111-02447
111-02447
    HELLERMAN(海尔曼太通)
    T50R GRY PVDF TIE 8"
111-02447 数据手册
Revision level SW 06.1 Revision Record Part State Drawing Design Release - Changed Date Approved Date CTF 07/09/2019 GAL 07/09/2019 SEE ECN# 015273 ISOMETRIC VIEW SCALE 1 : 2 6.00 .236 9.00 .354 1.50±0.05 .059±.002 SERRATED SIDE 8.80 .346 4.70±0.05 .185±.002 200.0±3.5 7.87±.14 REFERENCE: PERFORMANCE REQUIREMENTS 1. 2. 3. 4. 5. CABLE TIE MINIMUM LOOP TENSILE STRENGTH: 225N (50lbf) TOOL APPLICATION MAXIMUM TENSION FORCE: 55N (12lbf) BUNDLE DIAMETER RANGE: 8mm TO 50mm TEMPERATURE RANGE: -40°C to +140°C [-40°F to +284°F] MAXIMUM PERCENT REGRIND PERMISSIBLE: 50% Material SEE CHART Units: millimeters Dimension without tolerances details to: .XXX .XX .X None = = = = = .013 .13 .3 .8 0.5 Dimension Formatted mm/[in] 06.1 06.1 Drawn The copyright of this drawing is reserved by HellermannTyton. It is issued on condition that it is not reproduced, copied, or disclosed to a third party, either wholly or in part, without the consent of HellermannTyton. CTF Approved GAL 1/11/2019 Article/Type-No 1/11/2019 Title HellermannTyton North America Email: corp@htamericas.com Web: www.hellermann.tyton.com TYPE COLOR T50R-PVDF-GY PVDF GRAY Scale T50R STANDARD T50R CABLE TIE Drawing-No MATERIAL GLOBAL PART DESCRIPTION PRP 17-2468 Production : Phase Format 17-2468-001-CSU 2:1 Project Number Sheet AH 1/1
111-02447 价格&库存
很抱歉,暂时无法提供与“111-02447”相匹配的价格&库存,您可以联系我们找货
