE WIC2-PE 561-02344 WIC2-V 561-02224 WIC2-AC 561-02000 WIC2-W 561-02234 WIC2-DC 561-02001 WIC2-X 561-02244 WIC2-Y 561-02254 WIC2A,E,L,N,R, S,T,+,-,z 561-02994 WIC2-Z 561-02264 WIC2-SIGN 561-02004 WIC2L1,L2,L3,N, z 561-02303 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/identification 453 Identification Systems 5.1 Wire and Cable Markers Pre-printed Cable Markers WIC, snap on WIC2 TYPE Article-No. TYPE Article-No. + WIC2-+ 561-02702 WIC2-BLACK 561-02750 - WIC2-- 561-02716 WIC2-BROWN 561-02751  WIC2-z 561-02735 WIC2-RED 561-02752  WIC2-z 561-02739 WIC2-ORANGE 561-02753 L1 WIC2-L1 561-02310 WIC2-YELLOW 561-02754 L1 WIC2-L1 561-02311 WIC2-GREEN 561-02755 L2 WIC2-L2 561-02320 WIC2-BLUE 561-02756 L2 WIC2-L2 561-02322 WIC2-VIOLET 561-02757 L2 WIC2-L2 561-02325 WIC2-GREY 561-02758 L3 WIC2-L3 561-02332 WIC2-WHITE 561-02759 L3 WIC2-L3 561-02336 L3 WIC2-L3 561-02338 PE WIC2-PE 561-02349 N WIC2-N 561-02146 N WIC2-N 561-02140 N WIC2-N 561-02149 WIC2L1,L2,L3,N, z 561-02300 WIC2L1,L2,L3,N, z 561-02301 WIC2L1,L2,L3,N, z 561-02302 For product specific approvals and specifications please refer to the Appendix. 454 Further information at www.HellermannTyton.com/identification Date of issue: October 2015 WIC2 Identification Systems Wire and Cable Markers 5.1 Pre-printed Cable Markers WIC, snap on Date of issue: October 2015 WIC3 WIC3 WIC3 TYPE Article-No. TYPE Article-No. TYPE Article-No. WIC3-A 561-03014 WIC3-0 561-03604 WIC3-0 561-03600 WIC3-B 561-03024 WIC3-1 561-03614 WIC3-1 561-03611 WIC3-C 561-03034 WIC3-2 561-03624 WIC3-2 561-03622 WIC3-D 561-03044 WIC3-3 561-03634 WIC3-3 561-03633 WIC3-E 561-03054 WIC3-4 561-03644 WIC3-4 561-03644 WIC3-F 561-03064 WIC3-5 561-03654 WIC3-5 561-03655 WIC3-G 561-03074 WIC3-6 561-03664 WIC3-6 561-03666 WIC3-H 561-03084 WIC3-7 561-03674 WIC3-7 561-03677 WIC3-I 561-03094 WIC3-8 561-03684 WIC3-8 561-03688 WIC3-J 561-03104 WIC3-9 561-03694 WIC3-9 561-03699 WIC3-K 561-03114 WIC3-0-9 561-03101 WIC3-L 561-03124 WIC3-+ 561-03704 WIC3-0-9 561-03100 WIC3-M 561-03134 WIC3-- 561-03714 WIC3-N 561-03144 WIC3-/ 561-03724 WIC3-O 561-03154 WIC3-z 561-03734 WIC3-P 561-03164 WIC3-. 561-03744 WIC3-Q 561-03174 WIC3-2 561-03764 WIC3-R 561-03184 L1 WIC3-L1 561-03314 WIC3-S 561-03194 L2 WIC3-L2 561-03324 WIC3-T 561-03204 L3 WIC3-L3 561-03334 WIC3-U 561-03214 PE WIC3-PE 561-03344 WIC3-V 561-03224 WIC3-AC 561-03000 WIC3-W 561-03234 WIC3-DC 561-03001 WIC3-X 561-03244 WIC3-Y 561-03254 WIC3A,E,L,N, R,S,T,+,-,z 561-03994 WIC3-Z 561-03264 WIC3-SIGN 561-03004 WIC3L1,L2,L3,N, z 561-03303 For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/identification 455 Identification Systems 5.1 Wire and Cable Markers Pre-printed Cable Markers WIC, snap on WIC3 TYPE Article-No. TYPE Article-No. + WIC3-+ 561-03702 WIC3-BLACK 561-03750 - WIC3-- 561-03716 WIC3-BROWN 561-03751  WIC3-z 561-03735 WIC3-RED 561-03752  WIC3-z 561-03739 WIC3-ORANGE 561-03753 L1 WIC3-L1 561-03310 WIC3-YELLOW 561-03754 L1 WIC3-L1 561-03311 WIC3-GREEN 561-03755 L2 WIC3-L2 561-03320 WIC3-BLUE 561-03756 L2 WIC3-L2 561-03322 WIC3-VIOLET 561-03757 L2 WIC3-L2 561-03325 WIC3-GREY 561-03758 L3 WIC3-L3 561-03332 WIC3-WHITE 561-03759 L3 WIC3-L3 561-03336 L3 WIC3-L3 561-03338 PE WIC3-PE 561-03349 N WIC3-N 561-03146 N WIC3-N 561-03140 N WIC3-N 561-03149 WIC3L1,L2,L3,N, z 561-03300 WIC3L1,L2,L3,N, z 561-03301 WIC3L1,L2,L3,N, z 561-03302 For product specific approvals and specifications please refer to the Appendix. 456 Further information at www.HellermannTyton.com/identification Date of issue: October 2015 WIC3
561-03699 价格&库存
很抱歉,暂时无法提供与“561-03699”相匹配的价格&库存,您可以联系我们找货
