110-95000
    HELLERMAN(海尔曼太通)
110-95000 数据手册
Application Tooling 6.2 Application Tooling for Cable Ties Manual Tensioning Tool for Metal Ties MBT-Series MK9SST up to 16.0 mm strap width The MK9SST is constructed with heavy duty parts to ensure optimum performance. It is designed to apply our MBT cable ties with a strap width of up to 16 mm. The tool is ideally suited for use in most arduous environments such as those found on board ships, oil rigs, construction sites or in nuclear power stations. Features and Benefits • Glass-fibre-reinforced housing • Ergonomic design • Consistent tensioning and automatic cutting of metal ties (MBT-Series) • Infinitely adjustable tension force combined with two-step quick adjustment TYPE MK9SST SP MK9SST replacement blade MK9SST. Strap Width max. (G) Strap Thickness max. Weight Article-No. 16.0 0.3 0.60 kg 110-95000 - - 0.01 kg 110-95273 All dimensions in mm. Subject to technical changes. Pneumatic Tensioning Tool for Metal Ties MBT-Series MK9PSST up to 16.0 mm strap width The MK9 Pneumatic Stainless Steel Tool (MK9PSST) is constructed with heavy-duty parts to ensure optimum performance in demanding environments. It is ideally designed to apply stainless steel MBT-Series (Metal Ball Tie Series) up to 16.0 mm width. MK9PSST. Air Supply Non oiled / oiled Air Pressure (min.) 3 Bar Air Pressure (max.) 6 Bar Hose Internal Diameter 4.0 mm LxHxW approx. 280 x 200 x 55 mm Strap Width max. (G) Strap Thickness max. Weight Article-No. 16.0 0.7 0.91 kg 110-95350 SP MK9PSST replacement blade - - 0.01 kg 110-95307 SP lock cap tensioning knob - - 0.01 kg 110-07200 TYPE MK9PSST All dimensions in mm. Subject to technical changes. 522 Further information at www.HellermannTyton.com/tools Date of issue: October 2015 Features and Benefits • Unique levels of repeatability and accuracy • High application speed and low maintenance • Improved compressed air supply for faster tensioning piston movement • Shorter processing time and greater volume of connecting tie application • Ergonomic design • Automatic ejection of cut-off cable tie end • Ideally designed to apply stainless steel MBT-Series up to 16.0 mm width • Air pressure between 3 and 6 bar
110-95000 价格&库存
很抱歉,暂时无法提供与“110-95000”相匹配的价格&库存,您可以联系我们找货
