Application Tooling
6.1
Application Tooling for Cable Ties
Manual Tensioning Tool with Plastic Housing
• EVO7 up to 4.8 mm strap width
Features and Benefits
• Ergonomic, slip-proof handle for a comfortable and secure grip
• Extremely low maintenance
• Fast and precise application with minimum effort
(TLC mechanism)
• Convenient and simple tension adjustment
• Extended, slim nose for use in narrow spaces
• Housing made of resilient and lightweight glass fibre-reinforced
polyester
• Standard grip span (90 mm) and short grip span (80 mm) available
EVO7.
TYPE
Strap Width
max. (G)
Strap Thickness
max.
Weight
Article-No.
EVO7
4.8
1.5
0.275 kg
110-70129
EVO7SP
4.8
1.5
0.275 kg
110-70130
110-70106
BLADEKIT
All dimensions in mm. Subject to technical changes.
TLC-Technology: Tension - Lock - Cut
The new EVO7 protects muscles and joints and increases effectiveness
• Less recoil shock reduces impact to the operator‘s hand
• Application of force is significantly reduced
One Step to the Web!
308
3. Cut: Innovative, effortless and less recoil shock cut-off function.
Further information and products at www.HellermannTyton.co.uk/a308
Date of issue: January 2014
1: Tension: Tie is tensioned as usual.
2: Lock: When the desired tension is met the locking mechanism locks the tie
in place.
很抱歉,暂时无法提供与“110-70129”相匹配的价格&库存,您可以联系我们找货
