111-04000
111-04000
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 111-04000 - Comfort Strip, Polyolefin, 50mm, White, Mask E-Guard
111-04000 数据手册
HellermannTyton DATA SHEET MASK E Guard: DESCRIPTION The MASK E-Guard is designed to relieve tension and strain from the ears when wearing face masks. The unique design attaches to the mask so the elastic is positioned away from the ears. APPLICATION Comfortable - relieves pressure on the ear caused by wearing a face mask. Adjustable and easy to fit - simply tear off as many pieces as required. Ideal for use with disposable face masks. PROPERTIES Properties Material Continuous Operating Temp Tensile Strength Elongation at break Food contact Approval Typical Results Test Method Polyolefin -40ºC to + 85ºC 40MPa 180% Raw Materials approved to ASTM D638 ASTM D638 Regulation (EC) No 1935/2004 FDA regulation 21 CFR 177.1350 Resistance to: Oils & Lubricants Fuels Acids & Alkalis Solvents Colour Good Good Very Good Good White STANDARD LENGTH: L= 50 mm Issue 1 Plymouth International Medical & Technology Park , W il l i a m P r a n c e R o a d , P l ym o u t h , D e vo n P L 6 5 W R, E n g l a n d Te l e p h o n e : + 4 4 ( 0 ) 1 7 5 2 7 0 1 2 6 1 ; F a x: + 4 4 ( 0 ) 1 7 5 2 7 9 0 0 5 8 06-2020
111-04000 价格&库存
很抱歉,暂时无法提供与“111-04000”相匹配的价格&库存,您可以联系我们找货
